tigerman Posted August 10, 2018 Share Posted August 10, 2018 Need a new good 120 four stroke engine .My favourite four stoke engines are almost hard to obtain and are always out of stock so I will have to find a replacement and OS are the next best engines but it looks like OS no longer do a 120 four stoke but I see there are a few OS 120 E four stokes available still, just wonder what they are like ? Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 10, 2018 Share Posted August 10, 2018 The 120E is similar to the original surpass and is a good general purpose engine but its no power house. The exhaust supplied is also small and loud so will need replacement if you have a noise limit at your site. Beyond that they are good engines. A friend has the pumped version but its effectively a 120E as the pump gave up the ghost and its now got a standard asp120 carb on it. It runs a 15x8 prop in the 8300-8500 range and powered his 70 inch spit quite nicely. If you can find a non pumped surpass III you will be better off but they are pretty spendy if I recall. Quote Link to comment Share on other sites More sharing options...
tigerman Posted August 10, 2018 Author Share Posted August 10, 2018 The other 120 four stroke someone suggested was the ASP 120 but I thought this was a budget type engine and not sure of the quality of this engine but I could be wrong Quote Link to comment Share on other sites More sharing options...
Don Fry Posted August 10, 2018 Share Posted August 10, 2018 You are wrong. Nice motor. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 10, 2018 Share Posted August 10, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 10, 2018 Share Posted August 10, 2018 The ASP 120 is a good engine but from my experiences with that and one of the OS's, the OS will beat it both on output and carburation. My OS would turn a 16*8 APC quite happily while my ASPs were better on 15*8, the OS was easy to tune for a smooth throttle action, the ASPs were harder to setup for a smooth midrange transition. The ASPs were still very good engines just not as refined as the OS. Quote Link to comment Share on other sites More sharing options...
John Duncker Posted August 10, 2018 Share Posted August 10, 2018 Saito 125s are available of the shelf AFAIK. Not cheap though but quality rarely is. Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 11, 2018 Share Posted August 11, 2018 Posted by tigerman on 10/08/2018 19:52:54: The other 120 four stroke someone suggested was the ASP 120 but I thought this was a budget type engine and not sure of the quality of this engine but I could be wrong If you want it to last for ever, has great performance/quality and a nice finish then its the wrong motor. if you want an inexpensive power plant that works and you throw away when past its best then crack on. Just ignore the ASP run in instructions, there is a better way to do it. Quote Link to comment Share on other sites More sharing options...
Alve Hansson Posted September 4, 2018 Share Posted September 4, 2018 * Edited By Alve Hansson on 04/09/2018 19:01:06 Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 4, 2018 Share Posted September 4, 2018 The ASP/SC/Magnum 120's are all ok, they last years, but haven't got the power of an OS. In fact the same is said to all the engines, but powerful enough for most things, good value and spares are cheap, compared to OS. But the OS 120, especially the pump is a powerful beast, really powerful.One OS120 FS pump is 30 years old - had a new set of bearings 10 years ago and still going. Even now. on a 16x8 3 blade prop, I'm getting over 9000 rpm on it, it goes through the sound barrier - people can testify to anyone whos seen my Chris Foss Extra Wot go. In comparison a SC/ASP 120 FS with a 15x8 3 blade prop goes no-where near - and that's a smaller prop. But for the price it does it's job. Quote Link to comment Share on other sites More sharing options...
alex nicol Posted September 4, 2018 Share Posted September 4, 2018 if power and price are issues, then you could always go for the asp 1.80, there's not a lot of difference in weight and it's the same crankcase as the 1.20.......... more importantly it'll swing a 16x8 effortlessly I have one in the front of a Flair Christen Eagle (not the lightest airframe on the planet) and it will go vertically out of sight. there's a review on the JE website and it's spot on .......That's my two peneth worth.........good luck with your search Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted September 4, 2018 Share Posted September 4, 2018 I have several ASP four strokes and for what I paid for them new, they were good value for money and have served me well. Not as powerful as the OS and the quality of the carburettors is variable, tend to wear quickly so do give tuning issues and are no where near the standard of manufacture of the OS. Providing one accepted these things then no problem, given the engines were near half the price of an equivalent OS some years back. I have just bought a NIB OS120 E for my BT Spitfire Mk1a - cost me £200 and had to wait for a good one to appear on BMFA but the difference in quality is obvious - the engine is so much more powerful, smoother and economical than my ASP120fs, both run on Laser 5% fuel. Pulls the 14lb Spit around with authority. I still have a NIB ASP 91fs for another project underway at the moment, but I wouldn't buy another new one, they're not the good value anymore for what they are IMHO, which is a pity. The Saitos seem nice but I understand they need at least 10% nitro, which I'm not keen on - are they actually OK on 5% nitro? Noted Alex's comment on the 180 - a club mate has one and it does perform......but boy does it drink fuel if you use its performance. Edited By Cuban8 on 04/09/2018 20:36:51 Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted September 4, 2018 Share Posted September 4, 2018 Bought a NIB Saito 72 at the last club auction, still with a gratifyingly big price tag on it. Took a chance on it at the front of an ancient DSM Excelsior 150 which incidentally is a sweetie. Even I can fly it. The Saito sect advised 15% nitro and it ran and flew but it was hard to tune, after about an hour’s running. The sub-sect prescribed an OS 4 plug instead of the Saito and a tank of Laser 5. Starts easily, 2 clicks of throttle, holds its tune, idles ok and it’s £10 a gallon cheaper. Still very oily though. Maybe it’s the more modern Saitos which prefer more nitro. Hope this helps. BTC Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 4, 2018 Share Posted September 4, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 4, 2018 Share Posted September 4, 2018 Don't forget enya. if you can find a 120R they are savage monsters. Not especially refined I would say, but power in spades. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 4, 2018 Share Posted September 4, 2018 Yep I like Enya, love the sound of em, plenty Y.S about at good prices as well. Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted September 7, 2018 Share Posted September 7, 2018 Jon, What's the better way to run in an ASP? BTC Quote Link to comment Share on other sites More sharing options...
