iqon Posted February 25, 2017 Share Posted February 25, 2017 MR = multi rotor.... Quote Link to comment Share on other sites More sharing options...
iqon Posted February 25, 2017 Share Posted February 25, 2017 What he said Quote Link to comment Share on other sites More sharing options...
bert baker Posted February 26, 2017 Share Posted February 26, 2017 Thanks, I really ought to get out more. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 26, 2017 Share Posted February 26, 2017 Posted by bert baker on 26/02/2017 09:01:19: Thanks, I really ought to get out more. If you get a small indoor "M/R" then you won't have to. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 26, 2017 Share Posted February 26, 2017 Posted by Fun Flyer on 25/02/2017 18:24:35: Thanks for that Frank but I have enough headaches without trying to master SBus as well!! I've just spent the afternoon with Librepilot running through the setup. All went fine until I got to the last part of the Tx setup. i.e. centre the sticks and then move them to their extremes. I got no results at all. I'll hopefully get back to it tomorrow. Fortunately, being of a suspicious nature, I stuck a voltage indicator on what I understood were +5v pins on the PDB before I connected them and got 12v!! I'm using a venerable NiCd pack to power the Rx for the time being. When you say you got 12v at the PDB, did you mean at the BEC power supply to the Flight Controller? Power should be Lipo - BEC - FC - Rx. If you are using a separate battery then plug the power supply into the FC and it will then supply the Rx, I'm not sure if the FC works properly the other way round. BTW I'm just doing something similar with a CC3D with a view to using it in a fixed wing as a flightstabliser, on the bench at the moment, but should transfer it to a test mule soon. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 27, 2017 Share Posted February 27, 2017 Ok, the BEC is on the way and should arrive tomorrow. I've connected the standalone 5v pack to the FC as Frank suggested, however I'm still hitting the same wall. The setup works as expected until I get to centring the sticks and moving them to their extremes. The screen shows Receiver Activity for the correct channels but the sticks on the display aren't moving. However if I go back to the Remote Control Input screen the sliders all move as expected when the sticks are operated. Some helpful advice would be very welcome at this stage. Using the CC3D as a flight stabiliser in a fixed wing model would be very interesting. I have a second unit and I would hope to fit it to a large Cessna 172 that I'm refurbishing. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 27, 2017 Share Posted February 27, 2017 Fun Flyer, mine is doing the same, in fixed wing dual aileron mode, but it is moving the servos, I think it must be a bug in Librepilot. I'm using Srxl input, but that shouldn't make any difference. The one in my quad is running Open Pilot, as I haven't got round to changing over to Librepilot on that yet. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 27, 2017 Share Posted February 27, 2017 Posted by Frank Skilbeck on 27/02/2017 17:18:14: Fun Flyer, mine is doing the same, in fixed wing dual aileron mode, but it is moving the servos, I think it must be a bug in Librepilot. I'm using Srxl input, but that shouldn't make any difference. The one in my quad is running Open Pilot, as I haven't got round to changing over to Librepilot on that yet. Interesting, and somewhat reassuring, that you're seeing the same effect. I might just ask the question on the Librepilot Forum. I'll wait for the BEC before I do anything more. Quote Link to comment Share on other sites More sharing options...
iqon Posted February 27, 2017 Share Posted February 27, 2017 I watched a vid the other day on youtube, he unticked a box on cleanflight and re booted. box was ticked again when it came back on and all worked fine. can I remember what box .....no...if i find it i`ll let you know...it may be similar with what you are using . Quote Link to comment Share on other sites More sharing options...
iqon Posted February 27, 2017 Share Posted February 27, 2017 may not be related - but watch this vid from 6 mins in, this is the one I was thinking about... Quote Link to comment Share on other sites More sharing options...
iqon Posted February 27, 2017 Share Posted February 27, 2017 My progress so far of my cheap n cheerful quad , come to a stop, need a few ext cables. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 28, 2017 Share Posted February 28, 2017 Posted by Fun Flyer on 27/02/2017 17:25:22: Posted by Frank Skilbeck on 27/02/2017 17:18:14: Fun Flyer, mine is doing the same, in fixed wing dual aileron mode, but it is moving the servos, I think it must be a bug in Librepilot. I'm using Srxl input, but that shouldn't make any difference. The one in my quad is running Open Pilot, as I haven't got round to changing over to Librepilot on that yet. Interesting, and somewhat reassuring, that you're seeing the same effect. I might just ask the question on the Librepilot Forum. I'll wait for the BEC before I do anything more. Just went back onto mine and did a firmware update to the board before starting, and now it all works OK! Sticks move on the screen as they should. Only thing I did different was to use a different Rx battery as the other was getting a bit low, not sure if that would cause a problem though! Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 28, 2017 Share Posted February 28, 2017 According to LibrePilot its a known issue that occurs when the Flight Mode switch is not assigned. I hadn't done that and just clicked "Skip" when asked. Coincidently I assigned the switch last night when I could do nothing else but didn't try the setup again. It works now. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 28, 2017 Share Posted February 28, 2017 Sorry, I think my last post made even less sense than usual! I hadn't bothered to assign the Flight Mode switch because I didn't think it was essential. I fitted the BEC when it arrived this morning and to my surprise it all seems to be coming together. All I need to do now is tidy up all the spurious bits that are hanging off and then work up the courage to put the props on. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted February 28, 2017 Share Posted February 28, 2017 Posted by iqon on 27/02/2017 19:37:32: I watched a vid the other day on youtube, he unticked a box on cleanflight and re booted. box was ticked again when it came back on and all worked fine. can I remember what box .....no...if i find it i`ll let you know...it may be similar with what you are using . Thanks iqon, Cleanflight doesn't display quite the same as LibrePilot and I didn't see anything that compared to that box. However I've managed to move on another step. Nice looking machine you have there. Quote Link to comment Share on other sites More sharing options...
iqon Posted March 2, 2017 Share Posted March 2, 2017 Hope it`s as nice when ive test flown it....... Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted March 2, 2017 Share Posted March 2, 2017 Posted by iqon on 02/03/2017 17:06:49: Hope it`s as nice when ive test flown it....... If you've not flown helicopters or Multi-rotors before, you have to unlearn the habit of chopping the throttle when it starts to go wrong if you are on attitude mode on a Multirotor, centralising the pitch/roll stick should level the coptor. I'd recommend starting on that mode, rather than rate mode. Quote Link to comment Share on other sites More sharing options...
iqon Posted March 3, 2017 Share Posted March 3, 2017 Had it hovering in dinning room, not best place for it but somebody made it rain...... Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted March 3, 2017 Share Posted March 3, 2017 Pouring down all day here too. Is someone trying to tell us something?? Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted March 4, 2017 Share Posted March 4, 2017 No rain this morning so out to the garden for a test flight. Much to my surprise it actually flies!! Some drifting but I'm sure that can be trimmed out. Climbs like an express lift. It needs a totally different mindset compared to a fixed wing. At least I finished with all the props intact. I'll try and post a video when my nerves settle down. Thanks for all the help that got me this far. Edited By Fun Flyer on 04/03/2017 16:03:04 Quote Link to comment Share on other sites More sharing options...
Lunch-time flyer Posted March 4, 2017 Share Posted March 4, 2017 Just enjoyed catching up this thread, I've a flamewheel 450 and looking for a smaller racer - wondering whether to build from scratch or just buy off the shelf, don't think I'll be making my own frame but hat's off to FF Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 1, 2017 Author Share Posted April 1, 2017 Finally got to fly my new quad today, delayed through lack of money, then waiting for banggood to deliver. Bought an Eachine 250 Racer Anyone fancying one don't be put of because it says racing quad, there are 3 modes,angle,horizon.acro, flown in the beginners mode ..angle, it's not an handful and pretty stable, controls feel very nicely balanced, very good model for the money, lights are good as well Big thank you to my technical crew n lipo sponsor, Mr Gary Manuel John Quote Link to comment Share on other sites More sharing options...
iqon Posted April 18, 2017 Share Posted April 18, 2017 Good day Yesterday at field , you are never too old..... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 18, 2017 Author Share Posted April 18, 2017 Fine body of men/big kids Don't forget your predictions for this Sundays DVMFC Grand Prix John Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted April 18, 2017 Share Posted April 18, 2017 I predict you'll be standing on the flight line with hands in pocket, pretending to be flying your quad for the team photograph - again Can't wait for another go. Might be even more of us next week. Quote Link to comment Share on other sites More sharing options...
