David Hayward. Posted May 1, 2018 Share Posted May 1, 2018 Started new thread as advised... Hi All, I have asked this question on other forums in order to capture as much feedback as possible, so apologies if you have already seen this post elsewhere. I am preparing to build a chorus gull from RCME plan by Brian Peckham Feb 02. So far I have had the plan enlarged by 25% which gives me a 6ft wingspan. I have for example noted others have commented about issues with the wing rib sizes as shown on the plan, so this is one area where I would appreciate feedback. So if you have built one of these from the RCM&E plan I woild be pleased to hear from you any any comments/advise you may have. Thank you Here is a link to some information on this model... **LINK**. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 1, 2018 Share Posted May 1, 2018 I'll be interested to follow this as I've just completed a quarter scale Mew Gull from the Skyways Models plan-pack. I've had 6 flights so far and not one what I would call a good landing but I'm getting there. It's very good in the air and flies with authority on its 6S electric set up. How are you intending to power your Chorus Gull? Expanding the Chorus Gull to 6' ws makes it the same size as my Mew Gull so it'll be interesting to see how it build and, perhaps more importantly, flies. Prior to the test flight in late December last year. I removed the spats and they'll remain off until I master landing I've only flown it again in the past few weeks because of the weather. Geoff Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted May 1, 2018 Author Share Posted May 1, 2018 That looks nice Geoff. I am going to power mine with a 4 stroke ic, possibly a 90. Quote Link to comment Share on other sites More sharing options...
Trevor Posted May 1, 2018 Share Posted May 1, 2018 Hello David. I built an electric version of the Chorus Gull back in 2002. Details (including a number of subsequent mods) here: **LINK** Trevor Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted May 1, 2018 Author Share Posted May 1, 2018 Thanks Trevor, that's great. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted May 1, 2018 Share Posted May 1, 2018 I have just read through Michael Parry's Chorus Gull build article from February 2002 RCM&E and I can't find any adverse comments regarding the rib sizes, presumably you have this article? I do remember reading about some issues with the plan but sadly I can't remember what they were. Hopefully someone else will have a better memory than I. It's a lovely looking model and will look (and fly) even better scaled up 25%. Following with interest. Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted May 1, 2018 Author Share Posted May 1, 2018 Thanks Piers, I do have the magazine article. I spotted a post on this forum which led me to believe there is an issue with the ribs as drawn on the plan, here it is: http://www.modelflying.co.uk/forums/postings.asp?th=11047 Edited By David Hayward. on 01/05/2018 15:35:24 Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted May 1, 2018 Share Posted May 1, 2018 I built one a few years ago now. Mainly a hanger queen as I have far to many plane's and have my regulars. hmmm we have an "OLD" plane club event coming up soon. Sad to say I cheated on the wings and had a set of foam ones made for me. There are a good few picture's here. And a build thread from another forum here. Built using the full size plan and not the freebie from the mag. I have a copy of the build article from February 2002 and the Original "Radio Modeller" article from March 1989. Can scan to PDF if required. I contacted Trevor during the construction of mine asking for advice. A nicer more helpful person you could not wish for. Kev Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted May 2, 2018 Author Share Posted May 2, 2018 Hi Kevin, thank you for your response, liked your images and build blog. I have the RCM&E Feb 2002 article but not the original Radio Modeller article and so would be most grateful of a pdf. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted May 3, 2018 Share Posted May 3, 2018 PM sent David. Kev Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted August 13, 2018 Author Share Posted August 13, 2018 I am getting closer to doing some actual building; sum total of my efforts so far is the production of two wing rib templates. I would appreciate some advice on building the wing which has a tapered chord and section. I have magazine articles from the original design in Radio Modeller March 1989 and also the later article in RCM&E February 2002, but neither goes into any detail about wing construction. it's the tapered section element that I could do with some advice on. The ribs will be produced by the sandwich method. It appears to me the wing section should taper top and bottom from root to tip; this means I cant just build with the ribs from root to tip down on the building board as this would mean only the top of the wing would taper. What this means is ribs from the root to the tip will have to be gradually spaced off the building board, also bearing in mind building in the necessary washout. Firstly is my thinking correct? Secondly, if this is correct, is the easiest way of achieving this by including tabs on the ribs to provide the required spacing? I have included an image of the two template ribs cut and in position for drilling. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 13, 2018 Share Posted August 13, 2018 I cheated!! Got a set of foam wings cut. Bilkits did them for me. Kev Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 13, 2018 Share Posted August 13, 2018 Hey, I built the original some years ago powered by an OS 52S. Great model. I seem to remember that the published ribs were shown at the wrong size but a SAE got you the right ones. I sold this on to a club mate who is crazy on the Mew Gull because I built a 1/4 scale version powered (over powered) by a YS110 so if you bear with me I shall describe this in more detail. I easily found a free PDF by Colin Usher on t`internet of the original, but re drawn by a lady, who unfortunately does not know the difference between a rudder and a tailplane as you will see if you look at it, but otherwise quite good except that one of the formers is way too narrow; quite a job to work out the correct size given the awkward shape of them. I could not wait for a mate to print it to 1/4 scale for me so `tiled` it; 64 sheets of A4! But not all in one go. I much prefer the bubble canopy version and luckily found one from MRM at W&W. I wanted this to be more aerobatic since the smaller one would do four point rolls better than many F3A`s so I mirrored the wing top section to the bottom of it which made it fully symmetrical and of course a little thicker. The spats are a real problem so I made GF moulds for these, fixed with silicone, and halved the length of the torsion bars to stop the u/c bending back and the spats going through the bottom of the wing. The cowl is also GF. I should still have the moulds for these. If the rudder was a bit bigger it would easily do the complete 1970`s style F3A schedule. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted August 14, 2018 Share Posted August 14, 2018 Posted by David Hayward. on 13/08/2018 20:15:34: it's the tapered section element that I could do with some advice on. The ribs will be produced by the sandwich method. It appears to me the wing section should taper top and bottom from root to tip; this means I cant just build with the ribs from root to tip down on the building board as this would mean only the top of the wing would taper. What this means is ribs from the root to the tip will have to be gradually spaced off the building board, also bearing in mind building in the necessary washout. Firstly is my thinking correct? Secondly, if this is correct, is the easiest way of achieving this by including tabs on the ribs to provide the required spacing? No David, I don't think it is. I don't have the plan in front of me but just pin the lower spar to your building board and glue your ribs to that, not forgetting to pack up the trailing edge, - progressively increasing spacers to the tip to create the required washout. Don't build the wing 'off the building board'. I am not a fan of foam wings but the Bill Kits foam wing cutting service looks very good value if you follow the link provided by Kevin. It might save you time and heartache if you are not comfortable building a tapered, washed-out wing. Good luck. Edited By Piers Bowlan on 14/08/2018 05:45:40 Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted August 14, 2018 Author Share Posted August 14, 2018 Posted by Piers Bowlan on 14/08/2018 05:43:27: Posted by David Hayward. on 13/08/2018 20:15:34: No David, I don't think it is. I don't have the plan in front of me but just pin the lower spar to your building board and glue your ribs to that, not forgetting to pack up the trailing edge, - progressively increasing spacers to the tip to create the required washout. Thanks for your response Piers. So this would mean the wing section tapers only on the top of the wing from root to tip; the bottom of the wing will be flat. My understanding was that the root and tip ribs centres should be aligned as in the image I have posted - then you have even taper of the section top and bottom? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 14, 2018 Share Posted August 14, 2018 You don`t need to worry about building in an underside taper since this will automatically appear when the wing halves are joined with a little dihedral. I do not remember bothering with wash out. The wing loading on mine is quite low and there is no tendency to tip stall. The sandwich method is not a good idea for tapered ribs, much better to download the basic Profili s/w which will produce an accurate outline of each rib. You can easily add building tabs as well and use these to provide wash out. A foam wing would be rather heavy and look quite wrong since the design calls for a partially open structure. Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted August 14, 2018 Author Share Posted August 14, 2018 Ok, thank you to everyone that contributed and thank you Martin, I can now see after doing a couple of basic drawings how dihedral effectively means the wing tapers top and bottom from root to tip. Martin, I see you have an image of a Mew Gull in one of your albums, is this actually the Brian Peckham Chorus Gull I am about to build? Do you have any images of the build? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 14, 2018 Share Posted August 14, 2018 Hi David, I think you mean the pic of the tail end which was just put there to illustrate the rudder angle or something. This would be the 1/4 scale version and I am afraid that I do not have any pics of the build. The wing is very simple but due to not having any vertical sides the fus. really needs a jig of some sort but I do not remember using one on the 1/4 scale one. Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted August 14, 2018 Author Share Posted August 14, 2018 Hi Martin, this is the image I was referring to from one of your albums.... Quote Link to comment Share on other sites More sharing options...
will -0 Posted August 15, 2018 Share Posted August 15, 2018 Hi David I have a chorus gull built as per the plans. Don't recall the wing rib thing, but it's possible I just made a set by sandwich method, or bodged it after. Anyway mine is powered by an OS 60FP and it goes really really well, grooves round the sky. It's possible it is a tad nose heavy,, but it flies so well like this that I'm not worried. The only issue I have is that it's not the lightest of aircraft and is a bit slippery so can be a challenge to get it stopped on our patch in certain wind directions (or more of a problem with nil wind). If I were to build another I would probably consider adding flaps. I would also makes sure the back end is as light as possible - mine has quite a bit of lead in the cowl. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 15, 2018 Share Posted August 15, 2018 Hi David, I missed that one which is of the 1/4 scale version. I possibly confused the ribs with the Spiteful from the same publication. Quote Link to comment Share on other sites More sharing options...
David Hayward. Posted December 3, 2019 Author Share Posted December 3, 2019 I have at last started covering my Chorus Gull and I want to copy the red with gold trim as here. I will be using Solarspan for the red but have not yet sourced anything for the gold trim. Any suggestions as to what I could use? Will all the different types of covering stick to Solarspan? Any suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
Steve Jones 2 Posted December 3, 2019 Share Posted December 3, 2019 Hi there, I have got one of these models , built from a plan and its fantastic.. fitted with an OS 91 FS.. which is a bit much but it cruises on half power and sound great. Cockpit is scale and I took a trip to Old Warden where they had one and took load of pics. Only comment I would have is for durability over the years as the U/C wires seem to have worn the holes in the wing blocks so they rock back and forward. On landing now its a nightmare unless you get a 3 pointer. Otherwise they swing back and dig in, pitching model up. O really need to cut the wing open and sort the worn mounting blocks but as the model is white solartex covered and painted i dont know the exact colour to match. So, as yours is not covered i would seriously suggest you consider the wing mounting block system and maybe strengthen or sleeve before the covering goes on. Steve Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 3, 2019 Share Posted December 3, 2019 For gold trim I'd be asking around local companies that do trade decals and trim for vans, vinyl wraps etc. as they may well have offcuts that you could use. Otherwise Quote Link to comment Share on other sites More sharing options...
