Craig Spence Posted March 6, 2009 Share Posted March 6, 2009 Hi all, I was wondering if anyone could explain the difference between two and four stroke engines, more so in performance. Ive read recently that two strokes are more powerfull but when looking at prices four strokes cost more?, im looking at buying a new plane, which I love and want to give it everything lol!, so some advice would be greatly appreciated. Cheers all. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 6, 2009 Share Posted March 6, 2009 Craig, I've deleted the duplicate thread - you don't want to split the answers you'll receive. It's a good question but I just wondered what model are you thinking of getting? Quite often the type of model will suggest the engine type you see. Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted March 6, 2009 Author Share Posted March 6, 2009 Hi David, I will be getting the CMPro Lancair, it has the option of two or four stroke. Cheers David. Quote Link to comment Share on other sites More sharing options...
andy watson Posted March 6, 2009 Share Posted March 6, 2009 I will leave the technical difference to a more knowledgeable engineer, but here is my more pragmatic differences- as they relate to which should I use? You have it right- 2 stroke- cheaper, more powerful, sound like a wasp! 4 stroke- more expensive, less powerful, sound like a cat purring! So for me, if you are building a scale model the extra effect of the 4 stroke is worth the increased cost (the lower power is often irrelevant because you end up sticking in a bigger engine to get the same end power). Scale models are about slow low passes and looking gorgeous, and a 2 stroke can let them down in that respect. If you are wanting to buzz (literally) around the sky as fast/high/spinny as possible, then the 4 stroke becomes pointless, and better to cram as much power as cheaply as possible in the front with a 2 stroke. That distinction works for me. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted March 6, 2009 Share Posted March 6, 2009 Andy, I think is dead on, not that I would know much, but after using my 2 stroke heli, the 4 stroke just sounds perfect! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 6, 2009 Share Posted March 6, 2009 To add to the thankfully non too technical answers so far... think of the fourstroke as better at swinging larger props slower ( which is much more efficient anyway ) and the 2 stroke as high revving but having less torque or "grunt" at lower RPM. Four strokes can by their design be slightly higher maintenance type, as there are valves to adjust occasionally ( well tappets to be more accurate ) no biggy, but they do have many more moving parts than the beuatifully simple design of the 2T Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted March 6, 2009 Share Posted March 6, 2009 The previous answers are a good guide wiyhout being techy. The Two stroke has a power stroke every 2nd stroke hence the name. More Power at a cost of some wasted fuel compered to,,,,,,,,,,, The Four stroke has a power stroke every 4th stroke, it is more efficient for fuel use, tends to be quieter and sounds better to most folk. It is heavier than the 2 stroke which can be a plus point on a model with engine/s mounted close to the wings or one which would need a lot of lead up front for balance. A larger size, .70 instead of a .46 or.53 two stroke is required. Quote Link to comment Share on other sites More sharing options...
thomas oliver 1 Posted March 6, 2009 Share Posted March 6, 2009 Craig, To answer the technical part of your question, this is how they work:- Four-stroke: 1. INDUCTION STROKE- Inlet valve beginning to open at top dead centre--Piston moves down cylinder and causes air to be sucked through carburettor, picking up fuel until valve closes just after bottom dead centre. 2. COMPRESSION STROKE -- Both valves are now closed--piston moves up cylinder compressing the mixture. 3. POWER STROKE-- Just before top dead centre, a spark occurrs igniting the mixture which burns and expands forcing the piston downwards- both valves still closed 4 . EXHAUST STOKE -- Exhaust valve now opens and upward moving piston pushes the burnt gases out of the valve. TWO-STROKE ENGINE:- Initially the piston moves up and suction in the crankcase fills it with fuel mixture, ase then the piston moves down compressing the mixture in the crankcase and forcing it up a transfer port into the cylinder. This might be called the priming phase. The two operative strokes now occurr-- 1. COMPRESSION -- the piston moves up compressing the mixture and at the top of the stroke the plug or spark plug ignites the mixture. 2. POWER- the expanding burning gas forces the piston down. The exhaust escapes through the exhaust port towards the bottom of this stroke. Note that while 1. is happening, a new charge is being drawn into the crankcase, and while 2. is happening, this charge is being compressed ready for transfer and a repeat of events This is a slight simplification of events. Tomol. Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted March 6, 2009 Author Share Posted March 6, 2009 Thank's for the info fella's much appreciated, I think ill go with the two stroke. Even though I want the four stroke, it's just too expensive really and I cant justify spending the money just because it sound's better (i know there are more benifit's than just sound, as laid out in this thread). I might look for a second hand four stroke. Cheers all. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 9, 2009 Share Posted March 9, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Malcolm Keen Posted March 27, 2013 Share Posted March 27, 2013 I have two Saito and two OS four strokes and in some situations I have them fully enclosed within a cowl. My question is how can I best protect them from deteriation because I can't get after run oil into them or can I ? Any suggestions gratefully recd. Many thanks Malcolm keen. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 27, 2013 Share Posted March 27, 2013 Which models are they Malcolm.....? Your best bet is a squirt of after-run oil into the breather (put a bit of tube on so it reaches outside the cowl) if the engines have one. The latest OS motors have internal breathers though so that kind of wrecks that idea. Another option is to arrange a length of brass tube so it exits just over the carb mouth.....again extend this tube so you can get at it from outside the cowl & then use this to introduce a bit of after run oil into the carb.....this should then find its way to the crankcase. Not as good as squirting it in via the breather but your only option I'm afraid. Also make sure you use a fuel with synthetic oil & ensure you "run the engine dry" at the end of a flying session.... HTHs Quote Link to comment Share on other sites More sharing options...
ceejay Posted March 27, 2013 Share Posted March 27, 2013 whilst not wanting to get technical here i have another question on the same subject, i have often wondered why the model 2 stoke is deemed to be less tourquey than a 4 stroke, i dont know how it works at smaller engine sizes but in my past life i road motorcycles and my sport was trials, and if we wanted tourge and lots of it a single cylinder low reving two stroke was the man for the job, and if you needed hp that comes from high revs a four stroke was your engine of choice, as a four stroke will rev far far higher than a two stroke, F1 is the ultimate user of extreme high revving 4 strokes, so now i fly larger models and what do we use 2 strokes, and they can be tuned to turn huge props chris Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 27, 2013 Share Posted March 27, 2013 Well I think you've put your finger on it Ceejay...it comes down to how the engine is "tuned".....you can have torque-y 2 strokes & screaming high rev 4 strokes...or vice versa....depends on valve/port timing....dimensions (under or oversquare)..... For two similarly tuned engines though a 4 stroke will generally be the more torquey as a) the cylinder filling is more efficient & b) the "power stroke" of a 4 stroke is longer. Basically the 4 stroke cycle is just more efficient & extracts more energy from the fuel....where the 2 stroke scores of course is in its lighter weight...useful in trials bikes & aero engines.... Quote Link to comment Share on other sites More sharing options...
John Olsen 1 Posted March 28, 2013 Share Posted March 28, 2013 OK, a curious thing about the weight of two strokes and four strokes...My son and I recently put an OS 56 four stroke into a Hangar 9 Sundowner 35, for which the recommended engine is an Evolution 46 two stroke. As part of the research we checked the weight of the two engines...according to the advertised figures the OS is slightly lighter than the Evolution, desite having more capacity. I suspect that the OS has an ABC type of liner, while the EVO probably has a steel or cast iron liner...but anyway, in that particular case the four stroke, being larger, has about the same power, is no heavier, and will use less fuel. So the all up weight for a given flight duration will be less, especially if longer flights were needed. Mind you, shoehorning the OS into the cowl was not a trivial exercise. It is taller, so we mounted it sideways with the head and barrel coming out through one of the side cheeks. Works fine but it is not easy to assemble and disassemble. The resulting model flies really well, the four stroke sound is deceptive since it does not sound all that fast...but it is actually going along pretty quick. John Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 28, 2013 Share Posted March 28, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
MikeS Posted March 28, 2013 Share Posted March 28, 2013 Intresting read this thread. I always understood the four stoke principle and hows things work. However I never understood the two stroke principle until this thread. I can tune a four stoke better as I understand how it all works. I myself prefer four stokes in my models. I like the sound, look and power. However my P40 has a two stoke in it and when in flight it sounds much better than a four stoke would due to how the P40 flys. Most of the time it goes like a scalded cat. Mike Edited By MikeS on 28/03/2013 16:39:48 Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted March 28, 2013 Share Posted March 28, 2013 four stroke, suck, squeeze,bang, blow. two stroke, sucksqueeze, bangblow, simples Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted March 28, 2013 Share Posted March 28, 2013 Phil Are we talking engines? Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted March 28, 2013 Share Posted March 28, 2013 i was, myron. mandy says two strokes are too quick Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted March 28, 2013 Share Posted March 28, 2013 Phil I must agree with Mandy . Speed/diameter/pitch/angles of attack /etc at our age means nothing IMHO Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted March 28, 2013 Share Posted March 28, 2013 And 4-stroke requires more care and maintenance ........but the scale need them.... Quote Link to comment Share on other sites More sharing options...
stu knowles Posted March 29, 2013 Share Posted March 29, 2013 I've never been a fan of four stroke motors, Expensive, reduced power, prone to throwing props. I don't buy into the noise somehow being 'better' as neither sound remotely like any full size aeroplane that I've ever heard. Two stroke, simple and reliable. Fly with small diameter prop for high speeds or oversize for noise sensitive sites or WW1 / vintage. Tried both but don't own any four stroke motors at all now. stu k Edited By stu knowles on 29/03/2013 09:14:22 Quote Link to comment Share on other sites More sharing options...
Malcolm Keen Posted March 29, 2013 Share Posted March 29, 2013 Hi Steve Many thanks for your input here. One model is a scratch built Mew Gull with an OS 72, one is a World Models Midget Mustang with an OS fs110 and the other is a magnattila with a Satio 56 (old) like me. If they haven't totally gummed up because of the dam weather I will try to put this advice into action. regards Malc Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted March 29, 2013 Share Posted March 29, 2013 i have four strokes, two strokes,one wankel,one petrol and loads of electric motors, i like to play and fly with all of them Quote Link to comment Share on other sites More sharing options...
