Winter projects
Daren Cogdon
17 hours ago, Nigel Heather said:
Nice - where did you get the plans for this - or is it your own design?
The original Thunderbob was a 70cm Depron lightweight model.
http://rc-plans.com/catalog/item432.html
I increased the plan to 1100mm wingspan, and constructed it out of 5 and 10mm foamboard from Amazon.(£25 for 5 sheets delivered).
All edges shaped, filled and rubbed down.
Used a 240v and 3s Lipo powered glue gun throughout.
It was painted by hand in Farrow and Ball green emulsion I got from the local dump (where most of my modelling paint comes from).
One coat of hand applied, water based satin polyurethane varnish (again from the dump).
The Ailerons are controlled by two new mg 17g servos, with plastic spoons cut in half and painted black to provide suitable covers.
Control surfaces are hinged at the top only by wide reinforced tape.
4s powered, weight circa Lb4.
It could be constructed in a week, but as I was enjoying it so much.............took a month!
  • Like 2
Due to our patch resembling a lake, I have only managed a couple of test fights so far.
Absolutely no vices at all, and for once no trim needed.
Early days, but its definitely a keeper.
I get more enjoyment out of models like this, than my £350 jets which spend most of their time in the hanger!
Getting there, I need to have it built by the end of the weekend! Not too sure about the nose, I know that it’s a ‘cartoon’ replica but I could probably have put a bit of an inwards curve on it. Still, it’s only the prototype so I’ll leave that until I’ve seen how well or bad it flies!
  • Like 3
