Pete Crosby Posted June 25, 2014 Share Posted June 25, 2014 Big slab of RTV silicone that was poured into a large paint tin lid (5ltr) left to cure..then pulled out to leave a nice round slab that won't stick to any thing. Now makes a wonderful glue mixing plate..epoxy eat you heart out just bend when finished to remove the hard glue.. ( I used RTV left over from making a mould... ) you can buy small amounts from sculpting supplies... Edited By Pete Crosby on 25/06/2014 21:53:21 Quote Link to comment Share on other sites More sharing options...
MaxG Posted June 26, 2014 Share Posted June 26, 2014 Cotton buds used to paint fuel proffer/polyurethane varnish/sanding sealer/dope in places where finish is not important. For example inside cowls on ARTFs that are not fuel proofed or where you need to stick "sticky velcro" on to wood and wish to seal it first. Throw away when you have finished. Cheaper than thinners to clean a brush. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 26, 2014 Share Posted June 26, 2014 THose plastic covers for pet food tims also make excellent epoxy mixing trays Quote Link to comment Share on other sites More sharing options...
Mowerman Posted June 26, 2014 Share Posted June 26, 2014 Glass shelf (ex bathroom) packing tape can be stuck on then cut to shape as required for decorating models,The tape can then be peeled off and transfered to model wothout loosing stickyness. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 26, 2014 Share Posted June 26, 2014 Posted by Peter Miller on 26/06/2014 08:35:39: THose plastic covers for pet food tims also make excellent epoxy mixing trays also the clear top on Whiskers anti-hairball and Dentabit cat treats make good mixing plates and also make a low-walled constraint for small screws etc to stop them disappearing off the top of the bench. Quote Link to comment Share on other sites More sharing options...
Richard V-D Posted June 26, 2014 Share Posted June 26, 2014 Another vote for coffee stirrers plus those little waxy paper cups from the likes of golden arches. Ideal for small amounts of epoxy, and can be used again, once the first batch of epoxy has gone off. (not that I'm tight or anything!) I have also used a bit of garden hose to increase the reach of a small screwdriver/hex spinner. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 26, 2014 Share Posted June 26, 2014 Mixing pallets, free also works with Argos, Wickes etc Mix it, tear off, throw away John Quote Link to comment Share on other sites More sharing options...
Fredrum Posted July 2, 2014 Share Posted July 2, 2014 I buy cheap open-weave non-slip mats from the supermarket. They are quite soft and are good for having on the bench to prevent hanger rash. Quote Link to comment Share on other sites More sharing options...
Mowerman Posted July 2, 2014 Share Posted July 2, 2014 Cat litter- great for soaking up spilt fuel.and oil inside modes, workshop and garrage. Also see my post under Fuel soaked engine bay. Edited By Mowerman on 02/07/2014 17:11:17 Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted July 2, 2014 Share Posted July 2, 2014 Broken props ( though probably not wooden ) make brilliant epoxy resin mixers and also applicators. If not scratched you can re-use a few times as the hardened resin should come off when you flex the blade. For mixing I recycle greeting cards, appointment cards and the like, most of us should have an inexhaustible supply of these, just don't let SWMBO bung them into the recycling. Quote Link to comment Share on other sites More sharing options...
Martian Posted July 2, 2014 Share Posted July 2, 2014 plastic credit card sized gift cards make great filler applicators use whole or cut up to best size ,all sorts of round objects of different sizes ca sandpaper or whatever you use ,foam board makes great small sanding boards glued on with UHU por Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted July 2, 2014 Share Posted July 2, 2014 yes ,like the health lottery cards on the lottery stands in shops Quote Link to comment Share on other sites More sharing options...
Chuck Plains Posted July 3, 2014 Share Posted July 3, 2014 Most things from Poundland or 99p Shop. And I think I mentioned elsewhere, cheap thin non stick cutting mats from kitchen shops. £2.99 for 4 different colours at The Range Oh yes, a lathe! Ok, I know it's technically a tool, but I just bought one and can't wait for it to be delivered at work next week. Quote Link to comment Share on other sites More sharing options...
Martian Posted July 3, 2014 Share Posted July 3, 2014 the stainless steel support tube from solar lights sharpened make excellent hole borers ,indeed anything that can be sharpened of any size. Quote Link to comment Share on other sites More sharing options...
