dirk tinck Posted May 26, 2018 Share Posted May 26, 2018 Hi guy's ! This is my 2-servo system with hatches bottomside and aileron-linkages upperside. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted May 26, 2018 Author Share Posted May 26, 2018 finaly found the way to upload pic's here.I will try to keep up with you all and post some progress pic's. This is what it should look like in September : Quote Link to comment Share on other sites More sharing options...
steven kemp Posted May 26, 2018 Share Posted May 26, 2018 Nice one Dirk and loving the choice of your chosen model,look forward to seeing you back on the slope in September,Happy Landings to you.. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 4, 2018 Author Share Posted June 4, 2018 Hi,made the top sheeting today after installing all the electrics. As for the washout , i madeup a wedge starting with 2mm at the tip going to zero at the end of the sidepanels(2degrees is about 2mm at the back of the tip)and tack-glued them under the TE. Edited By dirk tinck on 04/06/2018 00:32:17 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 4, 2018 Author Share Posted June 4, 2018 I wanted to give the dihedral braces alittle more grip so i filled the area between the spars(first compartiments)with 3mm balsa Edited By dirk tinck on 04/06/2018 00:34:44 Edited By dirk tinck on 04/06/2018 00:41:17 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted June 4, 2018 Share Posted June 4, 2018 Looking good Dirk! Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted June 5, 2018 Share Posted June 5, 2018 A very interesting variant you're going for there, Dirk! See you in September Quote Link to comment Share on other sites More sharing options...
J D 8 Posted June 5, 2018 Share Posted June 5, 2018 Heard of two in a Hurricane before but not a backseater with a popgun,must have surprised some 109's. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 9, 2018 Author Share Posted June 9, 2018 To give the wingtips a little more support i sanded them flush with the false LE and then added the true LE Edited By dirk tinck on 09/06/2018 00:28:50 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 9, 2018 Author Share Posted June 9, 2018 The black thing is spraypaint serving as a sanding guide so i don't sand the sheeting away. That would be big trouble I did also marked the position of the nav.ligths. When glueing on the tips , make sure the ply-part of the tip is in line with the aileron TE Edited By dirk tinck on 09/06/2018 00:37:31 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 21, 2018 Author Share Posted June 21, 2018 Took a swing today at the wing fairings.Tried with blue foam with a balsa base.It came out rather well so tomorrow i'll do the other side. Edited By dirk tinck on 21/06/2018 00:19:00 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 23, 2018 Author Share Posted June 23, 2018 Some more work on the wing fairings.I cutted the front part of the leading edge away and added it to the fuse because the fairings were getting to thin at the front.Its a really nice fit !! Time is running !! Edited By dirk tinck on 23/06/2018 23:50:34 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 25, 2018 Author Share Posted June 25, 2018 It's official now :There's a two_seater hurricane flying to the Orme in september !! Edited By dirk tinck on 25/06/2018 23:32:00 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted June 26, 2018 Share Posted June 26, 2018 Oh yes!! A major milestone achieved!! Looks great. Can't wait to see this up close in September!! Quote Link to comment Share on other sites More sharing options...
Steve McLaren Posted June 26, 2018 Share Posted June 26, 2018 Yes, fabulous fairing Dirk. I don't think I'll have the time or patience to match that! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted June 26, 2018 Author Share Posted June 26, 2018 Thanks Steve,it didn't take that much time really.The hard part is that the foam gets really fragile when it is that thin.I'm hoping the cloth will strengten the whole. Succes with yours ,greetz Edited By dirk tinck on 26/06/2018 23:37:47 Quote Link to comment Share on other sites More sharing options...
Harry Twist Posted June 27, 2018 Share Posted June 27, 2018 Hi Dirk, looks great, nice work with the wing fairings! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted July 14, 2018 Author Share Posted July 14, 2018 Hi guys ,back on track ! Sanded the fuse,fitted the tail and working on the nav-lights Edited By dirk tinck on 14/07/2018 00:28:15 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted July 14, 2018 Author Share Posted July 14, 2018 Can somebody tell my how to get those pics in the right position ? Edited By dirk tinck on 14/07/2018 00:30:12 Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted July 14, 2018 Share Posted July 14, 2018 .down upside is keyboard the however ,laptop a on Dirk them viewing problem no have I Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted July 14, 2018 Share Posted July 14, 2018 Posted by Mark Kettle 1 on 14/07/2018 08:37:59: .down upside is keyboard the however ,laptop a on Dirk them viewing problem no have I ... humm... reads like an ARTF construction manual from Shenzhen... Either problem here no . Cheers Chris Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted July 22, 2018 Author Share Posted July 22, 2018 I'm all set for glassing but it's too damn hot ! 27c till late night... Will have to go in night mode ! Edited By dirk tinck on 22/07/2018 01:32:19 Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted July 23, 2018 Share Posted July 23, 2018 Posted by Mark Kettle 1 on 14/07/2018 08:37:59: .down upside is keyboard the however ,laptop a on Dirk them viewing problem no have I I like that Mark! Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted July 23, 2018 Share Posted July 23, 2018 Posted by dirk tinck on 22/07/2018 01:30:10: I'm all set for glassing but it's too damn hot ! 27c till late night... Will have to go in night mode ! Edited By dirk tinck on 22/07/2018 01:32:19 Opposite effect here Dirk. 2am and still 18deg C in the shed. Great for setting aliphatic glue in under 2 hours! Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted August 6, 2018 Share Posted August 6, 2018 Looking good Dirk - way to go with photos is always take them with your phone landscape then they will always turn out right, or rotate them to landscape before you upload them? You can't rotate them on this site, there are no tools available for this. Quote Link to comment Share on other sites More sharing options...
