Martin McIntosh Posted April 23, 2018 Share Posted April 23, 2018 Never heard of mixing screen wash with paint before. Where did that idea come from? Quote Link to comment Share on other sites More sharing options...
Martian Posted April 23, 2018 Share Posted April 23, 2018 somewhere in the annals of this forum Martin although I only use it on gloss acrylics myself I use ordinary tap water with Valspar matt it sprays ok Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted May 7, 2018 Author Share Posted May 7, 2018 I got a bit of flying in on Saturday and took advantage of the weather to paint the camouflage on Sunday and today. The method that I tried this time was to cut a mask and use rolled up masking tape to hold it off the surface a bit. This gave a feathered edge effect. More later... Quote Link to comment Share on other sites More sharing options...
Martian Posted May 8, 2018 Share Posted May 8, 2018 its looking the business Geoff some have it finished Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted May 8, 2018 Share Posted May 8, 2018 It looks good Geoff. I have not seen the rolled up sticky tape technique before, but it appears to be very effective. Keep posting! Pete Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted May 8, 2018 Author Share Posted May 8, 2018 Thanks Martian - it's getting there. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 8, 2018 Share Posted May 8, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted May 27, 2018 Author Share Posted May 27, 2018 Bit more painting done today: More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted June 1, 2018 Author Share Posted June 1, 2018 This is the way I paint using masks: 1. Cut mask using my vinyl cutter and apply. 2. Paint edges with corresponding colour to prevent bleed. 3. Paint top colour. 4. Carefully peel off the mask. I had a bit of an oops moment when the wing fell off the table and damaged the corner. Out with the filler. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted June 10, 2018 Author Share Posted June 10, 2018 Not much to show for half a day tinkering today. I have cut out the remaining horns and sorted the servo bearers. More later... Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted June 18, 2018 Share Posted June 18, 2018 Geoff, What kind on vinyl cutter do you have? Impressive paint job! Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted June 18, 2018 Author Share Posted June 18, 2018 Thanks Mike. I have one of these: Quote Link to comment Share on other sites More sharing options...
Mike Beard 1 Posted June 18, 2018 Share Posted June 18, 2018 That's funny. When I realized you were using some kind of cutter and went looking. This is the one that I found! Have not purchased yet but it seems to be a great tool for the shop! Thanks! Can you cut lettering in vinyl to stick on a plane also? Instead of creating a template to paint "through"? Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted June 18, 2018 Author Share Posted June 18, 2018 Yes, it will cut vinyl decals - in fact it will cut all sorts of paper,card,vinyl - even fabric (I have only used it to cut paint masks so far). I think it is a good piece of kit for the price. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 19, 2018 Share Posted June 19, 2018 Same one that I use. Very useful and good value. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 2, 2018 Author Share Posted July 2, 2018 I have been fitting out the cockpit this weekend: More later... Quote Link to comment Share on other sites More sharing options...
Martian Posted July 2, 2018 Share Posted July 2, 2018 she is looking cracking Geoff Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 4, 2018 Author Share Posted July 4, 2018 Thanks Martian. Canopy going on now. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 7, 2018 Author Share Posted July 7, 2018 Masked up and ready for painting. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 9, 2018 Author Share Posted July 9, 2018 This weekend I got the canopy painted, added some weathering around the exhaust stacks and applied a satin clear varnish coat. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 30, 2018 Author Share Posted July 30, 2018 Little bit more done: Fitted the retracts and the gear doors. Printed off some spacers for the motors with my 3d printer. Nearly there now. More later... Quote Link to comment Share on other sites More sharing options...
Martian Posted July 31, 2018 Share Posted July 31, 2018 Brilliant stuff Geoff Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted July 31, 2018 Author Share Posted July 31, 2018 Thanks Martian. Today's job is to put it on the CofG tester and see if I can get it balanced with just battery, ESC and receiver positioning. Has yours flown yet? Geoff... Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted July 31, 2018 Share Posted July 31, 2018 Geoff, watching with interest, my BH mossie needs everything as far forward as possible to get C of G. Just love the U/C and doors. Quote Link to comment Share on other sites More sharing options...
Martian Posted July 31, 2018 Share Posted July 31, 2018 Hi Geoff no it has not flown yet i keep building but don't fly yet hopeless I know. I was advised CG should be checked with gear up Quote Link to comment Share on other sites More sharing options...
