john stones 1 - Moderator Posted December 30, 2015 Share Posted December 30, 2015 Mine will be lecky, and as I already have some gubbins at hand i'll be using them. here's what I have SK3 3548 1050kv ..60amp Plush esc...3300 mah lipo prop we'll decide on later with ground clearance and wattmeter. So that's my set up, I'm sure there'll be quite a few different ones and they'll all be O.K John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 30, 2015 Author Share Posted December 30, 2015 No pictures yet, I've only cut parts out so far. Will be a fuzz mounted u/c and will be built up tail/fin, why ? so I can use up some of offcuts I have, and I like the open structure showing through the covering, either Solartex or the translucent H.K film. John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted December 30, 2015 Share Posted December 30, 2015 Oooh a translucent one, all modern & see through. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 31, 2015 Author Share Posted December 31, 2015 Well would you believe it, I wait over a month and I can't find the usb lead for my camera, so no pictures available till new lead turns up. John Quote Link to comment Share on other sites More sharing options...
Silver Wolf Posted December 31, 2015 Share Posted December 31, 2015 Hope you've finished that chippy, or have you had permission of Danny SW Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 31, 2015 Author Share Posted December 31, 2015 It's sat in corner looking at me S.W, I feel guilty everytime you lads post progress John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2016 Author Share Posted January 2, 2016 Having some p.c problems and lost some pics, did a built up fin/rudder, could one of the mods change my title to johns ballerina build please Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2016 Author Share Posted January 2, 2016 Thanks Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2016 Author Share Posted January 2, 2016 Few of t/plane and elevator, l/e of t/plane done with 1/8 laminate strips and rear of elevator will be 1/16 strips, I'm gonna lock the spars in with 1/16 infils. John Quote Link to comment Share on other sites More sharing options...
Levanter Posted January 2, 2016 Share Posted January 2, 2016 Nice work John. I like the laminates going into the tip and especially the fore and aft ribs Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 2, 2016 Share Posted January 2, 2016 I always find that diagonal strips between the ribs help reduce twisting and warping Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2016 Author Share Posted January 2, 2016 Yes Levanter going to the tip gave more glue area. Will be fitting 1/4 x 1/8 braces Peter, little weight for extra strength. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2016 Author Share Posted January 2, 2016 First strip on t/e, will add 2 more on outer then infills to lock spars in John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2016 Author Share Posted January 3, 2016 Little more done on elevators, I shall add some 1/8 behind l/e for strength/hinges and the cross braces also. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2016 Author Share Posted January 3, 2016 Tail end needs a sand up now, looks neat now completed, wing next I think. John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 3, 2016 Share Posted January 3, 2016 That's taking shape John. At this rate I think I will be the only person with a sheet tailplane! BEB Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2016 Author Share Posted January 3, 2016 I figured as you only need to follow the outline of the plan to build the sheet tail end BEB, new builders would have no problem with doing it, so I used up some of my off cuts on mine, I see nothing wrong with a sheet one, apart from I would've had to buy some John W.F has done a sheet one Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 3, 2016 Share Posted January 3, 2016 well just to be different I'm going to make an inflatable holographic one BEB Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 3, 2016 Share Posted January 3, 2016 I will be using a built up tail as well - but different again.. One point, I have folded 2 tail-planes in the past couple of years (in flight). I would be inclined to add a 1/16" ply brace about 8" long butted against the TE (inside edge) if you can get it in without hacking it to much Nice work John Martyn 1 Quote Link to comment Share on other sites More sharing options...
AndyD Posted January 3, 2016 Share Posted January 3, 2016 fantastic work, john abit fragile for me im to clumsy,i went to step over my sukhoi last summer and caught my foot on the tail and compleatly destroyed it, Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2016 Author Share Posted January 3, 2016 Cheers fella's John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 4, 2016 Author Share Posted January 4, 2016 Last bit on elevators done all braced up. John Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted January 4, 2016 Share Posted January 4, 2016 Very nice! Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted January 4, 2016 Share Posted January 4, 2016 Really great John, I'm about two thousand light years behind... ppfff Happy tailing Chris Brussels, Belgium Quote Link to comment Share on other sites More sharing options...
Ben H Posted January 4, 2016 Share Posted January 4, 2016 Looking nice John, especially the le & te Quote Link to comment Share on other sites More sharing options...
