Acrowot takeoff & landing
PeD
I have recently aquired a Kit built Acrowot and finding that it takes a fair length to unstick from Mother Earth. (Grass bumpy)
The Acro. does not have the original undercarriage but is fitted with a heavier thicker "plastic" type and the wheels look to be further forward and lower than pictures of the ARTF version.
The height of the center of the spinner from ground level is 200mm
undercarriage measured at the fixing bolts 105mm
and the tail measured at the hinge line of the rudder 65mm.
Is it too low or too parallel to the ground?
Engine is a SuperTiger 61, running on Southern Modelcraft 10% nitro
with synthetic and castor oil. 11*71/2 prop.
Elevator and aileron settings I've set from the ARTF manual.
In the sky it tracks perfect with very little trim reqd. At just less than 1/2 throttle it "bats" along quite quick.
Being more used to heli. flying, I also find it lands at a fair lick as well and needs all the available runway we've got. This could of course be my inexperience in landing this type of plane and fearing a low speed stall. An experienced colleague has flown it and he also brought it in very quick. I was advised to turn the tickover down a tad which I've done. But it still seems very fast to me to land.
Are the above symptoms normal for this plane or is there something slightly out of kilter in the setup?
Regards
Peter
Hi PeD
I have just maidened my Acrowot this last weekend. I did notice that it goes a lot further than my Wot 4 when taking off but once its in the air it is superb. It is the ARTF version with an SC91 pulling it. My Wot 4 will take all of in two feet of runway on full throttle at take off. Not very scale but fun all the same.
I found that running a smaller pitch prop helps when landing. I have a 14 X 6 on my acrowot and it lands nicely within the boundrys of the pitch. I run a 13 X 4 on my wot 4 as it is quite hard to get down in the space available when there is little head wind to help slow the model down. The smaller pitch creates less waft when the engine is at idle allowing the model to come in slower.
hope this helps
Dean
Posted by PeD on 18/09/2013 22:47:10:
Do you mean the bottom of the rudder hinge line? If so, that sounds very high and would mean that the angle of attack of the wings is very low which would indeed, result in a high take off speed.
PeD - you say it takes a long time to unstick - are you waiting until it decides to become airborne on its own? This is OK as a take off technique - but depending on the model it can indeed lead to very long take off runs. Some aircraft need to be "rotated" to get up.
All other things being equal lift depends on two things; speed and angle of attack. If the model naturally sits with a small angle of attack, or if you are letting the tail come up so it sits horizontally (which is the "correct" method), then you will need a lot of speed to get enough lift to become airborne. The problem with this is that models experience a lot of drag when on the ground - remember a model going along a typical grass strip will be like a full size aircraft trying to take off in 3 foot high undergrowth!
If you "rotate" by squeezing in a bit of up-elevator once the speed has built to a reasonable level, you should become airborne fairly easily. The increased AoA giving you a bit of extra lift. Once in the air, and free of the drag of the grass, the model will build speed more rapidly and you can feed out the elevator. Obviously it's important to exercise some judgement with this! Put in the elevator too early and the model will be too slow to fly! Overdo the elevator and you run the risk of stalling the wing. But its easy enough to develop the feel of when and how much!
BEB
hello peter...change the prop as suggested and give it a bit more umph...in the take off...it should really jump off the ground.......landing-if the tickover is too high the aircraft will want to fly-and no amount of stick twiddling will make it land.....so back off all together on the power once the aircraft is straight and level on the landing appproach....have a try at some dead stick landings-this will help in your power on landings......you should find the A/Wot has no nasty tendencies.......and will float in....
ken anderson....ne....1 ......umph dept....
I think people are used to seeing models leap into the air after putting the throttle to max and two feet of rolling then throwing the model up at 45 degs
horrible
models used to fly with a lot less power than most people use nowadays meaning a longer roll out was needed.
I try to deliberately make my take off roll out long and climb up at more scale like angles. Controlling a tail dragger along the floor with the tail flying can be very satisfying
Thanyou for all the replies :
"Martin"
The measurement is at the rudder vertical hinge. The Acro. came to me without a tailwheel just a non original aluminium bkt without the tail wheel. The original mount fixing holes look as though the tail would have been lower. So perhaps me adding a wheel assembly to the bkt. has compounded the problem.
"Dean"
I see in the Super Tiger 61 manual it will go too 12*6 or 7. So that maybe worth a try.
"Beb"
I've not tried a "shorter" takeoff as it just does not feel like it wants to lift off until I've almost run out of runway. The speed accross the grass seems adequate for it to lift.
I'll try giving it a bit more "welly" accross the grass. The Acro. came from club with a lot longer runway than mine, so maybe not a problem for them and a long takeoff was normal. I'll make enquires re-that.
"David" I will take it up higher next time out to see where the stall is.
"Andy" The c.g is slightly forward (3 1/4 +- 1/4) .This probably down to the non standard undercarriage. I thought I'd leave the c.g forward initially to make sure it was at least flyable.
Will test some of the replies on the next outing, weather permitting.
Thanks again
Peter
With my kit built acro powered with an OS AX 55 and 12x6 prop I fly it so slow it actually stops flying and just sits there before going into a flat spin, it is virtually impossible to stall this plane so on landings it should come in at a fast walking pace, I do flat turns using full rudder and opposite aileron at virtually zero airspeed, much more fun then full throttle flying.
This plane has a massive flight envelope, explore it and have fun.
Darryl
Edited By Djay on 19/09/2013 09:30:52
I always flew my glow Acro with a 12x5 on an Irvine 53. My Electric Acro flies with a 13x6.5 on 1100 watts. thes are both built as the chris foss kit. I find an Acrowot has to be flown in so it will have more speed than a Wot4 for example.
Edited By Glyn R on 19/09/2013 09:41:03
The first AcroWot I had, years ago, was fitted with a Enya 50 helicopter engine, not the largest in the recommended range. Never had any problem taking off at all. But I did think at first that I couldn't land it satisfactorily, probably because I was not letting it slow down enough. As a result I kept knocking the undercarriage off.
I then learned to slow it down before the final approach!face 1
If it is set up correctly it will be easy to land if you give it a chance to settle.
My second, electrified AcroWot takes off in about ten feet, probably because of the greater torque available from rest...................face 23
The take off technique has been outlined pretty well above but regarding your floaty landings, the Acrowot is a slippery model with a relatively high wing loading so it will respond poorly to the all too common "cut the throttle and point the nose at the runway" technique.
Something rarely appreciated is that a model flies fastest - and essentially slowest - with full throttle. Before you dismiss this as a ridiculous statement, think of a 3D model in the hover or a harrier - the airspeed is close to zero but the throttle will be close to or actually wide open unless the model has a more than 1:1 power to weight ratio.
Translate this to a more normal landing approach and you'll find that the most manageable condition is with the nose somewhat higher than in a power off glide and enough throttle to maintain a steady descent, balancing the increased drag from the higher angle of attack. This will mean in practice that you either have to hold in a little back pressure on the elevator - or you could adopt full size practice and re-trim for the correct attitude.
If you find that you're beginning to undershoot, don't pull back on the elevator - nudge the throttle open a little. The airspeed won't increase significantly but the sink rate will decrease. If you're overshooting, close the throttle a bit (see why we aim to approach with a little power?) and the sink rate will increase BUT not the airspeed, which, as long as you hold the approach attitude will stay almost static until you go into the flare and landing hold off.
The chop and glide method does work relatively successfully with lightweight models and typical trainers but once you move on to the likes of Acrowots and WW2 scale models you'll find that the technique above will give you much more rewarding approaches and landings. There's an almost magical feel when you have a model "locked in" to an approach and you adjust the glide angle with use of the throttle, almost like there's a physical connection with an invisible string suspending the model...
Edited By Martin Harris on 19/09/2013 14:26:31
Posted by Bob Cotsford on 19/09/2013 11:53:05:
Is the tail coming up on the take-off run? My kit-built Acro needs a little up held in to stop it nosing over because the tail comes up almost as soon as it starts to roll, and then it needs a touch more up to unstick.
The tail has not come up on any takeoffs so far. Again this maybe I've not given it enough "ummph" to start with.
"Martin" thank you for this type of landing approach. I'll try this at height along with the stall and find out more what it's going to do.
I've been a bit cautious, as I've had to do a couple of dead engine landings with it. The last 2 flights out, after another carb. clean (nothing found) it flew as on rails with no engine probs. All the electrics,tank and tubing were changed before it's first flight.
It is the heaviest plane I've flown so far and flying helis' as I normally do doesn't help in the take off and landing of planes, it only helps when it's up there.
Lots more practise with it (weather permitting)
Again thanks for the replies.
Peter
HI Peter
My old kit built Acrowot with an OS 55 didn't suffer from any of the problems described above...and whilst Martin's explanation on landing with power on is first class & correct I have to say that my model was quite happy on a cut and glide landing pattern and we have loads of trees to get over at our patch so it had to be quite steep at times...
Perhaps the C of G does need moving back slightly..but be careful not to go to far.
Enjoy!
Jon
I've watched this thread with interest, my original acrowot (brown printed instructions!!) had several engines before I settled on a saito 82 with a 14x6 prop.
Dead stick you could hear it whistling as it flashed up the strip but with the saito on tickover it flew very slowly indeed.
Getting the angle of attack right took some time as I wasn't sure what attitude to hold. After several sessions I found that if I held the model in an attitude that resembled that of a three point landing then I could perform the landings as Martin Harris described but it took me a while to become comfortable with it.
This paid dividends as I then practised that on a WM midget Mustang that previously tried to fly into the next county on landing but became a real pussycat with practice.
As always practice a little high until you've got the hang of it and also check out the stall speed at that attitude.
The other thing that makes for a fast landing is excess weight coupled with a forward c of g. I have heard that the artf weighs 6 pounds up, dependent on engine. I'm pretty sure mine weighed around 5 lbs with the saito in and I used a heavy alloy spinner but the c of g was at the rearmost point recommended and may even have been a few mm behind that, CF certainly gave a safe and useable range for that point. Anyhow I certainly had no problem getting it to spin.
  • 1 month later...
I just rekitted my electric Acrowot. The original Chris Foss kit is very strong when glassed but is a bit heavy so will land and take off quite fast. I was taking off (in a flying comp) for my second flight when it tip stalled into the ground from about 10 feet. The fuse is probably repairable but I may build a new one and try to keep it light rather like the ARF. The foam wing is only slightly damaged so will be re-used. I must finish my Super Chipmunk before the rebuild can start.
Acrowot
This is my Glow version but the electric one is identical
My Acrowot reversed back into the ground a few years ago, I think that might have been just a little too windy that day. Not being in a very good mood I used the wing to bridge the mud puddle at the field entrance where the cows gathered. I subsequently stripped the wing, found zero damage, recovered it and carried on using it for another year or so. It's very hard to kill an Acrowot, even without a glass finish.
To take off with a tail dragger, hold full up elevator, open the throttle until the model starts to roll forward, open the throttle to full and return the elevator to neutral. At this point the tail should lift, wait until flying speed is obtained and rotate. If the tail does not lift its likely either the main wheel axles are too far forward or the main gear is too short. Axles should be in line or slightly ahead of the leading edge at the wing root when the fuselage is parallel to the ground.
I find that (don't have an acrowot but it should still apply) taking your time on take off and building up enough speed on the strip before rotation helps. Obviously, if you are too slow on take off and then pullback a stall is bound to happen(there are better people than me to explain it but I understand the principles). Don't pull back too much on take off let the lift on the plane do most of the work.
As a rule of thumb 1/2-2/3 of the wheel showing beyond the LE when looking from above.
