Allan Bennett Posted August 14, 2017 Share Posted August 14, 2017 I too prefer to over-size the ESCs when I have to mount them out of the air flow. A couple of other "tricks" come to mind when I think about it: In my scale-fuselaged helis I've got cooling fans attached directly to the ESCs heat-sinks; and in my Flair Manatilla I've substituted an aluminium floor panel in place of the balsa one, to attach the 70-watt sound system amplifier's heat-sink to. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted September 11, 2017 Author Share Posted September 11, 2017 I haven't posted for a while as I have had a bit of a break from the build, concentrating on flying and repairing other models. Now that the weather is becoming less favourable, I have been getting back into building. I have cut out the gear doors and shaped the inside faces. Also cut out the cockpit area. Finally, glued on the horizontal stab. More later... Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted September 12, 2017 Share Posted September 12, 2017 That looks very nice Geoff. Can't wait to se her fly. Pete Quote Link to comment Share on other sites More sharing options...
Rob Ashley Posted September 12, 2017 Share Posted September 12, 2017 A great effort here Geoff, all coming along very nicely. Have you decided what covering/finish you are going for? Rob Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted September 12, 2017 Author Share Posted September 12, 2017 Thanks chaps. Rog - I am going to go for a glass fibre/epoxy resin finish and spray paint Martin and Martian - if you read this, can I ask if you used a steerable tail wheel in your models? I ask because the one if have, the steering arm protrudes outside of the fuselage side which will mean cutting away some of the balsa. From your pictures you don't appear to have had that problem. Geoff... Quote Link to comment Share on other sites More sharing options...
Martian Posted September 12, 2017 Share Posted September 12, 2017 Coming along nicely Geoff Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted September 12, 2017 Share Posted September 12, 2017 Mine is just fixed and retractable, Martin Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted September 12, 2017 Share Posted September 12, 2017 My build is at about the same stage as yours Geoff, and I'll be glassing and airbrushing. My rear wheel is retractable, but I doubt if I'll make it steerable. But, being electric, it's quite easy to programme motor differential if you want to help ground handling when returning from a flight. I've done it on my Multiplex Twinstar (which I've added tail-dragger undercarriage to) with motor throttles mixed with rudder, with a switch to disable it so that I don't inadvertently use it during flight. Quote Link to comment Share on other sites More sharing options...
Martian Posted September 12, 2017 Share Posted September 12, 2017 Posted by Geoff Gardiner on 12/09/2017 18:30:07: Thanks chaps. Rog - I am going to go for a glass fibre/epoxy resin finish and spray paint Martin and Martian - if you read this, can I ask if you used a steerable tail wheel in your models? I ask because the one if have, the steering arm protrudes outside of the fuselage side which will mean cutting away some of the balsa. From your pictures you don't appear to have had that problem. Geoff... Non steering and retractable ,with the retract unit I used the steering link was just an irritation so I abandoned it I can make it castoring if necessary . The real mossie had a castoring tailwheel . Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 15, 2017 Author Share Posted October 15, 2017 After much pondering I have decided to go with a steerable tail wheel. Here is a quick test to see if it works, before tidying things up. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 17, 2017 Author Share Posted October 17, 2017 I have been thinking about how to fit the canons into the nose, so....... Cranked up the trusty 3D printer and came up with this. More later... Quote Link to comment Share on other sites More sharing options...
Martian Posted October 17, 2017 Share Posted October 17, 2017 they look fantastic Geoff Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 22, 2017 Author Share Posted October 22, 2017 Got a little bit more done today: A slight adaption to the canon mountings Also made, fitted and fettled the rear cone. More later... Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted October 22, 2017 Share Posted October 22, 2017 Mouthwatering.... Quote Link to comment Share on other sites More sharing options...
Martian Posted October 23, 2017 Share Posted October 23, 2017 coming along nicely Geoff I like the cannons very impressive Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 23, 2017 Author Share Posted October 23, 2017 Here's a couple of designs for the 'recessed' canons: I will see which one is the easiest to fit. More later... Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted October 31, 2017 Share Posted October 31, 2017 Been following along and picked up some great tips! Here is mine so far, under cote done and waiting for paint job. Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted October 31, 2017 Share Posted October 31, 2017 Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 3, 2017 Author Share Posted November 3, 2017 Hi Mike. That looks fantastic - I hope mine turns out that good. What did you cover her with? Looking forward to seeing the finished article. Geoff... Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted November 6, 2017 Share Posted November 6, 2017 Geoff. Normal prep for balsa with filler. Then fiberglass with Eze-Kote. So much easier than epoxy and just as good (in my opinion). Then my trick, after a good sanding, is to fill all the normal fiberglass "micro holes" with Perfect Plastic Putty mixed 50/50 with water. This followed by a sanding creates almost glass. Then on to Klass Kote epoxy paint (So far just undercoat). Super hard and strong finish.. Mike Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 19, 2017 Author Share Posted November 19, 2017 A few more bits done: Using a laser that I got from ebay, I fitted the vertical stab. Cut the holes for the recessed canons. Started on the cockpit/battery area. More later... Quote Link to comment Share on other sites More sharing options...
Martian Posted November 20, 2017 Share Posted November 20, 2017 Great stuff soon be painting it Geoff Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 20, 2017 Share Posted November 20, 2017 Exactly what size of batteries are those Geoff? Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 20, 2017 Author Share Posted November 20, 2017 These (4S). Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted November 28, 2017 Share Posted November 28, 2017 Jeoff, What engines will you be using with 4S Batteries? Mike Quote Link to comment Share on other sites More sharing options...
