Lucas Hofman Posted October 17, 2022 Author Share Posted October 17, 2022 Indeed it does. I find build up wing construction pleasing to look at and to work with. Foam wings are not the same. By the way, do you know how many Rans S-9 have been build after the plan was published? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 17, 2022 Share Posted October 17, 2022 43 minutes ago, Lucas Hofman said: Indeed it does. I find build up wing construction pleasing to look at and to work with. Foam wings are not the same. By the way, do you know how many Rans S-9 have been build after the plan was published? I have no idea. I only get the feedback from the forum. I know we had one in our club. there is another on the forum Quote Link to comment Share on other sites More sharing options...
lesley Posted October 17, 2022 Share Posted October 17, 2022 I built one, flys nice. Add me to that list. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted October 17, 2022 Author Share Posted October 17, 2022 1 hour ago, lesley said: I built one, flys nice. Add me to that list. Hi Leslie, good to see someone else except Peter is following my ramblings. Do you have some pictures of your RANS S-9? Regards, Lucas 1 Quote Link to comment Share on other sites More sharing options...
lesley Posted October 18, 2022 Share Posted October 18, 2022 Not at the moment, will try tomorrow and see if I can post them. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted October 28, 2022 Author Share Posted October 28, 2022 the wing is finished, ailerons are made. Time to continue with the fuselage: Planking the bottom. Aft the formers are close enough that I can get the seams on the formers. Further to the front there is more then 100mm between them, so I glue the sheet together first. Cheers, Lucas Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted October 30, 2022 Author Share Posted October 30, 2022 Milestone. The bottom is closed. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 30, 2022 Share Posted October 30, 2022 Great! Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 6, 2022 Author Share Posted November 6, 2022 Started on the cowling. From the few pictures I have from the Rans I am trying to make a lookalike of it seem the cowling is more square. That makes things easier. The hole in the cowling looks slightly bigger than the spinner. I first make a "front plate" with a hole in it that centers it on the motor and fixed that to the spinner backplate. Then the top can glues in place: Next is the bottom. If I have though everything through correctly I can then still loosen the screws that hold the cowling backplate. Fix the backplate with tape top and bottom and glue in the sides. Mark the hole around the spinner an and after removing the spinner backplate the cowling-to-be can the be slided off the motor. I will tell you if I have overseen anything..... Lucas. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 6, 2022 Share Posted November 6, 2022 Sounds good to me. It is so long ago I can't remember what I did or how. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 8, 2022 Author Share Posted November 8, 2022 Completed the sides. And yes, I did think of removing the screws holding the cowling backplate in place. Until the hole in the front is enlarged the cowling cannot slide upwards. Next is making the big hole in the front, glueing some triangle stock on the inside corners and shaping the thing. Cheers, Lucas 1 Quote Link to comment Share on other sites More sharing options...
Mr Ficky Posted November 8, 2022 Share Posted November 8, 2022 Your build looks great! I finished mine earlier this year. Enjoyed it so much I'm tempted to build another! Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 11, 2022 Author Share Posted November 11, 2022 Looks good mr. Ficky! Are those struts profiled aluminium? Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 12, 2022 Author Share Posted November 12, 2022 (edited) Yes! The cowl came off. Shaping is next. Edited November 12, 2022 by Lucas Hofman Quote Link to comment Share on other sites More sharing options...
Mr Ficky Posted November 13, 2022 Share Posted November 13, 2022 Yes, profiled aluminium. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 13, 2022 Author Share Posted November 13, 2022 Cowl sanded. 11 hours ago, Mr Ficky said: Yes, profiled aluminium. Struts are next. Mr Ficky, how did you do the ends? Cheers, Lucas Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 15, 2022 Author Share Posted November 15, 2022 I was given som profiled aluminium profile of the right dimensions. Filled the ends with thickened epoxy and hope that will be enough hold for the M2 threaded rod and the hinge. Canopy is next. Half a mm. clear plastic sheet it says in the article. But where does one find that? Regards, Lucas ps. I am also looking for Canopy locks (for the battery hatch). Neither Hobby King, Banggood or my local suppliers have any in stock. Can I make it myself? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 15, 2022 Share Posted November 15, 2022 K&S used to do streamlined aluminium tube. J. Perkins no longer seem to list it. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 15, 2022 Author Share Posted November 15, 2022 4 hours ago, Peter Miller said: K&S used to do streamlined aluminium tube. J. Perkins no longer seem to list it. I was given a big box with balsa (both flakes and lists) and some metal profiles. Among with 1,5 m of 1/2'' Al streamlined profile. Which now has been converted to 4 struts. Quote Link to comment Share on other sites More sharing options...
kc Posted November 15, 2022 Share Posted November 15, 2022 You could make a simple hatch catch in a similar manner to the one I made for the Ballerina, but instead of putting the working bits in the fuselage put the whole catch in the hatch with the 'handle' projecting upwards. Simplest of all is a dowel at front and a turnbuckle made from a bit of servo arm but it's rather ugly. Turnbuckle needs a tiny piece of very thin leather underneath to make it stiff but moveable. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 16, 2022 Author Share Posted November 16, 2022 17 hours ago, kc said: You could make a simple hatch catch in a similar manner to the one I made for the Ballerina, but instead of putting the working bits in the fuselage put the whole catch in the hatch with the 'handle' projecting upwards. That would be a possibility. I decide to have one of these printed for me by a friend: https://www.thingiverse.com/thing:3576380. He has a 3D printer but not enough to print so is always happy to get some files in the mail. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 16, 2022 Share Posted November 16, 2022 SLEC have hatch latches, various types, in stock....... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 16, 2022 Share Posted November 16, 2022 I have just bought 4 of the white sliding bolt type latches from 4-Max, couldn't find them anywhere in the UK and didn't want to wait for them to come from China Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 16, 2022 Author Share Posted November 16, 2022 You are lucky in the UK with "local" companies that stock building supplies. Not so here in Norway and ordering small amount from the UK is expensive (posting, customs fees etc.) Quote Link to comment Share on other sites More sharing options...
Ian Lennox Posted November 16, 2022 Share Posted November 16, 2022 I simply flattened the ends, bent them to the correct angle and drilled a hole for a small bolt to attach to a T nut glued in the wing. I'll post a close up photo asap. Quote Link to comment Share on other sites More sharing options...
