john stones 1 - Moderator Posted April 6, 2020 Share Posted April 6, 2020 First run today, running on 20% for the break in and propped down, fired up first time and ran as sweet as a nut, throttlings good, pretty clean considering the mix, NGH wrap around pitts exhaust from Just Engines, think It'll be o.k for noise when propped up. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 6, 2020 Share Posted April 6, 2020 Superb pics John Please tell me that you use a real camera? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 No ones ever said that to me, now I'm waiting for the gag. It's a Nikon bridge camera £70 second hand Denis. Coolpix L120. Edited By john stones 1 on 06/04/2020 17:04:00 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 6, 2020 Share Posted April 6, 2020 No gag honest. It just our phones have taken over John, and the lens is never that clean, and the camera is just too small. In the olden days I helped students organise folders and you could clearly see a decent camera was used with a clean lens. Your pics are just clear and easy to see the detail. That silencer looks the business and don't forget it sounds worse on the ground near the house. Judge it in the air. You know that. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 6, 2020 Share Posted April 6, 2020 20%, did you mean 20:1 petrol/oil ratio? Be interesting to know your noise readings once you've got it ready to fly, thanks. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 Yep a proper prop on it'll be fine I reckon Denis. My phone has no camera, tinternet, text and calls only £10 from Asda, nice and small, folds to keep work muck out. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 Posted by Frank Skilbeck on 06/04/2020 17:52:33: 20%, did you mean 20:1 petrol/oil ratio? Be interesting to know your noise readings once you've got it ready to fly, thanks. Yep 20% for break in, follow the manual, then 30% - 33% for flying, another run and I'll fly it next, revs not going up n down, pick up is crisp, not touched needles, If it continues to perform like this I'll be very happy. Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 6, 2020 Share Posted April 6, 2020 Posted by john stones 1 on 06/04/2020 17:57:31: Posted by Frank Skilbeck on 06/04/2020 17:52:33: 20%, did you mean 20:1 petrol/oil ratio? Be interesting to know your noise readings once you've got it ready to fly, thanks. Yep 20% for break in, follow the manual, then 30% - 33% for flying, another run and I'll fly it next, revs not going up n down, pick up is crisp, not touched needles, If it continues to perform like this I'll be very happy. 20% is not the same as 20:1 fuel ratio which works out to 5% oil content as per the instructions and when run in you can reduce the oil to 4%which is 25:1 so please be carfull Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 Mix is correct F1, me grandma (Grammar) at fault. Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 6, 2020 Share Posted April 6, 2020 Posted by john stones 1 on 06/04/2020 18:30:32: Mix is correct F1, me grandma (Grammar) at fault. OK I'll let you off as you have probably seen my grammer/spelling Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 6, 2020 Share Posted April 6, 2020 Good luck with the noise test, I’ve always found there’s a fearsome crackle with NGH gas engines. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 Posted by cymaz on 06/04/2020 21:58:11: Good luck with the noise test, I’ve always found there’s a fearsome crackle with NGH gas engines. I'm deaf in one ear, sounds fine to me, silencer is pretty good, I can go up 2 inch on prop, plus I have plenty grunt and pepper pots if needed. Quote Link to comment Share on other sites More sharing options...
Handyman Posted April 6, 2020 Share Posted April 6, 2020 Hi John.May I ask what the model is that you are fitting your NGH17 engine into. I have an unused 17 that I have fitted a venturi on to. It apparently improves the running of the engine and stops fuel being sucked out of the carby,especially when fitted inverted. I have been trying to find a suitable model for my engine,and I like the look of yours. Many thanks. Anthony. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 6, 2020 Author Share Posted April 6, 2020 You can Anthony it's a Seagull Funky Cub, shop around for best price. Quote Link to comment Share on other sites More sharing options...
Handyman Posted April 7, 2020 Share Posted April 7, 2020 Hi John. I did a search and Sussex Model Centre has one in stock for £219 with free post I will have to empty my piggy bank and see how much is in there. Thanks again,I appreciate it. Anthony. Quote Link to comment Share on other sites More sharing options...
Handyman Posted April 14, 2020 Share Posted April 14, 2020 Hi again John Stones 1. I received my Funky Cub on Saturday last from SMC Models. As I said,only £219 free post. The manual that came with the engine quotes a propeller size of 13x8---15x8 that is for a 2 bladed prob. I would like a bit more ground clearance, so I was going to go for a 3 bladed prop. Any advice what size and pitch of prop would suit the NGH 17 engine. Hope you don't mind me asking. Anthony. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 15, 2020 Author Share Posted April 15, 2020 It gives a range Anthony, the prop used depends on the model and what you want from the Engine, I honestly couldn't tell you if a 3 bladed prop suits, It's suck it n see I would think. I can tell you even with a 15 inch prop on, there's plenty of clearance. I will be going with a 15x6 most likely 15x8 if it noisy, ask away if I can help, I will. Gave it a few more runs, starts very easy. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 15, 2020 Author Share Posted April 15, 2020 According to info on here Anthony, for a 3 bladed you go 1 inch down in length and 1 number down in pitch, so a 15x8 would be 14x7. Other opinions may vary, I have no idea. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Author Share Posted May 24, 2020 Just found a spring I haven't fitted, ran it already and no issues, what's the springs purpose ? Plug cap fits very snuggly, spring looks a bit Heath Robinson. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 24, 2020 Share Posted May 24, 2020 I'd be very cautious if you decide to omit it. I can see it in the picture under the polythene bag but can't make out all of the writing. If the plug cap comes off in use, it's quite possible that the ignition unit will be damaged irreparably - many are encapsulated in epoxy resin, so no chance of faultfinding. Edited By Martin Harris on 24/05/2020 19:43:11 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2020 Author Share Posted May 24, 2020 Found a separate piece of paper, It appears It's for different spark plugs, the type I have are bayonet push/twist fittings, the springs are for C-M6 plugs, clear as mud. Quote Link to comment Share on other sites More sharing options...
Jesus Cardin Posted May 24, 2020 Share Posted May 24, 2020 Well, both fopr JBA and NGH engines there are reports of misfiring and engines quitting due to plug cap bad contact and/or disconnecting from vibration (they are quarter of a turn fixing type). The spring just add a bit of tension and reduces the risk of the cap turning while flying. Quote Link to comment Share on other sites More sharing options...
