RPM Conundrum
SIMON CRAGG
Our club hold regular electric glider "one design" events with the HK Phoenix 2000. Everything stock, and all using a zippy 3s 1300 lipo. The events are always well attended due to the "level playing field" of all having exactly the same set up.
However, we tried recording the max rpm of each model today.
The range was from 7800 to 8200 rpm.
Although 400 rpm is not a lot, it makes a difference on a 30 second climb out.
Is the difference just due to some motors being better than others?
We used the same tacho throughout.
All batteries fully charged and balanced.
Is there some way of increasing the rpm, so that we are all at 8200?
Great competition either way!
My vote is with Trevor,
Example, I use standard, nanotech, and Graphene lipo and the battery voltage at full throttle drops less wit the Graphene hence the motor turns faster and absorbs more power.
As Scotty would say "You cannot change the laws of physics" and at least some of the additional consumed power should be turned into more speed.
On a different tack, if you wanted to bend the rules then reducing the models drag would probably produce a greater climb rate... especially if the model lost some weight...
The new lightweight gilder depending on the event might not work as well as its heavier brother...swings and roundabouts!
IMO the RPM variation noted in the OP is remarkably low.
I think you'll find that 5% variation in the motor's quoted kv figure is reasonable across most, if not all, cheap brushless motors.
Add in the variations to be expected in the batteries, even when brand new. Then take into account age, usage & differing charge regimes individual batteries will have had, again 5% performance would seem reasonable.
Even the props will have some variation during manufacture &/or storage.
I don't know whether or not Richard's suggestion would be possible with the ESC's supplied in the kit but another method would be altitude limiters set to cut motors at a specified altitude or time whichever occurred first.
Of course the extra cost would have to be considered as that could kill the popularity of a low key fun comp.
HK used to sell a suitable device but don't seem to have stocked it for some time now.
Edited By PatMc on 09/06/2019 22:01:05
Thanks for the comments.
I think we will have to live with the variation, and just concentrate on the set up / trimming and flying as smoothly as possible.
I have tried adjusting the motor timing (no difference), balancing the batteries (same) and virtually everything else I can think off, without success!.
Height limiters are a good idea, which we use in other events, but the P2K comp is to be kept as simple and cheap as possible, to encourage as many entrants as possible without additional cost,
