SIMON CRAGG Posted June 9, 2019 Share Posted June 9, 2019 Our club hold regular electric glider "one design" events with the HK Phoenix 2000. Everything stock, and all using a zippy 3s 1300 lipo. The events are always well attended due to the "level playing field" of all having exactly the same set up. However, we tried recording the max rpm of each model today. The range was from 7800 to 8200 rpm. Although 400 rpm is not a lot, it makes a difference on a 30 second climb out. Is the difference just due to some motors being better than others? We used the same tacho throughout. All batteries fully charged and balanced. Is there some way of increasing the rpm, so that we are all at 8200? Great competition either way! Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 9, 2019 Share Posted June 9, 2019 Could be some variation between the motors but more likely differences in internal resistance of the batteries. Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted June 9, 2019 Share Posted June 9, 2019 Simon, You could flash the ESC's so they are rpm limited. They do this in E2K pylon racing so that everything is even making it all down to pilot skill. Rich Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted June 9, 2019 Share Posted June 9, 2019 My vote is with Trevor, Example, I use standard, nanotech, and Graphene lipo and the battery voltage at full throttle drops less wit the Graphene hence the motor turns faster and absorbs more power. As Scotty would say "You cannot change the laws of physics" and at least some of the additional consumed power should be turned into more speed. On a different tack, if you wanted to bend the rules then reducing the models drag would probably produce a greater climb rate... especially if the model lost some weight... The new lightweight gilder depending on the event might not work as well as its heavier brother...swings and roundabouts! Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 9, 2019 Share Posted June 9, 2019 IMO the RPM variation noted in the OP is remarkably low. I think you'll find that 5% variation in the motor's quoted kv figure is reasonable across most, if not all, cheap brushless motors. Add in the variations to be expected in the batteries, even when brand new. Then take into account age, usage & differing charge regimes individual batteries will have had, again 5% performance would seem reasonable. Even the props will have some variation during manufacture &/or storage. I don't know whether or not Richard's suggestion would be possible with the ESC's supplied in the kit but another method would be altitude limiters set to cut motors at a specified altitude or time whichever occurred first. Of course the extra cost would have to be considered as that could kill the popularity of a low key fun comp. HK used to sell a suitable device but don't seem to have stocked it for some time now. Edited By PatMc on 09/06/2019 22:01:05 Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted June 10, 2019 Author Share Posted June 10, 2019 Thanks for the comments. I think we will have to live with the variation, and just concentrate on the set up / trimming and flying as smoothly as possible. I have tried adjusting the motor timing (no difference), balancing the batteries (same) and virtually everything else I can think off, without success!. Height limiters are a good idea, which we use in other events, but the P2K comp is to be kept as simple and cheap as possible, to encourage as many entrants as possible without additional cost, Quote Link to comment Share on other sites More sharing options...
Gordon Tarling Posted June 10, 2019 Share Posted June 10, 2019 Most likely just down to variations in rpm/V and batterry age/internal resistance, as already noted. If it's within the rules, warm the battery up to around 40C in a battery 'oven' just before flying - it'll make a difference. Don't go over 45C though. Quote Link to comment Share on other sites More sharing options...
Gordon Tarling Posted June 10, 2019 Share Posted June 10, 2019 Sorry - dup post. Edited By Gordon Tarling on 10/06/2019 08:51:07 Quote Link to comment Share on other sites More sharing options...
PeterF Posted June 10, 2019 Share Posted June 10, 2019 I had an IC twin once that ran 10x6 APC props, I tested 7 props one after the other on one engine and found something like a +/-200 rpm difference at 10,600 rpm, so even props can have a little variability. Quote Link to comment Share on other sites More sharing options...
BackinBlack Posted June 10, 2019 Share Posted June 10, 2019 +/- 2.5%, not bad when you consider all the manufacturing, calibration and process variables. Propeller Motor ESC Wiring Connectors Batteries Rx conversion/processing Tx calibration/processing Quote Link to comment Share on other sites More sharing options...
