Keith Orr 1 Posted February 5, 2020 Share Posted February 5, 2020 Hi Again, Bought a second hand Futaba T6EX 2.4ghz, lovely clean condition, along with linked receiver. I set up the receiver in my new model, which is unfinished, to test, switched on the transmitter, switched on the receiver and all worked as should. I read that when moving receiver to new model it is worth reseting the transmitter ref, say Modl 1, to factory settings, this I did and to my disappointment when I switch on as above the ESC emits a beep, then another beep with double beep, then beep with triple beep, etc etc, the transmitter operates the two servos as normal but not the electric motor. What am I doing wrong, any help gratefully received Quote Link to comment Share on other sites More sharing options...
Jonathan W Posted February 5, 2020 Share Posted February 5, 2020 Try reversing the throttle channel. For safety, remove the propeller while you are doing these checks. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 5, 2020 Share Posted February 5, 2020 On the reset Keith, the throttle may be reversed. High throttle makes the ESC inoperative for safety Reverse and trim down the throttle, then try again Jon beat me to it Edited By Denis Watkins on 05/02/2020 20:19:29 Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 5, 2020 Share Posted February 5, 2020 if reversing the throttle dosent fix it then make sure the trim is all the way down. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted February 5, 2020 Share Posted February 5, 2020 My money is on throttle reversing too - I think Futaba's throttle direction is reversed relative to most other brands, so you have to change it for most esc's. Quote Link to comment Share on other sites More sharing options...
Keith Orr 1 Posted February 5, 2020 Author Share Posted February 5, 2020 Absolutely spot on, all fixed. Thank you all for your input, I am much obliged. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted February 6, 2020 Share Posted February 6, 2020 Keith Orr 1 Still a useful learning experience. 1. Futaba throttle works opposite to all most other Tx. Remember it you will probably come across it again. 2. "If it ain't broke don't fix it". Quote Link to comment Share on other sites More sharing options...
Keith Orr 1 Posted February 6, 2020 Author Share Posted February 6, 2020 Good advice Simon, thank you. Still havent resolved the issue with my Hitec Optic 6 Sport 2.4 ghz, all I am getting from Hitec is that it could be a faulty module and can't seem to find out how to repair or replace (it getting the feeling that because its a "budget" transmitter there is not much interest, maybe cost of doing anything about it would be relatively expensive??, so, if anyone has further ideas on that one please let me know. Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted February 6, 2020 Share Posted February 6, 2020 Mike Ridley Keith you could try Mike, he covers most radios and gives an excellent service. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 6, 2020 Share Posted February 6, 2020 hello again Keith, buying 2nd hand is ok/ish if you know the seller...other than that be careful...also when setting up and getting to know your radio...take off the prop from an electric set up or you will damage your carol singers-fingers(well and truly) should the setting be wrong and the motor springs into life.....and it wont stop even when it hits anything.....hope you haven't given up on the hitec. ken anderson....ne..1..carol singers dept. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted February 6, 2020 Share Posted February 6, 2020 Posted by Trevor Crook on 05/02/2020 21:55:00: My money is on throttle reversing too - I think Futaba's throttle direction is reversed relative to most other brands, so you have to change it for most esc's. Be aware that Futabe exponential sttings are reversed from other makes.Futaba use negetive ( - )expo for soft center on sticks while JR and I believe Spectrum use (+) positive expo for softer center movements. Get it wrong and you could have an exciting flight Quote Link to comment Share on other sites More sharing options...
Keith Orr 1 Posted February 7, 2020 Author Share Posted February 7, 2020 Morning, Thanks again for all of your comments, very helpful. I now have the Futaba working as should, the Hitec operates the first model but refuses to go into link mode so can only operate with the first model, bit inconveint but will do for the time being. By the way, I did speak to Mike, thanks, and also Geoff at Perkins, both came to the conclusion that the module is faulty, Geoff gave me a indication of cost to repair/replace the module, so I now have options. I like the feel of the Futaba so may well go down the road of replacing the receiver in the first model so that both are on the Futaba, neater. Quote Link to comment Share on other sites More sharing options...
