Making a spinner by "spinning"
dave windymiller
In another thread, i mentioned i made an ME109 spinner from aluminium by using a method called "spinning".  In response to a "how to do it" plea, please see below.  I must firstly stress I am no expert and my methods / equipment are probably laughable to an expert however it does show good results can be obtained easily with just a normal lathe.
Spinning in a nutshell
I built a jet engine several years back and these are some of the parts i used
Some of the spun components are part of the combustion chamber and made from inconel sheet which was a nightmare to spin.  Some of the mandrels for this are in the forground.  The alluminium intake is a hellishly complex shape requiring a split mandrel so it could be removed. It turned out to be a breeze to make and the final intake was made in one attempt (unlike the inconel bits!). The mandrel took weeks to make and the final spinning about 2 hours for the ready to run component!
The mandrel can be made from metal, bakolite or even hardwood.  Aparrently you can make a wood version, spin a layer of aluminium over it so the woodgrain that may show through can be polished off leaving you with a mandril as good as solid metal (not tried it however).
For the spinner i made i used 12mm bakolite in layers attached to a chunk of steel for gripping in the lathe chuck
More to follow!
Edited By dave windymiller on 31/03/2018 13:21:20
Edited By dave windymiller on 31/03/2018 13:22:23
The metal being spun needs to be kept 'soft'....you find you have to anneal the metal several times before the article is completed...Use a substantial piece of material as a sooon for applying the pressure to the metal being spun, with a waxy tip to prevent burnishing or in some cases a roller bearing
There are numerous vids on youtube showing the methodology....
I've successfully spun aluminium and copper on my lathe without too many tears....crying Mainly for end covers for model steam boilers.
Fantastic stuff. In the three years through 1974 to 76 I was Production Manager at a company called Metal Finishes. We did all kinds of metal polishing, electroplating and anodising and were owned by a once famous company called Bulpitts, who made all of the Swan Brand kettles and other forms of holloware. Nearly of it was spun from copper or aluminium discs, a huge operation making thousands of pieces every day. Although that was well known, what wasn’t broadcast was the use of the metal spinning expertise for MOD work. Rocket nose cones and similar military hardware were spun from aluminium and then anodised by us in Metal Finishes. Very interesting.
A very useful skill.
The first task is to cut a blank disk of ally about 50-70% bigger than the finished spinner. Try to make the blank reasonably round and smooth as jagged edges can act as a focal point for the metal to crease. I used 1.5mm or 1/16 inch thick ally.
Next task is to anneal the ally. This has to be done several times during spinning. I just do it till it looks hot enough but you can use soap as a temp indicator (when it turns brown when its done apparently).
The blank has to be attached to the mandrel. For my turbine, all the parts I made didn’t use the centre so I could easily drill and screw the blank to the mandrel. The ME109 has a hole for a cannon in the centre so I also used a single m4 screw to attach the disk. To spread the load I made a 20-mm washer with an inside concave shape that matches the centre of the spinner.
If you don’t want a hole in the centre, the usual way is to use a live centre from the tail stock to physically push the disk/ concave washer against the chuck. Unfortunately my lathe isn’t able to do this as the headstock uses a taper plain bearing and any excess load from the tailstock causes it to sieze! Good job it’s an ME109 spinner with a hole I’m making.
The tool I use for forming is a brass rod approx. 12mm dia and some 600mm long with a file handle at the end. You could attach a small piece of brass to a steel rod of course. Cut the end of the tool at an angle, round all edges and polish it smooth. You can also use ball races with a radius ground on one edge mounted in the toolstock or on the manual tool. This is better for stainless ive found but for ally I prefer the brass rod method. This is used with a lubricant to keep the brass and ally from knarling together. Motorcycle chain lube works for me but candle wax or tallow can be used.
To lever the tool against the ally I use a bar mounted on the tool stock with holes in for a peg to sit in. This can easily be altered to get good leverage.
The tool is used against the ally UNDERNEATH the chuck. This way if you were to catch the chuck it wouldn’t fire the tool towards you. I must stress here that spinning probably breaks all the rules you are given for using a lathe safely!!!
When spinning, there are two different approaches. If you force the ally around the mandrel whilst keeping the ally disk flat/radial, you are in effect pressing the mandrel through the ally and extruding it. This thins the ally much like pushing your finger through taut rubber sheet. Any section that’s parallel will get too thin and probably sheer off. This pic shows this effect.
The other way is to “lay” the ally onto the mandrel by forming it into a cone (similar to the drawing at the top of the 1st posting) and done by sweeping strokes towards the outside of the disc. Unfortunately, if you wrap a sheet of paper around the mandrel it will wrinkle and crease which we don’t want. Spinning is therefore a mixture of the two methods above. We want to lay it down to keep thickness but have to extrude it enough to keep it from wrinkling. You are in effect moving the metal about like clay on a potters wheel!
The first version of the spinner I made, I extruded it too much and ended up with a spinner 0.6mm thick (too thin). My next attempt resulted in a 1.6mm thick spinner, much better!
During the making of my second spinner, the ally started to wrinkle which first shows as a judder felt through the tool. Don’t try to get rid of it by carrying on, it rarely works. It’s a good time to take it off and try to minimise the wrinkles with a hammer. It doesn’t have to be perfect, just remove the worst of it and re-anneal. The wrinkles are then removed by concentrating the force at the mandrel to extrude, ie push the cone further to the left. This action should cause the cone to open up and the wrinkles disappear (or it ends up a knackered mess ready for the bin!)
Its very difficult to put this whole process into words you just have to try it and spot the various behaviours for yourself.
Edited By dave windymiller on 04/04/2018 20:23:14
Rotation speed. Ive read it should be 800 rpm for initial roughing and 300 rpm for finishing. I use a lot slower speeds and it seems fine as my lathe lacks power at higher rpm.
If you have judged the size of the disk correctly, there would be nothing left as you cover the mandrel. If its too big you will end up with some excess that can be cut off with a lathe tool. Hopefully the spinning is longer in length than the final spinner so it is a simple case of trimming the excess and making a neat edge.
You can also remove the concave washer and neaten up the centre if necessary as the metal should now be a tight fit on the mandrel. You can also spin the metal over the back edge of the mandrel so it becomes permanently attached allowing you to give the centre more work with the tool if required. Once done part off the spinner to allow it to be removed from the mandrel.
If you managed to spin a sufficiently thick layer onto the mandrel, there should be enough material to allow any scratches to be polished or even machined out!
Final section – making the backplate and attaching the spinner.
I had family connections to Lune Metals in Lancaster, We made Swan brand pans , of which I still have a set in use from 1966 . As John Rudd states annealing is important , we used to make the ST ST hub caps for British Leyland motor show vehicles, and had to be heat treated after every pass, very time consuming ! . And yes we made rocket nose cones and 7 foot diam wash bowls for the textile dying industry .
Biggest problem was employee insurance as it was a very dangerous operation , !! The speed at which spinning takes place is very fast, Then when you trim the excess off, the buckled bit , it flew everywhere and its sharp !
Magic days , health and safety , ? not invented in the late 50s.
cheers
pete W
Many thanks Dave for pointing me to the article you have done on “spinning” as I’m in the same position with my Maxford USA Albatros plane which has a non standard spinner you can’t get and the one supplied is only a vac formed bendy plastic which is more for a static model than a flying plane. I have no lathe or experience in this field but have found an acquaintance of a friend who said he is intrigued at the method and could give it a try. I’m hoping to source a 150mm hardwood block which will be the basis for the mandrill and I was told Axminster Tools was a good option. For any who wonder why some modellers have to go to such lengths for a simple spinner have a look at the WW1 Albatros spinner as an example - you can’t buy one the right shape. Fingers crossed my acquaintance can achieve a result. Regards Peter
Again thanks for the complements and good luck with the albatros spinner. I guess this is posted in the right place already if rcm&e wanted to do an article and i would oblige if asked even if i am just a garage bodger type chap with improvised equipment.
I will finish the spinner article soon, just got back from a walking holiday so i cant walk now!!
  • 4 weeks later...
To make the backplate
True up a rough cut peice of 6mm dural using a 6mm hole and 6mm screw to hold it in the lathe. Once round it can be removed and a better, more accurate method of holding it will be used.
Put a peice of scrap thats smaller than the spinner into the lathe and true up the front face and add a shallow 8mm hole
After degreasing, attach the backplate to the newly formed face using thin cyno and a tailstock centre to get it reasonably true. The faces should be very true if alls well and the o/d can be also trued up. Dont remove this from the chuck until all machining is done.
Set the tool stock to an angle that suits the spinner at the base.
Machine away the o/d until the spinner fits over the backplate. Leave a 1.5mm shoulder for the spinner to seat on.
Take off just enough for the spinner to seat against the 1.5mm shoulder. It should sit nicely and be a tight fit that holds itself on. All being well, the spinner will spin true!  The shoulder edge can be trimmed to match the spinner either using the same angle or at 90 degrees as preferred.
Machine away the centre to leave a 1.5mm backplate and a 3mm thick outer ring where the spinner fits. Also open up the centre with a boring bar from 6mm to fit the engine (1/4" in my case).
It can now be removed from the lathe by heating with a blowtorch until the cyno fails. Clean up the back of any cyno that remains.
Final instalment soon!
Edited By dave windymiller on 20/05/2018 22:54:45
Excellent post Dave, and fascinating to see what's involved. I keep meaning to have a go at this, but as most of my models are electric, keep opting for the easier option of vacforming.
The backplate idea I will definitely have a go at, as that will also work well with Vacformed or even fibre glass cones.
Are the metals anything fancy?
Danny
Hi Danny
The metals are nothing fancy. Dural (duralumin) is simply a tougher grade of ally but normal ally should suffice and would be lighter. I had dural kicking about as it was once part of a wheely bar from a drag bike. The metal for spinning is just bog standard 1/16 ally sheet (dont know what grade).
I have made spinners using glass cloth (having made a mould from a vac formed version) but with the same back plate idea. Heres my mossi. These spinners withstood a vertical crash into the soft field after the usual tip stall that mossies love to do so much. Thankfully, the repairs to the plane only took a week.
Dave
Edited By dave windymiller on 21/05/2018 23:09:37
Edited By dave windymiller on 21/05/2018 23:11:42
Hi Dave,
Thanks for taking the time to post this, it's really informative.
May I ask, when turning the backplate, is cyno (superglue?) strong enough to hold the workpiece in place whilst machining it? Or do you leave the tailstock centre in place? If so I can't work out how you machine away the centre?
Thanks in advance for any help,
kind regards
Julian
