Chips with everything
Nev
Well maybe not everything but I am expecting this to take up most of my building and thinking time for quite a while.
I always liked to paint my AIRFIX pilots and was very proud of my wheels when I found that buffing the mat black paint with pencil lead gave a good rubber tyre look, it also added that bit of weathering in the form of exhaust stack stains. But that is about the extent of my scale detailing.
Like many others I started aero modelling in my early teens with control line models and a brief but unsuccessful attempt at RC with a KK mini Super. Then the almost inevitable 30 year layoff, until a welcome return to modelling a few years ago now. Having revisited the mini super ( MK2 flier very nicely) and having found that I do like a good project to get into, this chipmunk build looks like a great way to learn some new skills. Also the fact that it is a joint build is a big attraction as I think it will help enormously to keep the enthusiasm going, I found that out with the mass builds.
I have slowly been acquiring a few bits, nice shiny motor, some wheels, just to get things started and I already have a 5S, Lipo pack so that’s practically a Sign !! So today I placed my order for plan, wood pack, canopy and cowl. Roll on October.
Nev.
I did originally post a photo of another Chippy in the main thread as my chosen subject, a nice black job, very smart. Having thought about it though I have settled on this one. I think if I am going to put the effort in to add some scale detail I want it there for all to see and this version will show of the detail better than an all black paint scheme.
My only other "fun scale" model is an AT6 Texan from RBC kits. A nice build I enjoyed very much but I didn’t add any detail (apart from the pilot of course, that’s him on the left) and the paint scheme is only an approximation but it looks great in the air. So how far do we go with this one, well I want it to be practical, so no fine detail but cockpit certainly, panel lines yes, navigation lights trim tabs etc. yes, rivets No, but I would consider larger panel fasteners. Basically it has got to stand being handled and not take forever. Not that I actually know what I am talking about with any of this stuff but we will see.
Nice clean scheme that one Nev, you better get that red stripe straight, I will be checking
Sorry to upset but only domed rivets available in the bottle, needless to say there arent many flush rivets on a Chipmunk.......
However Tony's blown canopy version may have a few more flush ones than ours wink 2 But he is a glutton for punishment teeth 2
Danny
  • 3 months later...
I’ve never been in the ATC, of have links with any particular Chipmunk. So I thought it would be fun to make up a little mascot, just so I have a sight of the finish line.
Well that was a bit of a shock, I used to be able to make a pretty reasonable job of these, or so my memory tells me.
First thing I found out, my eyesight isn’t as good as it used to be and the second is I need to brush up on my painting skills. Still I think it will do for now, maybe I will revisit the painting later but we will see.
PS. I get the new reading glasses on Saturday.
What no balsa !
I don’t get a lot of time to build, maybe an hour or so white the soaps are on. I was going to start with the tailplain but realised I was soon going to need the hinges, so spent the time cutting them out with a dremel and cleaning them up. (should have done this earlier).
I didn’t have 10 BA screws but did have 2mm ones so drilled them out at 2mm, a nice free hinge and I think it still has plenty of meat around the hole. Then I notice 4 of the hinge pieced are about 1mm wider that the others, which is the one I drilled a test hole in. Still it’s a start.
Well done nev, perhaps i should have mentioned the 10BA bolts before hand. If anybody is looking for some Macc models is a source I use. In case you haven't figured it out the set of 4 hinge plates that are slightly wider are for the Rudder, the other set of eight are for the elevator. Don't forget to lock the nuts, you dont want them coming loose!
I cut my hinge parts free as i need them with an old razor saw, makes light work of the job and is less agressive than a spinning disk, well at least its safer in my hands!
Danny
If I'd looked earlier I would have seen the 10BA bolts myself. Model fixings have 1.6 mm ones, I'll get some of them and re drill the other end of the hinge. The wider rudder ones can stay at 2 mm. I have thread lock.
Edited By Nev on 01/10/2014 21:45:28
Balsa at last. I had already decided on Terry's Christmas tree approach, I'm sure I've seen it done like this before somewhere.
The ribs are thin and you need the patience of a saint. I used alphatic which was also thin to took an age to dry. another thing is you run out of blocks and things to hold the ribs while they dry. Still it's all finished now although I admit in the end i did resort to some small filets and CA to keep everything in place.
While I was waiting for the ribs to dry so i could do the next batch, I made one of these.
The wire is a tad thick. 14 swg would have been good but I didn't have any so went for the next size up. Its not heavy though, less the 10g.
probably wont get anything done tomorrow but will try and finish the tailplain at the weekend.
Nev.
Edited By Nev on 02/10/2014 21:34:57
