Joe Newrick Posted April 30, 2019 Share Posted April 30, 2019 Hi I need some 1/8" and 1/4" aircraft grade plywood for my latest build. I cant seem to find anywhere that sells it? I have lots of lite ply but cant find aircraft grade. Does anyone know of somewhere I can order this only, or an alternative term for my "google-ing" Thanks! Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted April 30, 2019 Share Posted April 30, 2019 https://www.aircraftplywoodandtimber.co.uk/birch-plywood.html How about that? Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted April 30, 2019 Share Posted April 30, 2019 Sizes are large and so delivery expensive Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 30, 2019 Share Posted April 30, 2019 SLEC, INWOOD, BALSA BUTCHER. Aircraft grade is is nothing special. I assume it a model. Quote Link to comment Share on other sites More sharing options...
Martin Dilly 1 Posted April 30, 2019 Share Posted April 30, 2019 You could try contacting the Light Aircraft Association. Some home builders might have small amounts they could sell you. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 30, 2019 Share Posted April 30, 2019 Although Birch Ply appears in 8' x 4' foot sheets The thickness is usually Metric these days And 3mm and 6mm Birch Ply are very common in model construction And are available in smaller sheets from Dons listed suppliers Quote Link to comment Share on other sites More sharing options...
Levanter Posted April 30, 2019 Share Posted April 30, 2019 Joe Welcome to the forum. What is your latest build? There are lots of different types of ply and what you are searching for as "aircraft grade" may well be over the top. Levanter Quote Link to comment Share on other sites More sharing options...
Joe Newrick Posted April 30, 2019 Author Share Posted April 30, 2019 Thanks for the responses. It is a 1/4 scale L19 bird dog. I am using the Vailly plans but cutting the kit myself so trying to find some of the wood is difficult. its 108" span and target auw of around 10kg. Says to use "3mm" (1/8th) lite ply, then the same thickness in aircraft grade ply and laminate the 2 ribs together. Also says to use 1/4" aircraft grade ply for the engine firewall and sections on the fuse where the wings join. Should I just use birch ply in place of aircraft grade? Its far easier to get hold of in smaller quantities. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 30, 2019 Share Posted April 30, 2019 Yes Joe Birch Ply, used in models for a lifetime 3mm and 6mm in your case Quote Link to comment Share on other sites More sharing options...
Levanter Posted April 30, 2019 Share Posted April 30, 2019 Like Dennis says. My local model shop only stocks birch ply up to 3mm so if I want something thicker I laminate 2 or more pieces together. Post some photos of your build. It will be interesting. Levanter Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 30, 2019 Share Posted April 30, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 1, 2019 Share Posted May 1, 2019 As has been said. SLEC have a large range of sizes in Liteply and Birch ply. I would expect birch ply to be fine. Aircraft grade will be specially made to a specification and will cost a small fortune. AGS (Aircraft General Sapres) nuts and bolts cost a fortune compared to normal high tensile bolts bought from a shop Quote Link to comment Share on other sites More sharing options...
Joe Newrick Posted May 1, 2019 Author Share Posted May 1, 2019 Thanks for all the help, think I will just give birch ply a a try. Will put an order in with SLEC. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted May 1, 2019 Share Posted May 1, 2019 I beg to differ on the thicknesses. Lite ply is metric, birch is still generally imperial, although I once did a little repair work on a full size Stampe and the LE sheeting was 1mm aircraft grade birch. No different to the stuff we use except for the inflated price. Quote Link to comment Share on other sites More sharing options...
