Ron Gray Posted November 3, 2021 Share Posted November 3, 2021 If you have a Tx with it on then you don't need a PC, there is no necessity to keep upgrading versions and models can be easily built on the Tx. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 3, 2021 Share Posted November 3, 2021 I used my Taranis ans OpenTX for over a year before using Companion ap ot'a entirely practical withouf a PC. GG Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted November 3, 2021 Share Posted November 3, 2021 I agree. Companion is just a tool to make it possible to set up and test a model from the comfort of your PC chair. Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted November 4, 2021 Share Posted November 4, 2021 Companion will not play audio files unless you tell Companion where to find them in the settings ditto your jpegs . Just look in the setup and link to the files otherwise it's just blank . Quote Link to comment Share on other sites More sharing options...
MattyB Posted November 4, 2021 Share Posted November 4, 2021 17 hours ago, Andrew Calcutt said: Open tx is all very well but you need a laptop, I don't have a laptop only a pad. Well... That's not really true - if you want you can buy your TX and use it out of the box for ever without ever connecting it to anything, setting up all your models on the TX itself. True most will want to update it and play with files in Companion occasionally, but it's not mandatory. All the open source firmwares including OpenTX, ErskyTX and EdgeTX are completely FREE and created by volunteers. As such they don't have infinite resources to support every platform. From memory there have been requests from users to move Companion onto Android an iOS, but there concerns over getting the TXs connected reliably and spreading dev resources too thin in terms of ongoing support, so it never happened. Which other high cost proprietary systems even offer a PC based simulator tool as an option anyway? I'm not aware of any at this time, even the Android based Spek TXs don't seem to offer anything. Quote Link to comment Share on other sites More sharing options...
Dickw Posted November 4, 2021 Share Posted November 4, 2021 9 minutes ago, MattyB said: Which other high cost proprietary systems even offer a PC based simulator tool as an option anyway? Not relevant to the discussion, but for the sake of completeness - Jeti do. Dick Quote Link to comment Share on other sites More sharing options...
Max Z Posted November 4, 2021 Share Posted November 4, 2021 (edited) Hi all, I am relatively new to OpenTX, but I am getting on with it very well. I managed to update the OS and firmwares via the SD-card without problems. What puzzles me is that several posts here suggest that you don't need Companion for that process, but following the manual you need it to set the options, like noheli, lua scripts, etc., and only then upload the .bin file to your transmitter. Is this step in fact not mandatory, and can you upload the .bin file downloaded from the OpenTX site directly (presumably with all options accepted)? Should it not be made suitable for your specific Tx (profile)? Max. Edited November 4, 2021 by Max Z Quote Link to comment Share on other sites More sharing options...
