Bjorn Posted March 27, 2009 Share Posted March 27, 2009 Hello, my name is Bjorn and I live in Norway. In september last year I started to build a 1:9 scale Lancaster from Nijhuis plans. Progress has been good and I am almost done with the "put together woodwork", only missing sheeting of the nacelles and cowlings. I have done some modifications from the original plans on all control surfaces to make them more scale in appearance and added flaps. It will be built as a MkIII with the conventional bomb bay and markings will be 550 sqd BQ-B "The phantom of the ruhr". Power will be provided by four O.S .56 FSa four strokes. More pictures in my album Last mockup of the Lanc Edited By Bjorn on 27/03/2009 20:10:19 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 28, 2009 Share Posted March 28, 2009 Hi Bjorn and welcome. Looks like a nice job you're doing there Keep us posted with progress. Quote Link to comment Share on other sites More sharing options...
Bjorn Posted March 28, 2009 Author Share Posted March 28, 2009 Thank you will do so Quote Link to comment Share on other sites More sharing options...
Bjorn Posted April 9, 2009 Author Share Posted April 9, 2009 More work done. The nacelles and cowlings are coming together I made a small jig to hold the front plate while building the sides of the cowling Getting there, the right wing has got ruffly shaped cowlings Edited By Bjorn on 09/04/2009 23:28:00 Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted April 9, 2009 Share Posted April 9, 2009 lookin' sweet! good luck! Wish i had enough money for four os 56s!!! Quote Link to comment Share on other sites More sharing options...
Sheldon Holy Posted August 21, 2009 Share Posted August 21, 2009 Wow, very nice! I to wish i could afford those engines Sheldon Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 21, 2009 Share Posted August 21, 2009 I've often thought about building a multi-engined model but but have always baulked at the process of getting four engines running the same! How are the throttles connected, is there a servo for each engine or one between two? If it was one each would you use something like the JR Matchbox to drive them? Also, how is the fuel supply set up, one tank each or one between two? Knowing my luck by the time I'd got number 4 running, number 1 would be out of fuel! Quote Link to comment Share on other sites More sharing options...
Bjorn Posted September 5, 2009 Author Share Posted September 5, 2009 The throttles will be controlled by one servo each and will be connected to separate channels on the radio. This way it is quite easy to do adjustments on each motor. Fuel will also be one tank per motor Last thing done now is that servos is being installed into the left wing. First testing of the flaps http://www.youtube.com/watch?v=JUj5wcnYxlU Quote Link to comment Share on other sites More sharing options...
Bjorn Posted September 5, 2009 Author Share Posted September 5, 2009 landing lights coming together Quote Link to comment Share on other sites More sharing options...
Dusty Posted September 5, 2009 Share Posted September 5, 2009 Very nice! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted September 16, 2009 Share Posted September 16, 2009 Bjorn,what is the wing span? Quote Link to comment Share on other sites More sharing options...
Bjorn Posted September 18, 2009 Author Share Posted September 18, 2009 Wingspan is 3.4 meter or 134" Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted September 19, 2009 Share Posted September 19, 2009 Thats big Bjorn Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted September 19, 2009 Share Posted September 19, 2009 Have you bought a bigger car to fit it in yet? :P Quote Link to comment Share on other sites More sharing options...
Bjorn Posted September 20, 2009 Author Share Posted September 20, 2009 Yes it is quite big and my car is getting a little small for this bird, but in theory it should fit into my Renault Laguna stationwagon. The wings split at the fuselage sides and I have made the stab so it is easy to remove the fins. The whole unit is detachable from the fuselage, leaving a 2,3 meter fuselage (balsatube more or less) without anything that takes up width. So if I put the wings at the bottom and hang the fuse in the roof it should be ok Quote Link to comment Share on other sites More sharing options...
Terry Whiting Posted October 19, 2009 Share Posted October 19, 2009 Very good pictures of your build Bjorn, you must have those landing lights working ! Keep at it , and please keep us posted. Edited By Terry Whiting on 19/10/2009 21:00:19 Quote Link to comment Share on other sites More sharing options...
Bjorn Posted February 15, 2010 Author Share Posted February 15, 2010 Some progress on my project, fuselage is now glassed and bomb bay doors cut from the fuse. Trying to figure out how to install the servos for the doors, think that two forward and two aft will do. This is a test with two servos, look ok http://www.youtube.com/watch?v=R2l4tPv-pFM Quote Link to comment Share on other sites More sharing options...
Dusty Posted February 15, 2010 Share Posted February 15, 2010 Wow this is going to be one hell of a model! When do you predict to finnish the build? Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted February 15, 2010 Share Posted February 15, 2010 Posted by Dusty on 15/02/2010 20:48:23:When do you predict to finnish the build? Its going to finland? :P Quote Link to comment Share on other sites More sharing options...
Bjorn Posted August 5, 2010 Author Share Posted August 5, 2010 Assembeled for the first time at the flying club. Did some engine adjustments and some taxi trials, so all the loose bits could fall off. and they did ofcourse And what a sound from four .56 fourstrokers, pure music Maiden next, hopefully next week Edited By Bjorn on 05/08/2010 16:30:11 Edited By Bjorn on 05/08/2010 16:32:02Edited By Bjorn on 05/08/2010 16:37:30 Quote Link to comment Share on other sites More sharing options...
Terry Whiting 1 Posted August 5, 2010 Share Posted August 5, 2010 Well done Bjorn, I was beginning to think you had abandond the project, but pleased to see it in it's raw state. What is the AUW at the moment.? Quote Link to comment Share on other sites More sharing options...
Bjorn Posted August 5, 2010 Author Share Posted August 5, 2010 Thanks Terry AUW is 27 lb now but it needs a small lb of lead in the nose to be on the CG marked at the plans. It will be in this state for the rest of this season, getting a little bit familiar with the english lady before doing the last details and painting. Maiden will be in the beginning of next week if the weather holds Quote Link to comment Share on other sites More sharing options...
Terry Whiting 1 Posted August 6, 2010 Share Posted August 6, 2010 Sure hope the weather holds for you Bjorn, Tony Nijhuis always maidened his 'ladies' in their undressed state . If she flies as her smaller counterpart, you will have no problem. Quote Link to comment Share on other sites More sharing options...
Bjorn Posted August 12, 2010 Author Share Posted August 12, 2010 Successfull maiden today She really flies beautifully, this was my first attempt on four engines and the biggest plane for me so far. I am really surprized that a plane of this size is so smooth to handle, and quite responsive on all controls as well. Will link up a video soon Quote Link to comment Share on other sites More sharing options...
Terry Whiting 1 Posted August 12, 2010 Share Posted August 12, 2010 Congtatulations Bjorn on your maiden flight. Now it's down to the finishing job.. Looking forward to viewing your videoEdited By Terry Whiting 1 on 12/08/2010 17:00:41 Quote Link to comment Share on other sites More sharing options...
