Rich too Posted April 23, 2016 Author Share Posted April 23, 2016 I decided to swap the heavy u/c for better c/f version. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 23, 2016 Share Posted April 23, 2016 thats my boy......... ken anderson...ne...1 welll done rich dept. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted April 23, 2016 Share Posted April 23, 2016 Nice tidy job there Rich. Yup, carbon fibre is the way to go despite the cost. The metal ones get bent with slightest bouncy landing and are a pain to bend back. Additionally, they are never the same again. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 23, 2016 Share Posted April 23, 2016 Looks better Rich John Quote Link to comment Share on other sites More sharing options...
Rich too Posted April 25, 2016 Author Share Posted April 25, 2016 Thanks guys, its slowly getting there, two steps for, one back at the moment ! I have another issue. The wing is held in place by four M6 bolts, two forward of the wing tube, and two behind - only two plastic bolts were supplied but blind nuts are in place. The trouble is the forward bolts are obscured by the tank when it is installed making it nigh on impossible to fit the bolts!! So, in the instructions (which are borrowed from a similar model), it mentions threaded pins fitted to the wings , that pass into the fuselage and are retained by R clips - good idea but where do I get them from??? Much appreciated. Edited By Rich2 on 25/04/2016 06:39:28 Quote Link to comment Share on other sites More sharing options...
Rich too Posted April 25, 2016 Author Share Posted April 25, 2016 Threaded would be ideal, but these would probably do the job, glued into the blind nuts.... **LINK** Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 25, 2016 Share Posted April 25, 2016 Do you know anyone who could cross drill and thread a piece of 6mm round steel? Could you cut the head off 6mm bolt and cross drill it to take an R clip? Quote Link to comment Share on other sites More sharing options...
Rich too Posted April 25, 2016 Author Share Posted April 25, 2016 Hi Bob, 6mm bolt is not a bad idea - thanks. Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 22, 2016 Author Share Posted May 22, 2016 I used the clevice pins and they are great. I don't know why they are not used more, much better than bolts. I glued them into the blind nuts using gorilla glue. I have another issue. I am using two switches and batteries, tech aero ibec, twin elevator servos and I am out of channels on the receiver! I am one short. What do people do? Buy a receiver with more channels or buy a much cheaper electronic servo mixer for the elevator? Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 22, 2016 Author Share Posted May 22, 2016 I have a Futaba 7c transmitter, am I right in thinking that I need a FASST receiver? An 8 ch FASST receiver is the best part of £100!!! Quote Link to comment Share on other sites More sharing options...
flight1 Posted May 22, 2016 Share Posted May 22, 2016 If you got a 7 channel tx a 8 channel rx will be no good so if you need 8 channels a tx upgrade would be needed too. I count 2x elevator+ 2 alirons+ throttle +rudder = 6 channels needed whe re the 8 comming from? also if you need afordable faast rx's try these have proven reliable Edited By flight1 on 22/05/2016 20:39:03 Quote Link to comment Share on other sites More sharing options...
iqon Posted May 22, 2016 Share Posted May 22, 2016 ever heard of Y leads.... Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 22, 2016 Author Share Posted May 22, 2016 Throttle, ailerons, rudder, two elevators, two batteries, and the ibec. Will it not work ? Two of the channels are for the batteries. Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 22, 2016 Author Share Posted May 22, 2016 Y lead will not work for the elevator as I need to reverse one of the servos. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 22, 2016 Share Posted May 22, 2016 Use the Y lead for the batteries Rich....two batteries into the Y lead & then plug into the Rx.... Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 22, 2016 Author Share Posted May 22, 2016 Doh! Brilliant thanks! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 22, 2016 Share Posted May 22, 2016 What servos Rich ? John Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 22, 2016 Share Posted May 22, 2016 Posted by Rich2 on 22/05/2016 20:07:38: I have a Futaba 7c transmitter, am I right in thinking that I need a FASST receiver? An 8 ch FASST receiver is the best part of £100!!! Try T9 hobbies and have an FrSky tfr8 FASST Quote Link to comment Share on other sites More sharing options...
TinPot Pilot Posted May 23, 2016 Share Posted May 23, 2016 You could also use a Y lead with a servo reverser for the elevators. Quote Link to comment Share on other sites More sharing options...
onetenor Posted May 23, 2016 Share Posted May 23, 2016 Why do you need an elevator reverser.A mixer I can follow but------ ???? Quote Link to comment Share on other sites More sharing options...
onetenor Posted May 23, 2016 Share Posted May 23, 2016 Posted by Bob Cotsford on 25/04/2016 09:23:06: Do you know anyone who could cross drill and thread a piece of 6mm round steel? Could you cut the head off 6mm bolt and cross drill it to take an R clip? If you can't drill or get them drilled cut grooves in them and use the clips round the outside. There are other types of clip that could be used in this way Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted May 23, 2016 Share Posted May 23, 2016 Here's a thing Rich, I was in a similar situation as you a few years back with a Futaba 7C and how to set up elevators on bigger applications. As you have found out that with some makes of servos no matter how you turn them, if you use 2 servos and a y-lead they still never operate in the same sense. Next I used a servo reverser, unsuccessfully I might add, purely because the two identical servos get to the end of their travel at a fractionally different speed. And of course one failed. Not good for precise aeros. Next I used just one powerful servo and set up a pull/pull arrangement much like a rudder but with two wires per elevator. Better, but really fiddly to set up and cable holes have to be added to the fuz side along with a different horn arrangement. I then bowed to the inevitable and bought a new TX the Futaba 14SG which had the required number a channels and the programming facility for dual elevators that the 7C doesn't possess to do the job properly. Sounds a bit over the top on the expense, but setting up 2 elevator servos is a dream now! Hope that helps mate. Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 23, 2016 Author Share Posted May 23, 2016 Posted by john stones 1 on 22/05/2016 21:18:57: What servos Rich ? John HXT 10kg from HobbyKing Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 23, 2016 Author Share Posted May 23, 2016 Posted by onetenor on 23/05/2016 03:24:22: Why do you need an elevator reverser.A mixer I can follow but------ ???? The elevator servos need to work in opposite directions. Quote Link to comment Share on other sites More sharing options...
Rich too Posted May 23, 2016 Author Share Posted May 23, 2016 Posted by Adrian Smith 1 on 23/05/2016 07:17:27: Here's a thing Rich, I was in a similar situation as you a few years back with a Futaba 7C and how to set up elevators on bigger applications. As you have found out that with some makes of servos no matter how you turn them, if you use 2 servos and a y-lead they still never operate in the same sense. Next I used a servo reverser, unsuccessfully I might add, purely because the two identical servos get to the end of their travel at a fractionally different speed. And of course one failed. Not good for precise aeros. Next I used just one powerful servo and set up a pull/pull arrangement much like a rudder but with two wires per elevator. Better, but really fiddly to set up and cable holes have to be added to the fuz side along with a different horn arrangement. I then bowed to the inevitable and bought a new TX the Futaba 14SG which had the required number a channels and the programming facility for dual elevators that the 7C doesn't possess to do the job properly. Sounds a bit over the top on the expense, but setting up 2 elevator servos is a dream now! Hope that helps mate. Thanks Adrian. The Y lead for the batteries will provide the solution this time, but the 14SG has been on my wish list for some time!! Quote Link to comment Share on other sites More sharing options...
