Neddy Posted February 13, 2024 Share Posted February 13, 2024 I have down loaded the program but it won't connect to my transmitter. My transmitter is an E Fly 4channel . According on my transmitters instructions it says connect lead to micrphone jack on computer. But the instructions on Phoenix says connect to USB outlet on computer. The USB lead I am using is a SuperSim set to Phoenix but its not working. Looks like I will have to get a special adaptor lead. Oh well it's only money. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 13, 2024 Share Posted February 13, 2024 (edited) Do you have the transmitter manual Ned that shows calibration? As there is a whole load of joystick calibration to do, and may help you get it working. Edited February 13, 2024 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 13, 2024 Share Posted February 13, 2024 If you see messages telling you no transmitter is detected, you're unable to calibrate. Is your Supersim 'lead' just a dongle that is a usb connector at one end an a mini phono jack socket at the other? That's what both dongles I have had are like... The cable from the tx plugs into the mini phono socket. A picture of the SuperSim lead may help us to help you. 1 Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted February 13, 2024 Share Posted February 13, 2024 To connect the Tx to the computer you need a USB dongle like this https://www.ebay.co.uk/itm/403145328219?chn=ps&_ul=GB&_trkparms=ispr%3D1&amdata=enc%3A1QItok7gcRge7JohypBab0w26&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=403145328219&targetid=1647205089520&device=c&mktype=pla&googleloc=9046449&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205089520&abcId=9300866&merchantid=419708514&gad_source=1&gclid=Cj0KCQiAw6yuBhDrARIsACf94RUeHMDx2qt2tV7W2JCFk87u4tZLmayeWapAMjNdLw5V7u-H9KWmvHoaAiT7EALw_wcB The dongle is connected to the Tx using a lead with a 3.5mm jack plug, the other end plugs into the trainer socket of the Tx (various types of socket are used by different manufacturers, it may be a 3.5mm jack socket, it may not). If your Tx doesn't have a trainer socket you're out of luck unless you can find a wireless dongle that uses the same communication protocol as the transmitter. 1 Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 Here's a picture of simulator ,lead and back of my transmitter with socket showing Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 Instructions of transmitter say I can plug directly into microphone socket of computer and transmitter Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 Manual of transmitter say I can plug direct into microphone socket on computer but I am running windows 8.1. All information and pictures on transmitter configuration is Windows 7. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 13, 2024 Share Posted February 13, 2024 One end of your Phono lead goes into the USB dongle, the dongle then goes into the computer USB socket Then the remaining Phono goes into the back of your transmitter Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 It is connected as described message say Phoenix does not recognise my USB interface Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 I have checked my computer device manager and the USB is connected and configured for computer. The light on my dongle flashes when all connected and transmitter turned on Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 13, 2024 Share Posted February 13, 2024 Right Ned The transmitter should be fully charged, but not switched ON. The transmitter is always switched OFF The transmitter comes ON when the Phono is plugged into it. The computer uses just the sticks of the transmitter and does not need the RF board live. Quote Link to comment Share on other sites More sharing options...
Caveman Posted February 13, 2024 Share Posted February 13, 2024 Neddy, I have exactly the same dongle as you, which works perfectly with Phoenix. First thing, the sliding switch MUST be in the 4. Phoenix RC4 for the dongle to work with Phoenix. I am running Phoenix on Windows 10, but previously ran it on Windows 7 Denis says that the transmitter should be switched off, but that is not necessarily the case - for my FrSky Taranis it needs to be switched ON in order to work with Phoenix. I may be able to help if you, but I need to have a look at a couple of things tomorrow - I'll be back! GDB Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 13, 2024 Author Share Posted February 13, 2024 Thanks it is on the Phoenix setting. When I plug it into computer the light comes on on the dongle If I turn the transmitter on the light flashes. Does the dongle need the dongle DVD to activate it. I haven't got it. Could that be the problem? Quote Link to comment Share on other sites More sharing options...
James Green2 Posted February 14, 2024 Share Posted February 14, 2024 With my transmitter, it has to be switched on to work. Quote Link to comment Share on other sites More sharing options...
Caveman Posted February 14, 2024 Share Posted February 14, 2024 Hi Neddy, no, you don’t need the DVD. I assume that you’ve downloaded the Phoenix files from RC-Thoughts.com and installed them following their instructions? GDB Quote Link to comment Share on other sites More sharing options...
Caveman Posted February 14, 2024 Share Posted February 14, 2024 Neddy, I've been doing a bit more investigation. The nearest Art-Tech transmitter manual I can find is for the EFlyETB4 : EFly ETB4 User-Manual-1006698.pdf Is this very similar or the same as yours? The manual mentions connecting the simulator port on your transmitter to the mic port on the computer exactly as you describe. It than goes on to give instructions for the setup of Windows, followed by the installation and running of the FMS Flight Simulator. See here FMS Homepage (modelsimulator.com) Therefore it could be that your 'simulator port' is only compatible with this particular set-up - I really don't know - or it could be possible to connect it to Phoenix. There may be others on the forum that can advise you further. At the end of the day you could download the FMS simulator (which is compatible with Windows 😎 and follow the instructions and get that running. GDB Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 14, 2024 Author Share Posted February 14, 2024 Thank you for your investigation. I have found out the problem. I checked the lead with multimeter using ohms it must have a break in it. I replaced the lead with another lead and it started to work. After setting the various gimbal settings I was able try flying an aircraft. It's a good thing you get another plane to fly after crashing. I think my longest flight would have been about half a minute. I kept losing site of the plane and couldn't tell which way the plane was. Had a good laugh. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 14, 2024 Share Posted February 14, 2024 In settings Go to Ground in view, and tick that Now fly Quote Link to comment Share on other sites More sharing options...
Caveman Posted February 14, 2024 Share Posted February 14, 2024 Ah! Good news Neddy. Have fun! GDB Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 18, 2024 Author Share Posted February 18, 2024 One problem that I have is using this on my laptop is my screen is only 15inch and too small and I soon lose sight of the plane. Plus I have a problem with being able to make out the way the plane is sitting. I will be connecting my laptop to a bigt screen TV using a HDMI cable hopefully this will improve my sight problem. Just wondering is Phoenix 6 any better than the 5.5 as far as graphics go? Quote Link to comment Share on other sites More sharing options...
Jake Bullit Posted February 18, 2024 Share Posted February 18, 2024 You can scale up the size of the model to make it easier to see. Quote Link to comment Share on other sites More sharing options...
