Darren Posted September 3, 2020 Share Posted September 3, 2020 Is there any such tool as a mini valve spring compressor for model 4 stroke engines? To re fit the tiny collets to hold the valves in place I use a set of tweezers in one hand to compress the spring and fit the collets with the other but this takes multiple attempts and sometimes when the tweezers slip off it pings the collets across the workshop never to be found, I am looking for an easier solution to this problem. Manufactures must have a tool for this job?? Any tips or tricks would be appreciated. Thanks Edited By Darren on 03/09/2020 15:27:37 Quote Link to comment Share on other sites More sharing options...
kc Posted September 3, 2020 Share Posted September 3, 2020 I think Brian Winch covered this in one of his articles -- the one bit I remember is that you should use a polythene bag to catch the bits that fly out. Quote Link to comment Share on other sites More sharing options...
Darren Posted September 3, 2020 Author Share Posted September 3, 2020 Posted by kc on 03/09/2020 15:31:57: I think Brian Winch covered this in one of his articles -- the one bit I remember is that you should use a polythene bag to catch the bits that fly out. I have actually tried re assembling within a large grip seal bag to save loosing flying bits and parts, to be honest it just makes things even harder. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 3, 2020 Share Posted September 3, 2020 I used to refit valve collets quite a lot when I rebuilt motor cycle engines (usually vintage single cylinder engines) and, using a spring compressor (which I still have) it's not too difficult. However I can imagine trying to do the same on a 10cc engine rather than a 500cc one might be a little more tricky. There must be an easy way that people like OS use and I would guess a device to hold the spring compressed while the collets are fitted must be available. I think I'd try to hold the spring compressed by wrapping thin fuse wire round the turns and snipping it free once the collets are in place - inside a poly bad as well! Geoff Quote Link to comment Share on other sites More sharing options...
Willyuk Posted September 3, 2020 Share Posted September 3, 2020 I am just rebuilding a laser 150 v twin and have been experiencing the same. I have now done one cylinder. I placed a piece of triangular balsa inside the combustion chamber, then covered this with a piece of ply. Now the valves cannot move. I then put a small G clamp on to the ply and one side of the spring retainer. I could compress this far enough to slip the collet on one side, then slip it around to the other side and put the second collet in. I found working inside a bag impossible btw. I may try that again on cyl 2/ good luck Quote Link to comment Share on other sites More sharing options...
kc Posted September 3, 2020 Share Posted September 3, 2020 There is a thing called a jewellers apron which is some sort of apron attached to the bench and also to the person to catch things that would fall past your lap. A carpetted floor is better than a hard surface as it stops the parts bouncing away into some hidden place. The parts stay where they fall with any luck. A magnet can be better than eyesight in finding tiny steel parts. Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 3, 2020 Share Posted September 3, 2020 As willyuk suggest you need to make sure you have some sort of block for the valve to sit on. That way they stay put when you press the springs down. When it comes to pressing springs, find a small offset ring spanner that has an o/d about the same size as the collet retainer. You can use this to push down and then poke the collets in to place. Edited By Jon - Laser Engines on 03/09/2020 17:03:03 Quote Link to comment Share on other sites More sharing options...
jrman Posted September 3, 2020 Share Posted September 3, 2020 Use a large thin plastic bag such as you get with dry cleaning, not a stiff food storage type. Quote Link to comment Share on other sites More sharing options...
Darren Posted September 3, 2020 Author Share Posted September 3, 2020 Thanks for all of the info and tips, I will give the ring spanner a go, that sounds a bit better than the tweezers that I have been using. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 3, 2020 Share Posted September 3, 2020 Posted by kc on 03/09/2020 16:58:54: There is a thing called a jewellers apron which is some sort of apron attached to the bench and also to the person to catch things that would fall past your lap. One of my earliest memories is of watching my grandfather working at his bench repairing watches and clocks (he was working into his 80s). There was nothing special about his apron. It was just an ordinary white bib style but it clipped into fittings on his bench to catch any small parts that fell. I've often wondered why I didn't have the same when I've been scouring my workshop floor for some small part He died about 75 years ago when I was 5 and we lived with him and my grandmother at the shop so thanks for reminding me of a very special man. Geoff Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted September 3, 2020 Share Posted September 3, 2020 I use the ring spanner to compress the springs and then put the retainers into the valve groove with a watchmakers screwdriver with a dab of grease on the end Quote Link to comment Share on other sites More sharing options...
Glenn Philbrick Posted September 3, 2020 Share Posted September 3, 2020 I also use a small block under the valve and ring spanner to depress the spring I find using a small screwdriver that has been magnetised helps to locate the collets and prevents then flying away. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 3, 2020 Share Posted September 3, 2020 I often use a small screw driver with thick grease on the blade to position the collet on the valve stem with is also treated with tiny amount of grease to hold the collet once in place. As in other posts a block of balsa cut to hold the valve against its seat while fitting the spring and the big plastic bag . Quote Link to comment Share on other sites More sharing options...
Caveman Posted September 3, 2020 Share Posted September 3, 2020 This YouTube video shows the rebuild of an OS 52 four stroke. Building the valve into the head is shown from 5:45 Valve rebuild He makes it look very easy and quite simple!! GDB Quote Link to comment Share on other sites More sharing options...
Darren Posted September 3, 2020 Author Share Posted September 3, 2020 Posted by Caveman on 03/09/2020 21:14:40: This YouTube video shows the rebuild of an OS 52 four stroke. Building the valve into the head is shown from 5:45 Valve rebuild He makes it look very easy and quite simple!! GDB Those valves that are secured in place with circlips are pretty simple, it is the ones that are held in place with the collects that are the pain. You need three hands. Quote Link to comment Share on other sites More sharing options...
