Winter projects
Daren Cogdon
I did wonder, as I've not used it a great deal before (being more used to hot glue on the FT Spit).
I did try the hot glue on a few scrap pieces, and it seemed pretty strong.  I tried a few longer pieces sandwiched together (as if I was doing the wing), and it was quite solid.
4 hours ago, concept2 said:
Hi All..
Sorry for the slight hijack… is this 5mm foam from B and Q suitable for our models, and laser cutting?
https://www.diy.com/departments/vitrex-classic-5mm-foam-laminate-solid-wood-underlay-panels-9-76m-/5011204608997_BQ.prd
thanks
chris
Yes Chris, this is made from mostly the same stuff
Graham
1252149773_spit10012402.thumb.jpg.b463e6a020720b25f4842dc7380c6636.jpg160066074_Spit01012401.thumb.jpg.6e9e3f44de720cfcc7f6fa5b681e30a7.jpg
  • Like 3
So, a while back, I accidentally found a website for a company called J-Wings, who do a small range of foam kits in a similar fashion to Flite Test.  And yes, they do a Spitfire kit.  Naturally I bought it!  Think it's about time I started putting it together....
Hi Chaps, can I add my little project.
It's intended as a follow-on club project after the spitty contest last year.
The idea is to use the same kit we used for the spitty i.e. the value electronics kit. Of course there will be difference, for starter there are 4 SG90 servos, the motor I'm recommending is the 2212-1000kv instead of the 1400kv motor. Of course, being a glider, it needs a folding prop and a speed controller with break function, which unfortunately will add a little to the cost of parts.
Once we have a good few of these built, the intention is to do a comp with timed motor run (20 second ish) and then glide. Longest glide wins, with extra point for spot landing.
This is the prototype, It's flow a couple of times so far, and it's flies really well, and now we have an ESC with a break the glide is better than I ever expected. Can't wait to see how see preforms when there is some thermal activity.
  • Like 2
  • 4 weeks later...
So, for various reasons, my winter projects haven't quite gone according to plan!
That said, I have built something - it's based on the J-wings Spitfire kit that I had (which, sadly, fell to bits!), but I have no idea what power setup it will now need!  I made it from 3mm Westfoam-type material.  Wingspan is roughly 30ins.
  • Like 3
