G-JIMG Posted October 9, 2018 Share Posted October 9, 2018 Until now I've always flown IC aircraft but my latest build will be a twin using: 2 x PO-3547-800 Motors 2 x PP-TESC45AV ESCs 2 x 4S 14.8V 3700mAh Batteries 1 x tbd UBEC Question is, what's the best way to connect them? As two separate configurations with the UBEC connected to one of them (a), or with everything connected in parallel (b)? Also, there is plenty of cooling in the nacelles so presumably it's a good place to put the ESC's, but the batteries will be in the fuselage requiring about 18" of wire to reach the ESC. I suspect that may be a problem, but I also suspect that two ESCs in an uncooled fuselage may also be an issue. Thoughts? Jim. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 9, 2018 Share Posted October 9, 2018 Hi, Best suggestion is to talk to George at 4Max, I have always found him very helpful + there are a few help guides on his website. IMHO it won't make any difference either having longer battery leads or motor leads (tin hat on!) however other ESC manufacturers state that if battery leads are extended then additional capacitors are to be added. If its a small model then option "a" is okay (although if you have a spare channel you could have differential throttle if you want (very helpful if you have no rudder control)). I don't think option B helps unless diodes are used so the UBEC can be fed from either ESC (in case one battery goes flat). There are dual fed switches that can supply an RX from either battery so that's an option. I have a couple of 62" models that use only 1 lipo 4S5000 for both ESC's and a separate 2S1000 lipo for the RX (via UBEC). That way you power up the RX first and can check controls, then power up the ESC's when ready to fly Is there a reason why you want 2 main batteries? Do you have spare RX batteries for your IC models you can use? Tin hat on again! You may have a start up sequence issue with option A if you power up the lower ESC and don't have the RX powered up (check with George, as other makes have caught me out). PM me if you want a wiring diagram Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 9, 2018 Share Posted October 9, 2018 If you use two batteries, for whatever reason, I would suggest that you connect their power leads together so they both feed both ESCs and motors. This avoids the embarrassment of one motor dying before the other, due to one battery not fully charged, assuming of course that you never try to run them down to less than, say, 20% capacity. As for the BECs, it depends partly on what spec. the ones built into the ESCs are, and how big and complicated the model is. You certainly shouldn't have them both feeding into the receiver, unless you have an arrangement of diodes to prevent them back-feeding into each other. In some of my models I use the BEC in one of the ESCs to power the electric retracts and lights, and the other to power the receiver and servos. In others I've paralleled the BECs, using diodes to isolate them, so they both feed the receiver and servos. And in a couple of helis I've used a stand-alone BEC in parallel with the ESC's BEC, via diodes, to provide some kind of redundancy in case one BEC fails. It is said that long wires between battery and ESC can cause the ESC's capacitors to break down over time, followed by the electronics. This can be prevented by adding more capacitors across the power wires, close to the ESC. Long wires between motor and ESC don't cause any problem other than, perhaps, extra weight, and the fact that the ESCs might overheat if installed in the fuselage. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted October 11, 2018 Author Share Posted October 11, 2018 Thanks for the help guys. I contacted George and he was very, very helpful. He determined that: I do need two batteries because it will draw too much current with only one. I shouldn't connect them in parallel because if there's a miss-match it could result in a high current condition. Long wires between the battery and ESC is no longer an issue with modern ESCs. Based on that, and using standard 'Y' harnesses as far as possible, the wiring will be as per the schematic: As per Chris's comment, I will have to ensure the Right battery is always connected first to ensure the Rx is powered. Jim. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted October 11, 2018 Share Posted October 11, 2018 That schematic looks fine but I hope the advice is right about long battery to ESC leads being acceptable for 'modern' ESCs. My understanding is the problem is due to the long leads generating voltage spikes due to the pulsed nature of the current flow. The spikes damage the ESC's electrolytic capacitors. The longer the lead the higher the potential voltage of any spike. Capacitors can stand the spikes for so long then fail almost at random. Without correctly functioning capacitors the rest of the ESC is likely to fail in short order. Of course I may be wrong. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 11, 2018 Share Posted October 11, 2018 Jim, Looks good and if George suggests it with his experience I am sure he's spot on. His advice to me (twin IC with flaps and retracts) was to have one RX battery and a high power UBEC. His rational was that if a retract servo failed the UBEC voltage would not drop as the servo failed due to the high current performance of the UBEC. As you have two batteries you might as well spread the load for the cost/weight of another UBEC so I can see that logic. Only issue with UBEC's was with a HK one and some digital servos where if all three were used at the same time it "browned out" the RX voltage. Fortunately if found it on the bench and just bought a 4-max UBEC to solve the issue. It would have been a real gutter if the plane had been flown as my normal control checks are individual and slow so I would not have found the issue until a time of high stress panic which is not when you want to test the re-initialisation time of the RX! Be great for the rest of us if you set a build log up and post a few pictures PS all the best with the build Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted October 11, 2018 Share Posted October 11, 2018 That's a very similar set-up to the one I use in my Black Horse Mosquito. In that, the esc's are in the fuselage as there is room. A bit of air gets in around the nose machine guns and I have a small air scoop hidden under the wing root. The esc's have heatsinks and small cooling fans on them. There is an air exit near the tail. I've used 3-way versions of XT60 connectors for each set of motor leads - the wing halves separate. This arrangement was in the model when I bought it (secondhand) and has worked well. If I was starting from scratch I would probably put the esc's in the wing root radiators, which would be better for cooling and still keep the battery wires reasonably short. Depending on your model, you may be able to do something similar. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted October 11, 2018 Author Share Posted October 11, 2018 Simon, I had the same understanding as you but couldn't find a definition of "long". I asked George at 4Max and his response was, " The long wires on ESCs used to be a problem, but most modern manufacturers have designed around this and now long wires are no longer a problem". I assume they've addressed the issue within the ESC itself. Chris, Which 4Max UBEC did you purchase for your twin? He only has 4 for sale and the 20A version seems a bit of an overkill. I'm considering the 6A version. I am taking photographs of the build and may well start a build log at some point, I just didn't want to be yet another guy that starts a log that peters out after a few months. Jim. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted October 11, 2018 Author Share Posted October 11, 2018 Trevor, The model is based on the King Air 350 Turboprop aircraft. Consequently, there is a large air intake directly below the prop hub and an even larger exit 'hole' in the underside of the nacelle. That's why I'd really like to mount the ESC directly beneath the motor, smack in the middle of the airflow. The only concern I had was the length of wire to the fuselage mounted battery, but, according to George, that's no longer an issue. Jim. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted October 12, 2018 Share Posted October 12, 2018 Jim, I read recently in an RCM&E article that the adverse effect of long leads can be mitigated by fitting capacitors every few inches. Unfortunately I can't remember the spacing or capacitor values, and I think I've passed the mag on now. I think it was in Brian Collins' series on escs, perhaps someone else can enlighten us. Better safe than sorry! Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 12, 2018 Share Posted October 12, 2018 There's a long thread about the long-battery-lead saga in another forum. Suggestions for overcoming the problem are in the first post. Presumably the advice that modern ESCs don't suffer this problem is based on the fact that modern ESCs may have more capacitors (those big round cylinders near the power wires) and thus be able to cope with the voltage spikes generated in long wires. I can't vouch for this though, based on my own experience, and the fact that some major ESC manufacturers offer supplemental capacitor packs for you to add. I don't agree with the advice about not connecting the batteries in parallel: If there is a mismatch (one charged less than the other, I presume), then one motor will cut before you expect it to, unless you have separate voltage monitoring telemetry on each pack so you can land when the voltage gets too low. With them connected in parallel you can be reasonably sure that both motors will lose power at the same time, maybe resulting in a dead-stick landing, but not in a spiral dive. In fact, with them in parallel you can ensure that both motors will cut at the same time if lvc is reached, by using a LipoShield between the receiver and the two ESCs. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted October 12, 2018 Author Share Posted October 12, 2018 George (4Max) can obviously only speak for his ESCs, which he guarantees will operate correctly with long ESC to Battery wire lengths (20"+). Apparently it's not just the capacitors they now use, it's also that the Power Triacs are now more resistant to spikes. Regarding connecting the batteries in parallel; it's not recommended because if the voltage is different (more that 0.03V per pack) the current transfer from the high voltage pack can be huge and end up damaging both batteries. Quote Link to comment Share on other sites More sharing options...
PatMc Posted October 12, 2018 Share Posted October 12, 2018 Posted by G-JIMG on 12/10/2018 22:28:38: Regarding connecting the batteries in parallel; it's not recommended because if the voltage is different (more that 0.03V per pack) the current transfer from the high voltage pack can be huge and end up damaging both batteries. That's baloney, there's more chance of one battery failing before the other & causing an unexpected single motor spiral dive. What does George's guarantee cover if your model is written off due to one ESC failing ? A replacement ESC ? Personaly I'd go with parallel batteries & 2x 45A - 60A opto ESCs installed in the fuselage with extended ESC to motor leads. There must be plenty of room in the fuselage to allow for adequate ventilation for batteries & ESCs. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 13, 2018 Share Posted October 13, 2018 Posted by G-JIMG on 12/10/2018 22:28:38: ..... Regarding connecting the batteries in parallel; it's not recommended because if the voltage is different (more that 0.03V per pack) the current transfer from the high voltage pack can be huge and end up damaging both batteries. I don't have any numbers for exactly how much resistance is in the wiring and connectors, but even a total of 0.003 ohms (including wires, connectors, and batteries' own internal resistance) would only result in a momentary current of 10A if the voltage difference between parallel packs was 0.03v. That's not 'huge' and, I'm sure, is far less than the momentary current one gets when the ESC's capacitors charge up when the battery is connected, and it's much more preferable to me than one motor shutting down suddenly. Quote Link to comment Share on other sites More sharing options...
Peter Beeney Posted October 13, 2018 Share Posted October 13, 2018 Back in the day, when lipos first appeared on the scene and then balancing the cells when charging suddenly became necessary, a lot of discussion started up which suggested that before paralleling the packs together all the voltages must be exactly equal otherwise as stated the current transfer would be high and damage would occur. I wasn’t really convinced about this so in the usual pb ‘poke and hope’ tradition I tried a little experiment. Using two 3S 2200mAh packs, both in good order, I fully charged one to12.6 volts, and discharged the other until the open circuit voltage read 9 volts; it was definitely flat! I then just paralleled them directly together. I made a sacrificial item for the final connection; a short piece of heavy duty cable and a large croc clip. I didn’t particularly want to burn the sockets, I thought that perhaps this was the biggest danger. I used a clip on power meter to measure the amps and when I closed the croc clip on the wire the instantaneous current flow read 18 amps. This then began to tick down at about 1 amp per second until it reached a rate of about 8 amps. It then started slow further and when it fell to the 3 amp level I disconnected, nothing was going to change much from there. The two packs would eventually reach parity, cells in a simple parallel circuit will always eventually level out at the same voltage, whatever the circumstances; plus my power meter might not always be strictly accurate below 4 amps anyway. This would imply that the total circuit resistance would be around 200 milliohms, certainly the internal resistance of the fully discharged pack would be at a maximum. Nothing warmed up, at least to the touch. Both packs recharged ok and just carried on powering models as if nothing had happened. As it happened, I was not in the least bit surprised about any of these events. Not really a comment on how to parallel packs and cells, this is just a statement of what I recorded when I tried the worst case situation. If I tried it with say 6S packs the voltage differential would be twice as much but the internal resistance would also be higher so maybe there would not be much difference in the current flow rates. PB Quote Link to comment Share on other sites More sharing options...
andyh Posted October 18, 2018 Share Posted October 18, 2018 another vote here for parallel batteries feeding both ESC's (& both uBECs), so long as they're well matched I don't think you'll have any issues. one other thing to note, I see on your diagram that you've disconnected the +ve red wire on the "trunk" of the Y-lead from the Rx to the ESC's as you're using a uBEC. personally, I would (& do) disconnect the red wires on the two "branches" of the Y such that the two ESC +ve's aren't connected, rather than on the "trunk". Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 18, 2018 Share Posted October 18, 2018 Absolutely disconnect the red wire at each ESC, if using a separate UBEC (or battery). "I do need two batteries because it will draw too much current with only one." Say what? You could fit one single larger battery. Of around double the capacity of the individual pack size. 4S 8000mAh. Here's one for £56. With max rated discharge of 240A. I'd de-rate that to about half - being a hobbyking effort - but I would think 120A would more than cover your needs. On the other hand, 4S4000 is quite a useful size pack and you might want to use a single one in another project. Your call of course. "I shouldn't connect them in parallel because if there's a miss-match it could result in a high current condition" I would personally absolutely connect them in parallel. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted October 18, 2018 Author Share Posted October 18, 2018 Thanks, I'd already figured out I need to disconnect both Red wires at the ESCs but it's nice to have it confirmed. I already have 4S 3700mAh batteries, hence the statement that I need two of them. The model uses scale 10.5" 4-bladed props and the Battery/ESC/Motor combination has already been tested and proven to provide the required thrust. I understand the rationale behind parallel wiring of the batteries and the benefits it can bring, but there is also battery life to consider, these things are not cheap! Although a slight mismatch is unlikely to destroy the battery(s) I understand that it could severely shorten their life. Quote Link to comment Share on other sites More sharing options...
Peter Beeney Posted October 18, 2018 Share Posted October 18, 2018 G-JIMG - With respect, but may I ask how you are considering, or describing, a mismatch, please? And indeed, how it might shorten a particular battery’s life? I’m only just asking out of interest… PB Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted October 18, 2018 Share Posted October 18, 2018 I understood that one advantage of a LiPo cell is that it obtains its nominal charge voltage very quickly from a discharge state. This means that connecting batteries in parallel but with a different charge state will not result in a large long term current flow. This is exactly what Peter Beeney identified even with batteries at the extremes of charge level... This is the same situation when you use multiple charging board where in effect several batteries are connected in parallel and you don't have to worry about them all being at exactly the same charge level. They all quickly achieve a common cell voltage and then share the charge current proportional to minute variations in cell voltage until they all reach the full 4.20 V state. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 18, 2018 Share Posted October 18, 2018 Peter, with all due respect it is not what Jim is saying it is what he has been told by George the owner of 4Max (the equipment supplier). As I mentioned earlier in the post, if you want to hear it from the person who will give you his professional advice for free then it is best to contact him directly on 01256 782 512 What I cannot comprehend is that people will post directly the opposite to what George advises about his products in this forum. Perhaps people enjoy misinforming others. Quote Link to comment Share on other sites More sharing options...
andyh Posted October 18, 2018 Share Posted October 18, 2018 Posted by Chris Walby on 18/10/2018 19:31:13: What I cannot comprehend is that people will post directly the opposite to what George advises about his products in this forum. I think LiPo's are a sufficiently generic product that other people are entitled to an opinion based on their own experience of using essentially identical products. Quote Link to comment Share on other sites More sharing options...
Peter Beeney Posted October 18, 2018 Share Posted October 18, 2018 Chris - I certainly wasn’t intending to be in any way critical of G-JIMG or George at 4MAX, I was simply interested in the definition of a mismatch between lithium polymer packs when connected in parallel; and I certainly didn’t intend to post anything that directly contradicted anything that George said; or even only slightly contradicted anything he said. Neither was I intending to post something that is directly the opposite of what George advises, indeed in my previous post about paralleling lipos I did say that that it was ‘not really a comment on how to parallel packs and cells, this is just a statement of what I recorded when I tried the worst case situation.’ Many apologies if this is how it appeared to be… If G-JIMG choses to connect and power his model with two separate packs I don’t have the slightest problem with that at all, there are many ways of skinning a cat, as they say. That is until the momentum starts to get a bit of a wobble on, though; then if you’ve not taken this possible situation into account things can get a bit tricky. I’ve noticed it does happen occasionally with model aeroplanes… I tend to base my actions on the experience of spending many years in a previous working life tinkering about with things electric, including occasionally connecting in series and parallel cells and batteries that clocked enough voltage and sufficient capacity to cause a minor lightning flash if you got it wrong! Fortunately I never did, I’m frightened of electricity, but I was involved in more than one investigation when it did happen. Hopefully this is not misinforming anybody… PB Edited By Peter Beeney on 18/10/2018 22:44:12 Quote Link to comment Share on other sites More sharing options...
PatMc Posted October 18, 2018 Share Posted October 18, 2018 Posted by Chris Walby on 18/10/2018 19:31:13: Peter, with all due respect it is not what Jim is saying it is what he has been told by George the owner of 4Max (the equipment supplier). As I mentioned earlier in the post, if you want to hear it from the person who will give you his professional advice for free then it is best to contact him directly on 01256 782 512 What I cannot comprehend is that people will post directly the opposite to what George advises about his products in this forum. Perhaps people enjoy misinforming others. Or perhaps George is wrong. Edited By PatMc on 18/10/2018 22:51:16 Quote Link to comment Share on other sites More sharing options...
Gordon Tarling Posted October 19, 2018 Share Posted October 19, 2018 Posted by Chris Walby on 18/10/2018 19:31:13: Perhaps people enjoy misinforming others. Depends who you consider is misinformed. Quote Link to comment Share on other sites More sharing options...
