Bob Bertram Posted November 9, 2020 Share Posted November 9, 2020 That's the one I was thinking of FF, but maybe a red one would be better for visibility. Anyway, that is a while in the future. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 10, 2020 Author Share Posted November 10, 2020 More progress. I tried to follow Trevor's advice regarding choice of balsa but all my stock is the same so I had to use what I had. Looking at the elevator now and wondering whether to make it open frame or not as there looks to be very little to gain by doing so. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 10, 2020 Share Posted November 10, 2020 It is amazing how little you would actually save. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 11, 2020 Author Share Posted November 11, 2020 My thoughts exactly Peter. Glued up now. Cheers Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 13, 2020 Author Share Posted November 13, 2020 Progress. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Bob Bertram Posted November 13, 2020 Share Posted November 13, 2020 Very smart. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 14, 2020 Author Share Posted November 14, 2020 Thanks Bob. Next on the list is filling in this gap. Marking out on a piece of scrap 1/4" balsa then cutting out, leaving a margin of error. Next is working out the side fillet shape. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 14, 2020 Share Posted November 14, 2020 If you look through some of my builds you wil seethe easy way ofmaking the fin fairings. Scrap 1/4" sheet in place of the tailplane and fin spoot glued in place. Scraps of block each side. shape to match then split them apart and you have two block that will fill the conrer perfectly Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 14, 2020 Author Share Posted November 14, 2020 Like I did on the Ballerina. For some reason I did not think it would work, over thinking it I think. Just waiting for glue to dry then add the fairing blocks. It's full steam ahead now or should that be full throttle now? Cheers Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 15, 2020 Author Share Posted November 15, 2020 Progress. Temporary T shaped to the fuselage. Balsa blocks made up. And sanded to shape. A lot of work for two small pieces of balsa is my first thought, but then it would look ugly without them, even at 50' Cheers Steve Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted November 15, 2020 Share Posted November 15, 2020 Looking better all the time Earlybird. Here's some video of the full size doing its thing: RF4 Aerobatics Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 16, 2020 Author Share Posted November 16, 2020 Wow thanks for that FF. Just one question does yours do all those manoeuvres? Hmm more to the point will mine? Cheers Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 16, 2020 Share Posted November 16, 2020 I don't know about Fun Flyer's but mine did so his should. But mine did have a 30 FS in it. The film that I liked showed two Fourniers flying in perfect mirror formation. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted November 16, 2020 Share Posted November 16, 2020 Well mine will loop without any problem but I haven't been more adventurous than that so far. Now where will I get a smoke system for an electric model? Quote Link to comment Share on other sites More sharing options...
Trevor Posted November 16, 2020 Share Posted November 16, 2020 Why settle for just smoke? There must be plenty of unsold fireworks going cheap at the moment 😇 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 17, 2020 Author Share Posted November 17, 2020 More progress on the tail. The part to fill the gap glued to the fin. and test fit which shows that a bit of trimming is needed. Which is obvious when the tailplane is in place. That looks better. Cheers Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 18, 2020 Author Share Posted November 18, 2020 Cheers Steve Quote Link to comment Share on other sites More sharing options...
Bob Bertram Posted November 18, 2020 Share Posted November 18, 2020 Very nice Steve, your work is much better than mine. My turtle deck is not very smooth with indentations between one or two formers and have been contemplating cutting it off and replacing it or maybe call it the filler queen!!! Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted November 18, 2020 Share Posted November 18, 2020 The built up tail really looks the part. Well worth the extra work. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 18, 2020 Share Posted November 18, 2020 That is looking excellent Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 19, 2020 Author Share Posted November 19, 2020 Thanks everyone. This is my sixth build and trust me I have learned so much, my first build had loads of filler which I decided was not good so my aim is to minimise the filler and ideally use none. What next? This is the stage when I start thinking about what to build next I am tempted by the Swizzle Stick for a quick build and winter hack. I like sticks . But back to the front I think. Cowl and battery hatch to sort out. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 19, 2020 Share Posted November 19, 2020 Swizzle Stick is very quick and easy to build. Not sure about fitting a battery and motor. but I m sure that it can be done. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 23, 2020 Author Share Posted November 23, 2020 Swizzle Stick and The Ohmen ordered as Sarik have the 10% off black Friday deal at the moment. OCD? After a lot of deliberation I decided to construct the cowl the same as I did on the Ballerina. Light ply plate cut and test fitted. Now I have to make the battery hatch, before the cowl so that the cowl can be shaped to the hatch. Cheers Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 23, 2020 Author Share Posted November 23, 2020 Battery hatch frame work. Sheeting tomorrow. Cheers Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 25, 2020 Author Share Posted November 25, 2020 Battery hatch half sheeted, Cheers Steve Quote Link to comment Share on other sites More sharing options...
