Former Member Posted November 14, 2008 Share Posted November 14, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Keiran Arnold Posted November 14, 2008 Share Posted November 14, 2008 What about making a short jump lead with the wires crossed over - a bit Heath-robinson but it might work Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 14, 2008 Author Share Posted November 14, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 14, 2008 Share Posted November 14, 2008 The Tx has no servo reverse Eric? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 14, 2008 Share Posted November 14, 2008 Ah, so servo reverse but not model memory then - I see nowThe newer servo reverse units are pretty small and light these days Eric. Any chance of fitting a bellcrank setup somewhere 'tween the servo output arm and the horn - probably not...cos you did say the pushrods were kinda short? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 15, 2008 Share Posted November 15, 2008 Try putting your new old gear on swapshop I knew somehow you'd have more relics out there !Seriously -Cant you fit a bent pushrod attached to the opposite side of the servo disc? Or is the space really that tight ? I agree with you in not wanting to fiddlearound in the field with setting things up -some "expert "will arrive to help distract you & make the whole business more confusing . Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 15, 2008 Share Posted November 15, 2008 Yes, but as I put, on two models the ails are correct, on the third, they are reversed! Previously, (on the Reftec) everything worked in the correct sense! There is something fishy here. If they all worked the same way on the Reftec just how can one now be reversed. That is just not logical. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 15, 2008 Share Posted November 15, 2008 Perhaps because of the physical oreienation of the servos /horns on this particular model is opposite to the other two? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 15, 2008 Share Posted November 15, 2008 But he said that everything worked with the Reftec. He implied taht the models were the same, just the tranny changed. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 15, 2008 Share Posted November 15, 2008 Thats true .Over to you Eric ! Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 15, 2008 Share Posted November 15, 2008 You could buy or swap me something for my Hitec 4 channel Tx and Rx for sale in the Swap shop Eric ???? Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 15, 2008 Author Share Posted November 15, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 15, 2008 Share Posted November 15, 2008 Phil Wood wrote (see)I assume that now you have retired the Reftec you have put another Rx into model 3 and want to run it off the skysport.If you can't alter the servo's or control horns on model 3 is it possible to alter them on models 1 + 2 and leave your Tx switched to reverse? Phil. I was just about to say that also Great minds think alike ....or is it fools seldom differ Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted November 15, 2008 Share Posted November 15, 2008 Were these servos "standard" from the beginning? Quote Link to comment Share on other sites More sharing options...
Johan Bach 1 Posted November 15, 2008 Share Posted November 15, 2008 Hello Friends, I would just ask Merlin for a little magic perhaps? It might just help, or Eric may just put a very strongly worded note on his Xmas wish list. All the best to you all, Johan. Quote Link to comment Share on other sites More sharing options...
Hamish Posted November 15, 2008 Share Posted November 15, 2008 "I can only conclude that, as two receivers are old stock, and one is new, perhaps the encoder circuit has been altered for whatever reason?"Can you swap the receivers about to a model that you can physically reverse the servo? EditDisregards as I just read your recent post Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted November 15, 2008 Share Posted November 15, 2008 Eric.Since your gear is not "new", could you have fitted or maybe could you fit a reverse sense servo. In each set of 4 servos supplied with Tx Rx, there used to be one servo which ran in reverse for exactly this purpose. The Futaba ones used to have a green ID label instead of a black one to identify it. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 15, 2008 Share Posted November 15, 2008 That is right, many old sets like Acoms came with a reverse servo.The simple answer is a label by the on-off switch on the model "Reverse Ailerons" Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted November 15, 2008 Share Posted November 15, 2008 andys dead right i have just put an old acoms set on swopshop it has three black labels and one green Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted November 15, 2008 Share Posted November 15, 2008 I still have my old Acoms 35MHz AM 4 channel set in my cupboard, sitting alongside the Futaba Medallion 3 channel 27MHz AM set Quote Link to comment Share on other sites More sharing options...
