Tosh McCaber Posted June 24, 2020 Share Posted June 24, 2020 Calling DX9 owners. Sorry if this is a bit wordy! I am tearing my (little that I've left) hair out, due to the complete lack of instructions for the Spektrum DX9 I have a Phoenix motor glider, bought off a fellow club member. He helped to set up the model as a glider, in DX9 Sailplane mode, assisted by the motor. That is, the throttle is presently activated by Switch A- either full on or full off. The throttle lever works incremental crow braking. Various flight modes, Launch, Cruise and Landing Mode, are activated by the three way Switch D. I'm not really interested in high level glider competition, with the associated need for all the bells and whistles. What I'm looking for is the motor to be activated by the throttle lever, so I can toodle around the field at leisure, or have the variable throttle to stretch a landing. I would still like the availability of crow landing for both flat field and slope, which I would be happy to have as a two stage setup on, say, Switch A. Unfortunately, all the set ups that I can find on You Tube are for my intial glider type set up. My existing Port Assignments are as follows: 1 THRO: Left Ail 2 AILE: Right Ail 3 ELEV: Elevator 4 RUDD: Rudder 5 GEAR: Motor 6 AUX 1: L Flap 7 AUX2: R Flap 8 AUX 3: Aux 3 9 AUX 4: Aux4 My thoughts are, that I need to swap the motor to either "Aux" 1 or "Aux2", and one of the flaps , presently on "Aux" 1 and "Aux2", being activated by "Gear". But where do I go from there?? At this point, I've decide to hopefully get some guidance from people who know more than me. Can anyone help, please? Thx in advance. Quote Link to comment Share on other sites More sharing options...
The Whistler Posted June 24, 2020 Share Posted June 24, 2020 Hi, Manual can be found here if it helps: **LINK** Quote Link to comment Share on other sites More sharing options...
Linds.W Posted June 24, 2020 Share Posted June 24, 2020 Hi I have a Phoenix 2ooo and a 2400 great gliders. Both flown with aDX8 . Ihad a look at my TX and always have the throttle on the normal stick pos. the 2000 flaps on a Y-cord aelirons on the normal rx port. The 2400 has "crow" braking as it's a heavy old lump! Ailerons left normal port rt aileron to aux (6) .The switch A I use as a "motor" cut switch for safety. Don't know why your set up has split-flaps tho'- Switch D does all the flaps/crow. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 24, 2020 Author Share Posted June 24, 2020 Thanks for the above, guys. Unfortunately Whistler, the link to the manual leads me to the absolutely useless abbreviated instructions which come with the DX9! Thanks anyway. What I am really looking for, if possible, is a step by step guide to go into the tranny, and go from a to b – that is, to have my motor activated by the throttle stick, and my flaps activated in two positions as a crow landing aid, activated by switch D. (Apologies- at one point, I miscalled stick D as switch A in my query above). Like you Linds, I use switch A as a motor cut-off switch for safety. The reason for dual servos to the flaps- a) the model came that way! and b) it gives the oppurtunity to have switched coupled ailerons and flaps. Thx again. Quote Link to comment Share on other sites More sharing options...
Linds.W Posted June 24, 2020 Share Posted June 24, 2020 Hi Tosh I think the way forward i to dump this and start a new model memory and i'm sure the throttle will "normal" to channel 1 on the rx If it's a spectrum rx all will work I use a Lemon RX 6 chan and a 610 spectrum in the 2400 phoenix all work ok. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 24, 2020 Author Share Posted June 24, 2020 Thx Linds, Are you set up as sailplane or acro? As it is, my elevator, rudder and ailerons are fine- it's just geting past the hump of motor vs flaps. Edited By Tosh McCaber on 24/06/2020 15:30:36 Quote Link to comment Share on other sites More sharing options...
John Lee Posted June 24, 2020 Share Posted June 24, 2020 Have you seen the various options discussed in this thread? Quote Link to comment Share on other sites More sharing options...
Ronaldo Posted June 24, 2020 Share Posted June 24, 2020 Hi Tosh I have my Hotliners on my Black Dx 9 with the motor on throttle stick. It looks like you are using the sailplane setup same as I am. You need to unplug your motor from 'gear' on your Rx, and put the 'right flap' plug in. Then reassign 'right flap' to 'Gear' in 'channel assign' program. Now plug your motor into Aux 2 on your Rx, reassign Aux 2 to 'motor. . Then on the Tx 'channel assign' page click next at the bottom of the screen to go into 'channel input config', and reassign Aux 2 to Throttle stick. This is how I've set my hotliners and gliders up. Ps I set my crow up in the 'camber preset' program on a 3 position switch 'G'. Position 1 no flaps for high 'Cruise' ... speed flying. Position 2 for 'Thermal' ... a little down ailerons, and a little down flaps. Position 3 for 'landing' ... crow flaps. Ailerons still work in all positions. All deflections can be set on 'camber peset' page to your preferences using the roll button on the percentages slider to suit your glider. Hope this helps Edited By Ronaldo on 24/06/2020 20:52:51 Edited By Ronaldo on 24/06/2020 20:55:07 Quote Link to comment Share on other sites More sharing options...
Steve Colman Posted June 24, 2020 Share Posted June 24, 2020 How timely this thread is. I've just got a DX9 too Quote Link to comment Share on other sites More sharing options...
Linds.W Posted June 24, 2020 Share Posted June 24, 2020 Yes Tosh all the gliders on Sailplane if you don't I think crow/ flap won't work.I had to ask a few years ago on here to get the crow to work on the DX8 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Hi Ronaldo. Thanks for your advice. Carried out the mods to the receiver plugs. as shown in the right hand column below. Switching on afterwards, the readings on the Tx are as follows: Went to Rx Port Assignments- swithed motor/ esc lead to Aux2, and R. Flap to Gear. Then on to next Screen, after mods, CHANNEL INPUT CONFIG modified to: 1 THRO: N/A 2 AILE: N/A 3 ELEV: N/A 4 RUDD: N/A 5 GEAR: N/A 6 AUX 1: N/A 7 AUX2: Thr 8 AUX 3: RLv 9 AUX 4: RLv Unfortunately, after this, I'm still getting Motor activated by Switch A, and Flaps activated by throttle!! Just can't understand it! Where have I gone wrong?? Help! Solution appreciated! Edited By Tosh McCaber on 25/06/2020 11:45:41 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 When I try to think logically about the problem- ( it's beginning to grind me down!!), what I need to find is the partition in the DX9 transmitter set up procedure that shows me Switch A controlling the motor, and the motor lever controlling the flaps. Then I can switch the two around. At present, I haven't found any place mentioning Switch A as a control! Can anyone say where that should be? Thx for any help! Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 25, 2020 Share Posted June 25, 2020 Toss My Caber me lad Have a look on " Monitor " to see where switch A is allocated, and indeed see if it is still Swich A and flick the switch to see the movement on " Monitor " screen While you are in there, flick all your mix switches to see what they are joined too And see too that what you think is the throttle stick does Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Investigating further, I looked under Sailplane Type section of the Tx menu, and found at the bottom of the screen an entry- Motor: Switch A. I changed it to Motor: Thr. Stick. Switched on- still no motor control, throttle stick controlling the flaps. Don't know whether there's a conflict with the flaps still contolled by the throttle stick. Now, if I can find the section to move the flaps to Switch A in the TX, hopefully the set-up may work! I just had a thought- does anyone know whether having the motor controlled by the throttle stick is possible on Sailplane setup? Or will I have to go to Acro? Edited By Tosh McCaber on 25/06/2020 14:52:50 Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted June 25, 2020 Share Posted June 25, 2020 It might be easier to start a new model memory using Acro. I have done this on two electric gliders with flaps camber and crow assigned to switches on a DX6. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Did you manage to have motor controlled on the throttle stick, Shaun? I'm more or less on a "new" setup at present- it's just the swapping over of motor and flaps control I can't find anywhere so far. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted June 25, 2020 Share Posted June 25, 2020 Posted by Tosh McCaber on 25/06/2020 14:56:23: Did you manage to have motor controlled on the throttle stick, Shaun? I'm more or less on a "new" setup at present- it's just the swapping over of motor and flaps control I can't find anywhere so far. Yes, motor on throttle stick. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 25, 2020 Share Posted June 25, 2020 see the movement on " Monitor " screen While you are in there, flick all your mix switches to see what they are joined too Check the Mixes Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 In Monitor, I can see that the throttle stick controls both flaps and motor. However, using the throttle stick on the model only activateds the flaps- no response from motor. Mixing Monitor: AIL > RUD Fmode AIL > FLP Thr Mix 0 FLP > RAL On All the rest Inh Doies this make sense? Thx Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 25, 2020 Share Posted June 25, 2020 Inhibit INH Those mixes you don't want Tosh E.g Ail > RUD F Mode Highlight RUD F mode and scroll thumb wheel to INH. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Mixing Monitor: 1) AIL > RUD Fmode 2) AIL > FLP Thr 3) Mix 0 FLP > RAL On 4) All the rest Inh Which of these, Dennis- 1, 2, or 3, or all? Thx Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 25, 2020 Share Posted June 25, 2020 INH all of those Tosh Then later, you can have a mix as you desire E.g some Cub pilots like Ail > RUD mix, to bring the tail round in a banked turn. But can switch this off with the mix1 switch, in order to make flatter Aileron with opposite rudder turns Edited By Denis Watkins on 25/06/2020 17:32:53 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Thanks very much Dennis- I now have motor working on the throttle stick! but the bad news is that the throttle stick is stil also controlling the flaps. We're getting there! - But how do I sort out the flaps from here? How do I get them off the throttle stick, and onto Switch A, now it's not the throttle control, or Switch D, rembering that I already have flight modes- Launch Cruise Cruise Mode Landing Mode activated there. I guess that I can choose between the two switches, so long as i deactivate the throttle controlling the flaps! Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 25, 2020 Share Posted June 25, 2020 Right Tosh, you or someone may have taken a channel shortcut to make connection easier But your Tx and Rx rely on correct channel order So check for TAER. Spectrum operates that order 1 Throttle 2 Aileron 3 Elevator 4 Rudder 5 Flaps 6 AUX1 You may think it is ok to plug this here and swap there but when Programming, your Tx doesn't know what you did. Your Motor is Channel 1 Throttle And your mixes must still have some residual connection to Flap At some point someone may have selected Motor Low Flap down mix? Check your monitor and watch for connected movement on the top line Channel 1 This should bring some boffs out of the woodwork I don't know where the programming lads are hiding Edited By Denis Watkins on 25/06/2020 20:38:33 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted June 25, 2020 Author Share Posted June 25, 2020 Thx Dennis- that's the set-up that I use for my power planes. I understood in this case, that the difference is that I'm flying a motor glider. I've been told by quite a few glider guiders that the set up that I showed at the start of my thread was the way to go, with motor as an on-off switch. However, the way I'm setting things up is very much as a power plane. The initial setup was how the model was set up when I bought it. Next question- hopefully I can still go with "Sailplane" mode, incorporating your TAER setup, and somehow then obtain my flaps/ crow landing setup via switch D? Edited By Tosh McCaber on 25/06/2020 22:37:42 Quote Link to comment Share on other sites More sharing options...
