White Self Adhesive Trim.
Hi all, I’m currently restoring and old glider from the early eighties - a Veron Vortex.
I’m hoping to recreate the original colour scheme predominantly Orange with White stripes. I’ve purchased the iron on Orange film, however I’m reluctant to replicate the white stripes with iron on film - it would be a bit of a waste as the stripes really are not that big.
I’m looking for some ideas for a white gloss, thin self adhesive material (not too thick) it doesn’t need to be fuel proof. What have others found successful? Must be able to cut to size etc and easy to apply.
I’ve used Solartrim in the past, however that appears to be a bit thin on the ground - especially white.
Have you looked at car shops like Halfords - not sure if it is still a thing, but back in the day they used to sell all sorts of self adhesive trim lines and go faster stripes.
Alternatively go a DIY or craft place and buy some sticky back plastic (like Fablon) - it’s usually on a roll so you’d have to cut the strips yourself but the advantage is that you can choose whatever shape and width you want.
Something like this maybe
https://www.amazon.co.uk/4R-Quattroerre-10452-Stripes-Adhesive/dp/B08BHZH3MZ/ref=sr_1_19?crid=2FGU97LWP6HNY&keywords=Adhesive+car+trim&qid=1690266223&sprefix=adhesive+car+trim%2Caps%2C97&sr=8-19
Remember to put it down using soapy water so that you can position it.
Cheers,
Nigel
Edited by Nigel Heather
23 minutes ago, Ron Gray said:
Isn’t it a bit thick Paul?
I understand what you are saying Ron, however there can be a bit of a trade off with thinner material (wrinkles) etc.
Funnily I have some of that ‘white sign’ material that Paul mentions - I was looking at it the other day.
I’ll probably do the thinner stripes with the Trim Line product.
Thanks for all the advice.
