David Davis Posted October 6, 2014 Share Posted October 6, 2014 Hi everybody! The trusty Laser 90 in the "works" Senior Telemaster is in need of an overhaul. I am going to fit a new bearings and a new piston ring. I used to have a print-out giving detailed instructions on the valve timing, or perhaps more correctly, the cam timing of Laser engines. I'm blowed if I can find it now and I've trawled the internet to no avail. Anybody able to help? Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted October 6, 2014 Share Posted October 6, 2014 www.laserengines.co.uk cam timing is there. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted October 6, 2014 Share Posted October 6, 2014 www.laserengines.co.uk/Camtiming.htm Quote Link to comment Share on other sites More sharing options...
David Davis Posted October 6, 2014 Author Share Posted October 6, 2014 Thank you Braddock. Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 6, 2014 Share Posted October 6, 2014 There is also a thread on here called the laser appreciation society. I posted details of timing for both singles and twins Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted October 6, 2014 Share Posted October 6, 2014 Hi If you set the cams "on the rock" at TDC then it will be fine . On the rock is when inlet is just opening and exhaust is just closing . Hope it helps . Quote Link to comment Share on other sites More sharing options...
Stevo Posted October 11, 2014 Share Posted October 11, 2014 I'e assembled a few... follow the instructions and diagram as has been mentioned. I've never had a problem! Quote Link to comment Share on other sites More sharing options...
trebor Posted May 29, 2018 Share Posted May 29, 2018 Posted by Braddock, VC on 06/10/2014 07:34:42: www.laserengines.co.uk/Camtiming.htm Have you tried this link. http://www.laserengines.co.uk/Camtiming.htm any one got details of cam timing as I could not find it on the Laser site. Edited By trebor on 29/05/2018 13:52:34 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 29, 2018 Share Posted May 29, 2018 If you use the Internet Wayback Machine or similar, you can often find deleted website information such as this: **LINK** Hope it's useful! Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 29, 2018 Share Posted May 29, 2018 good grief that old site was awful. For anyone who wishes to remove their cams please take a photo of them before you remove them from the engine. Its good practice and will make refitting a doddle Quote Link to comment Share on other sites More sharing options...
trebor Posted May 29, 2018 Share Posted May 29, 2018 Posted by Martin Harris on 29/05/2018 14:30:46: If you use the Internet Wayback Machine or similar, you can often find deleted website information such as this: **LINK** Hope it's useful! All I get is a Timed out notice. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 29, 2018 Share Posted May 29, 2018 Just take a photo of the cam positions before you remove them. That's what I did earlier this year when I overhauled (ie cleaned and fitted new bearings) an old Laser 62. Photographing stuff before taking it apart is one of the boons of digital photography. Geoff Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 29, 2018 Share Posted May 29, 2018 Odd - still working for me - try copying/pasting http://web.archive.org/web/20130726222157/http://laserengines.co.uk/Camtiming.htm Edited By Martin Harris on 29/05/2018 15:33:27 Quote Link to comment Share on other sites More sharing options...
trebor Posted May 29, 2018 Share Posted May 29, 2018 Tried that, still no good. Took a screen shot but its a PNG file and I dont now how you can change it to jpeg to load on here. We need a banghead smiley. Quote Link to comment Share on other sites More sharing options...
trebor Posted May 29, 2018 Share Posted May 29, 2018 Bingo. If I click on the blue line it goes to a SKY website, ,if I click on the bottom one it goes nowhere Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 29, 2018 Share Posted May 29, 2018 Try a different browser? Here's a screenshot of the relevant part of the page: Quote Link to comment Share on other sites More sharing options...
trebor Posted May 29, 2018 Share Posted May 29, 2018 Thanks mine just comes up with network problems connecting to host whatever that means, I hate computers. Quote Link to comment Share on other sites More sharing options...
trebor Posted May 30, 2018 Share Posted May 30, 2018 Ok, Which one is correct Left or Right ? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 30, 2018 Share Posted May 30, 2018 Going by ED's guidance, the right hand one looks correct (I assume they are both at TDC) but the best way to check is with a degree disc on the crankshaft and using the info from the old Laser site I posted - but Jon might be able to confirm by eye? Quote Link to comment Share on other sites More sharing options...
trebor Posted May 30, 2018 Share Posted May 30, 2018 I think you are right, Ill soon find out Quote Link to comment Share on other sites More sharing options...
Ace Posted May 30, 2018 Share Posted May 30, 2018 Like Martin I think its the RHS on a small capacity Laser. The LHS looks to be 180' out between exhaust/intake. Where is Jon hiding when you need him Quote Link to comment Share on other sites More sharing options...
trebor Posted May 30, 2018 Share Posted May 30, 2018 The left hand was out one tooth on each cam. I can confuse myself really easy Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 30, 2018 Share Posted May 30, 2018 its really hard to tell from the photo as the picture is taken at an angle. The left engine is wrong but I think the other one is ok Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 30, 2018 Share Posted May 30, 2018 Just had a closer look. I think both are wrong, and im also pretty sure neither are at tdc as the pinion drive is not in the right place Quote Link to comment Share on other sites More sharing options...
trebor Posted May 30, 2018 Share Posted May 30, 2018 I hate to have to say this but these are not the easiest to set up Quote Link to comment Share on other sites More sharing options...
