Fuel tanks
I'm at the stage of trying to find a tank for my latest build but i'm not having much luck finding one which i think will be large enough that will fit into the space i have.
I'm going to be running a super tigre 61, but the largest tank i can find to fit is an 8oz. I haven't run the engine yet so don't know what sort of run time that will give but i don't think it will be that long.
The tank needs to be less that 107mm long to fit between the formers and less than 53mm tall and 73mm wide to fit through the former to be removed if need be. Its the length that is really restrictive and I can't leave the tank in the hole in the former as this would leave the clunk sitting around 3" below the carb level. If i could get a tank the exact size i need it would be around 12 - 13 oz, but theres never exactly what you need.
I'm a bit stuck which way to go. I've read about dual tanks which could be an option run in series but it adds complexity and could be a pain to fill, although i'd have ample room for 2 6oz or 2 8oz tanks side by side.
Is there any other solutions anyone could think of? I can't cut the former to fit a tank because its the former where the wing dowels locate.
Thanks chaps, its hard to describe the angle so i drew a quick pic.
So you can see if the tank was aligned with the bung in the hole in the firewall and the back of the tank was still in the hole in the former the tank would be at an angle which is why the clunk would be 3" lower. Although as you deduced the top rear of the tank will be about 1/2" - 1" below the carb line. I can widen the hole in the former but can't make it taller due to the location of the wing and wing dowels.
I'm a bit stuck where to go with this.
Thanks Jim,
Interesting idea. The wings on this are foam core and already joined and glassed, but i may beable to get away with just taking the leading edge off. Although it all depends on how it lines up with the location dowels, as there are 2 for the wing and 2 for the canopy.
Rob
edit:  Just had a quick look and the dowels for the canopy would get in the way.  Back to the drawing board.
Edited By Rob.. on 28/07/2011 11:49:16
Sorry PatMc, i guess i'm used to looking at it so it looks normal to me.
Its a side on view of the nose area. The vertical line on the left is the firewall, with the hole for the bung shown as the dotted lines.
The other vertical line on the right side is the former, with the dotted lines depicting the hole in the former.
Everything to the right of the former is the fuselage side and the wing seat as its a mid wing plane.
Rob
Is it not possible to accept a smaller tank?
I guess you have mentioned the size of the motor, although i cannot see it.
To an electric flyer 1/2 lb of weight seems quite a lot. I guess for IC modellers the trim change is not an issue.
Another thought, I have seen many years ago, a sketch of how two tanks were installed in a Vulcan. A smaller tank was fed by a larger tank. Could this approach be viable?
Thanks Erfolg. Think i said in the first post but its a 61 size engine so will guzzle the fuel, and i'm not too sure about the run time i would get from a smaller tank, but it may be the last resort. I've seen about using 2 tanks and i think thats probably what i'll try.
There seems to be a couple of ways to do it either a main tank with a header, similar to the way i believe its done in helis, or 2 of the same tank piped in series which will probably be the way i'll try mounted side by side. It means there will be a slight lateral trim change but both tanks will be near the centreline so i'm hoping the change won't be big enough to notice. I can always stick one smaller tank in at a later date if i have troubles with it.
Rob,
This doesn't help your immediate problem, but is just a thought that was triggered by your thread:
As a camper I use collapsible poly water bottles than can be crushed down for packing into the car. Fill them with water and they pop out again. I just wonder why no-one has manufactured a fuel tank based on the same concept. It could be crushed/squeezed and generally pummelled to fit into awkard spaces. The only problem may be the odd wrinkle left in the tank sides, that may affect the smoothness of the clunk, so these would have to come in various sizes so that a 'near fit' could be achieved.
How do I contact the patents office - this could be a winner!
Edited By Steve Houghton on 28/07/2011 17:51:49
Steve, the idea isn't new. The first proper control line stunt model (circa 1958) I made & flew, a KK Stunt Queen, had a tank made from a toy balloon. It was housed in a balsa compartment just behind the engine & accessible for filling via a simple hinged hatch on the side of the fuselage.
The tubing between tank & engine was joined by a short brass tube & of course there was no need for any vent or clunk.
I had an AM35 diesel in my model which meant that I had to make a new tank every outing as diesel fuel rotted the balloon but this wasn't a problem for glow engines.
The illustration is taken from the 1959 edition of Ron Moulton's Model Engine Encyclopaedia.
Posted by Jim Carss on 28/07/2011 19:15:39:
Giving your age away now Pat.
Age has it's advantages, Jim. Polite young people occasionally give up their seat in a packed Metro & hold doors open etc.
But I expect you'll have already experienced that.
Posted by kc on 28/07/2011 19:23:10:
Have you considered eliminating the dowel by using 4 wing bolts instead of dowel & 2 bolts? This might enable you to cut the former for tank access.
A better idea might be to cut away the wing LE as Jim suggested & glue the overwing fuselage fairing to the wing with the dowels fixed to the fairing at a point above the tank.
Thanks for all the replys everyone.
Flexible tank, sounds good, if there was one that was the right size, definately onto a winner there Steve. The ones i've seen on jets have all been long bags, almost like a drip bag used in a hospital that holds no air so shrinks as the fuel is withdrawn, but then i believe they all use pumps.
Using 4 wing bolts would work, although a fairly major modification would be needed to the fairing to allow it all to match up.
Unfortunatey i can't really attach the overwing fairing to the wing as the angles don't really equate for getting the wing in and out due to the amount of space (or lack of). The plan actually had the wing and fairing all as one piece but when i offered it all up it was too tight to get everything together and apart so i made the canopy removable.
I guess i have taken the 'easy' route and went to the LMS today and brought 2 smaller tanks that will fit in the space available. I'm going to run some tests with the tanks linked in series and parallel and see how well the system works. With them in series there will be a slight lateral imbalance but i don't think enough to be concerned about. Having them in parallel will solve this problem but could be difficult getting them both to drain at a constant rate. I can't really see a problem this way and theres no modifications that need to be made to the plane to get them to fit. I'll let everyone know what i decide on but thanks for all the help.
  • 2 months later...
Hi Rob,
On one occasion when I couldn't get a tank to fit I made one out of sheet steel from an old 5 litre oil can, easier to make than you would think. Two square end caps with a small lip tapped over right round and one strip formed into a square tube all soldered together. Nicked a clunk from an old tank and a bit of silicon pipe withstood the soldering ok. Still got it somewhere, I'll see if I can post a pic. It was about 6 ounces capacity and it was not very heavy (little bit more than a comparable plastic one but not much).
To correct the height difference is it possible to invert the engine (sorry can't see your sketch, it no longer displays).
Shaun.
Cheers Shaun,
I ended up fitting 2 smaller tanks and running them in series, so the exhaust pressure goes to the feeder tank and feeds the main tank. I've run a couple of tanks through and it works fine. Engine is side mounted because i'm using a pitts muffler so couldn't have moved it.
Heres a pic of what i ended up with.
Rob
Edited By Rob.. on 16/10/2011 15:11:46
