Peggy Sue 2
EarlyBird
and done.
Then I turned the wing over to do the bottom. 😕
Not good where the three 1/4" ribs are particularly the centre one which was something like 1/32" above the aileron spar, the same for all three between the aileron spar and trailing edge. Added balsa where needed and sanded down as required.
Then hid it all with the centre sheet so no one would know.
Bottom cap strips next.
Steve
  • Like 2
Cap strips done and trailing edge along the centre section between the ailerons. This made it time to tackle the first wing tip.
I laminated balsa as on the LE and wrapped it around onto the aileron TE then added the aileron TE. Thanks for the idea @Ron Gray. Worked well and not difficult at all. The other tip to do then LE cap strip which will be shaped and the tips rounded to match.
Well pleased with that :classic_smile:
Steve
  • Like 3
Thanks John, I will take that as a complement 🤣
There is a reason for the pile of unfinished models, indecision.
Been practicing making joints.
Plenty of good practice because only two pieces are the same length and angle.
It usually looks better when glued and sanded, lets hope so 🤣
I need to make decisions about the engine fit with regard to the position of F1 as I need to move it back 15 mm for the prop and spinner to be in the same position as on the plan. If I move it should I move it further and by how much to achieve the plan CoG? To give everyone time I will either finish Hound Dog or start Basic 3D. I could finish these side frames though, good idea I will continue with the joint practice.☺️
Steve
  • Like 2
All parts made for one side.
Glue next or cut the parts for the second side?
I have been thinking about the engine fit. It will have to be side mounted and moved back up to 50 mm. 25 mm sounds good to me 😕
Also I have two other models I could use it in and by pure coincidence they both have 3548 motors, and underpowered IMO. Another consideration is that the FG11 needs running in. Too much to think about and so I will keep building as the plan and make a decision when I absolutely have to.
Who said building was easy 🤣
Steve
Ply doublers added and F2 glued.
Then indecision struck again so started something that had been waiting and added to the pile of wings.🤣
Feeling guilty I returned to this build.
Battery location on F4 set up.
Holes drilled for cable ties.
Then F3 and F4 glued in place
That wasn't hard as no decisions were required.
Steve
Personally I wouldn’t bother but if you’re going to put some in (from memory Peter doesn’t) I would suggest a max of 2° downthrust and 1° sidethrust. My Peggy Sue 2 (electric) hasn’t got any and flies just fine.
Edited by Ron Gray
I never use side or down thrust.  The original smaller Peggy Sue that has been built in the club doesn't have any.The big one that was built in the club doesn't have any.  The one flown in a howling gale on the Peggy Sue thread thread and which was described as "Out Wot Fouring a Wot Four and Out Acro Wotting an Acro Wot. Didn't have any....But of course with your vast experience you may know better!!!!!
  • Haha 1
That's just the point of asking, I have very little experience. It was a request from an instructor, my understanding was that he would prefer side and down thrust for beginners to fly straight and level hands of, something to do with building confidence. Why adding down and side thrust enables hands off straight and level flight is beyond me.
Interesting about Peggy Sue because he flies one and loves her. I will ask him again.
Thanks
Steve
