Glenn Stevenson Posted December 19, 2024 Share Posted December 19, 2024 Hi, I am putting an escale seafire together and have some plastic parts need gluing onto the wings, ie wheel wells etc, What glue works best to stick plastic to oracover? Thanks Glenn Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted December 19, 2024 Share Posted December 19, 2024 I don't 'do' electrics, but on IC nothing will keep them there other than fixing / bolting them to the legs. 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 19, 2024 Share Posted December 19, 2024 2 minutes ago, Paul De Tourtoulon said: I don't 'do' electrics, but on IC nothing will keep them there other than fixing / bolting them to the legs. Wheel Wells? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 19, 2024 Share Posted December 19, 2024 (edited) Glenn, I would cut back the oracover and use Uhu Por to stick the wheel wells to the bare balsa. I assume it's balsa being covered with film. Edited December 19, 2024 by Eric Robson 1 Quote Link to comment Share on other sites More sharing options...
Ernie Posted December 19, 2024 Share Posted December 19, 2024 Its not a good idea to stick anything to oracover or any other covering film; because the strength of the joint is only as good as the strength of the oracover glueing it to whatever is underneath. And that's not very much. Strip the covering off where the glue is going to go, and stick directly to the structure.............................. Use 30min epoxy ernie Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted December 19, 2024 Share Posted December 19, 2024 24 minutes ago, Eric Robson said: Wheel Wells? Opps, just woken up,,    Hot glue will do it,,   sorry, my silly french side coming through.🤢 reading and not understanding what I am talking about,,  I have left the barn door open for 'you know who',,🤣 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 19, 2024 Share Posted December 19, 2024 A new club member brought a balsa built motor glider to the field, as he was preparing for flight the rudder horn came off. He asked if I had any superglue, when I looked he had stuck the horn straight onto the film covering, no screws in it, he didn't fly that day  1 1 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted December 19, 2024 Share Posted December 19, 2024 Jon Bon jovi - Living on a Prayer 😧 1 Quote Link to comment Share on other sites More sharing options...
Glenn Stevenson Posted December 19, 2024 Author Share Posted December 19, 2024 Thanks for the tips, looks like epoxy might be best then. Glenn Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 20, 2024 Share Posted December 20, 2024 Cut back Oracover and glue to balsa, AÂ flexible glue will be best IMO and allow slight movement . A rigid glue like epoxy is likely to cause ABS to crack . 2 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 20, 2024 Share Posted December 20, 2024 2 hours ago, Engine Doctor said: Cut back Oracover and glue to balsa, A flexible glue will be best IMO and allow slight movement . A rigid glue like epoxy is likely to cause ABS to crack . As no foam is around ordinary UHU is fine more flexible and less messy than epoxy. Or any contact adhesive but you have to get it right first time. Quote Link to comment Share on other sites More sharing options...
