Gaz Elliott Posted December 9, 2008 Share Posted December 9, 2008 Hi guys what is the best 2.4 spektrum or futaba?? Also can you use other rx for a specific brand as per 35meg? e.g. an Align rx with a futaba rx ( In 2.4)finally some of the shops advertise some of the 2.4 rx as for full size models yet other state that they are for indoor or park flyers what is the true view?? Quote Link to comment Share on other sites More sharing options...
winchweight Posted December 9, 2008 Share Posted December 9, 2008 Futab 2.4 ghz tx can only use futaba 2.4 rx. Spetrum / JR are interchangeable. I have a JR DSX9 and use Spekky rx not problem. I went JR/ Spekky because the rx are much cheaper than the Futaba ones.Some rx are for park fliers, and others have full range for bigger models. The bigger ones have better aerials to improve the range, the park fliers only have small aerials.If you do go 2.4 though, buy some 6v rx batteries as they are very sensitive to low voltage. There's loads of info on this site, have a read. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 9, 2008 Share Posted December 9, 2008 Spektrum is best.... unless of course you think that Futaba is Quote Link to comment Share on other sites More sharing options...
Kelly Posted December 9, 2008 Share Posted December 9, 2008 I have a Futaba, no problems with it so far. .Nothing wrong with the Spektrum,I would buy one .It's up to you,look on the respective web sites and read up on the specifications and decide which would suit you best.If unsure post the type of flying/models you are interested in and see what other people think.In the end they both do the same jobRegardsKelvin. Quote Link to comment Share on other sites More sharing options...
birdy Posted December 9, 2008 Share Posted December 9, 2008 If you ask me, its all about which one you find nicer to say: hence why I use Futaba. I don't like the letter k - it is evil. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 10, 2008 Share Posted December 10, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Marshall Posted December 10, 2008 Share Posted December 10, 2008 Me to just bought the Futaba 2.4 6ch I was very impressed with what you got for the £130 I spent and refreshed my trainer with all the new gear! Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 11, 2008 Author Share Posted December 11, 2008 Rightly or wrongly i have bought a Futaba set . Hopefully arrives today or tomorrow. Will spend week end lock in the hangar repair all the fleet from the problematic Tx/ rx on 35meg . 3 flights first landed just wing ripped out, changed crystal, second flight landed damage steering after rollercoaster flight, change rx, thrid flight damaged fus and prop. Conclusion problems with TX soloution 2.4, Need to stop the dodgy landings. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 11, 2008 Share Posted December 11, 2008 Ive just bought a 2nd Spectrum to buddy box my first which I have been happy with Quote Link to comment Share on other sites More sharing options...
Ian Nelson 2 Posted December 14, 2008 Share Posted December 14, 2008 I have been using Spektrum since April 2007. Best decision I made. Easy to use , simple to set up, gives greater confidence when flying. 35 MHz..................what's that ? Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 14, 2008 Share Posted December 14, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Richie P Posted December 16, 2008 Share Posted December 16, 2008 i bought the spectrum dx6i only because the futaba offered came in at £134.95 with servoes i don't need , so at £89.95 i just saved money that will go on something else Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 16, 2008 Share Posted December 16, 2008 Webbies at Frodsham, will do a deal to omit the servos if desired, on the Futaba 6exp. Not quite as cheap as the Spektrum.But then again the the Futaba, has 6 model memories and some mixing options, which I think the Spektum does not have, or not as extensive (could easily be wrong on these statements).It is good to see that Webbs, are flexible in these times and are trying to deals, whilst trying to stay in business, which I really appreciate and hopefully ensures they stay the course.Erfolg Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 16, 2008 Share Posted December 16, 2008 Nope...the DX6i has 10 model memories..... and also has more free mixes than the fuby. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 16, 2008 Share Posted December 16, 2008 Hmmmmmmmmmmmm, wrong again! How can this be? Sacre Bluer, Oh eky thump, Got im Himmel.Have bought the Futaba though.Just a little miffed that receivers are £67, although delightfully small..Erfolg Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 16, 2008 Author Share Posted December 16, 2008 Me to on both counts.I am familiar with Futaba and seemed a good easy to use model hind sight i thought perhaps I should have got the spektrum as the blade 400 and cx are on this as are the vapor etc and I could have saved and got bind and fly! ( Well hind sight is the best sight!!) Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 16, 2008 Share Posted December 16, 2008 see... told you guys ....Spektrum is best.... unless of course you think that Futaba isTo rub salt in the wound..... the excellent tiny full range 5 channel AR500 DSM2 receiver is only around £35 Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 17, 2008 Share Posted December 17, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted December 17, 2008 Share Posted December 17, 2008 Quote Link to comment Share on other sites More sharing options...
Ian Nelson 2 Posted December 17, 2008 Share Posted December 17, 2008 I am flying a Hangar 9 80" Mustang with a Spekky AR9100 power regulator Rx with 4 remote Rxs. I plugged in the Spekky flight log at the end of each flight and have had no fades at all. I would have never invested in such an expensive model on 35 Mhz. In my 27 years flying radio I have seen too many glitches and unexplained crashes, including my own. 2.4 has certainly given me the full security to invest more in my modelling. Sure some people will criticise that it is quirky in its set up. However, follow the basic rules, Rx positioning, battery power etc and you cannot go wrong(!!?). Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 17, 2008 Share Posted December 17, 2008 Wow, 4 remotes Ian - you really dont take chances do you !I agree with all you say. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted December 18, 2008 Share Posted December 18, 2008 It must look like one of these! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 18, 2008 Share Posted December 18, 2008 Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 18, 2008 Share Posted December 18, 2008 Having purchsed a Futaba 6exp, I have now read that not all Futaba FASS receivers are compatible with all their 2.4 transmitters!It seem I have potentially made a poor purchase, if this is the case?On the brighter side (for me) it seems that the Spektrum is limited to 40 sets operating at any one time. Dammmmmm, there are only 5 of us at the field at any one time. Do not tell me that Futaba is limited to 10, then i will go into a serious depression. As I am clinging onto a straw, that my purchase is not totally crass.Does the Futaba have the low voltage problem that seems to plauge USA modellers with Spektrums?I realy needed to have done more effective research, before reaching my decision.Erfolg Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 18, 2008 Share Posted December 18, 2008 What receiver have you get there Erfolg old chap? I thought my old R606's would not be useable with my new FF10 ...but they are so all might not be lost for youI've not heard of any Futaba low voltage issues along the lines of the Spektrum ones. Quote Link to comment Share on other sites More sharing options...
