Another TN 50mm Hunter
Lipo Man
I’ve been building foamboard models for a couple of years, and they’ve been an excellent way to get from novice to sort-of-competent flyer. So time to try a balsa model now I’m not expecting to destroy it immediately!  For good measure I thought I’d do my first EDF. I guess I’m about halfway through the build and so far it seems to have gone smoothly. Very clever design - a really simple structure. Looking forward to seeing it finished!
  • Like 4
3 hours ago, Paul De Tourtoulon said:
That's some quick building, I suppose you were up at the crack of dawn to start it ,.
If only I was that quick!  This is over evenings for the last week or so.  I am sure some folks could do one of these in a day, but I'm enjoying savouring the experience!
17 hours ago, Richard Acland said:
I am sure TN has shares in a balsa wood supplier. Most of his designs seem to involve big lumps of balsa that require lots of planing. When I built the fuselage of his 72 inch Spitfire Most of the wood ended up in shavings on the floor.
I am building his FW190A which came as a free plan in a Special edition.
My thoughts around the sections used is much the same so I am using the plan as a basis and removing all the slabs of balsa - preferring to use formers of the correct shape and then sheeting with 1/16" balsa. I will let you know the outcome but I am hoping to halve the weight.
I see where you are coming from, but for a first time balsa builder like me the simplicity of the approach paid off. I don’t suppose my carving and sanding was the best but the model looks OK and flies really well, and that’ll do for me!
Here is a photo of the “finished” model (is a model ever finished?). Decals are inkjet printed onto clear waterslide decal paper, with white vinyl circles (hand cut with the kitchen scissors!) behind the roundels to cover the yellow of the fuselage. Pleased with the end result as it’s my first balsa model and first EDF.
https://youtu.be/p8U8kIKjJ_U
  • Like 5
