laser cutter
I am a keen scratch builder and want to buy a laser cutter to cut ribs / formers etc in balsa and ply. I will need a machine that can cut parts for planes up to about 80" wingspan. Can anyone recommend a suitable make / model of machine capable of doing this that is not going to cost an arm and a leg? Any help appreciated.
a good router cutter will be as good as a laser cutter for cutting out ribs etc in ply or balsa wood .
many pros and cons , one issue that should be considered is the cost of the lamp some are expensive but last longer and cheep ones not so. also do't forget the software to operate.
This makes interesting reading.
It describes in detail making a 3D printer using CoreXY plotting based on aluminium extrusions and standard 3D printer parts.
Once he has that working, he then changes it so the head can be changed from an extruder to a laser cutter.
A YouTube intro and links to the build logs can be found here.
Definately food for thought.
  • 6 months later...
I actually thought about getting a laser cutter of my own. I had quite a few parts to make here and there and finding a manufacturer was a real pain in the ass. Looking for similar info like you, I stumbled upon this site. It actually makes getting a few parts easy, so I buried the thought. Maybe you can find some relief here as well laugh
I have a Ex school Denford Cnc router,,,it’s taken a age to set up and found software trying,,,
only just started to get good results,,,,,
my mate has purchased a cnc 4 axis router of internet,,, cones complete with everything you need,,, it’s very good and appears to be fairly easy to sort out .
and there’s the problem,,,,,if you need it for a one of job it probably won’t be cost effective,
if if you like to play and learn go for it,,,
although you can do 3D on a router,,, the laser is more forgiving if the speeds are to high..
I would prefer a Laser cutting machine over a router, if I was starting a fresh ..
plus lush the other issue is you need to have the capability of CAD drawing ,,,, google sketchup is good but you still need to learn it
Edited By bert baker on 24/05/2019 18:41:06
There is a company near me that does laser cutting and recently found out cnc router work as well.
I was talking to them about getting hand drawn parts cut and they took me to the machines to see. And showed me the cut parts. I could tell straight away that the router had a much more vertical cut on the thicker material,even more so on ply.
The only neg on the router was the inner corners are rounded,easy to sort.
I would rather have router cut parts the laser. This is just my limited opinion on parts seen and nothing to do with the machine
Posted by bert baker on 24/05/2019 20:31:47:
My thinking is Laser is more like printing and probably less hassle
Each system has advantages and disadvantages. A laser cutter might be quicker than a router, though you get (not quite vertical) burnt edges and fumes that you need to extract outside. A router does a very neat job but produces a lot of dust, which is more difficult to get rid of than fumes. Again there are jobs you can and can't do with both of them.
I have a fair sized laser cutter, which does all the jobs I want. I am constantly learning with it and improving my technique. It is as much a hobby in itself as any other.
I would advise that if you can find someone reliable to do your cutting, then that is the most economical way. Also it is producing the files to cut with that is the time consuming job. Cutting them is the easy part. Better to learn how to produce the files BEFORE buying a machine. It's a lot cheaper that way !
I have a laser machine that I bought on Ebay from China. Very happy with it, buy the most powerful laser you can afford and I wouldn't use the benbox software that comes with it either. I use Bencutlaser and it is very ease to use. There is a dedicated forum and Ralph the site admin answers all queries.
Regards
James
