Martin McIntosh Posted August 15, 2020 Share Posted August 15, 2020 Never had that problem with servos but electric retracts yes. I got another set of HK small MCR series ones but they would not respond to Orange Rx`s, OK on others and a servo tester, also some replacement amps I got for them were the same. After complaining that the manufacturer had probably made a change they sent me a free set, just the same so I checked various Rx outputs to find that some were only providing a 3V pulse, others which worked were 5V. Fat lot of good if they will not work with HK gear. If those extentions are made from flat wire, not twisted then that could be where the problem lies. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted August 16, 2020 Share Posted August 16, 2020 This type of problem - although on the face of it, one that should be easy to sort out given the few components involved - can be a pig to nail down to an exact cause. Some years ago back in the 35 Meg days, I had a pair of servos of the same make but not one of the mainstream brands, that would always chatter and hunt around centre at switch on. The other Futaba servos in the model were all working as they should. Give the suspect servos a nudge on the sticks or by pushing the output arms and they'd be fine until switch off and on again and the same thing would happen - not always, but probably three times out of five to add to the mystery. After faffing and substitution, swapping this with that etc etc it turned out that they'd be fine on their own directly from the Futaba RX but use another particular servo as well with them (a small and expensive futaba that I had on the rudder) and that would set them dancing at switch on, until they were nudged. All the servos would work perfectly in isolation. An odd problem that I have a theory as to why it occurred, but again something that does happen when mixing and matching parts from various brands. IIRC, I bought another couple of the 'dancing servos' and fitted all four of that type on their own in another small model without an issue until I sold the model on years after. Edited By Cuban8 on 16/08/2020 11:09:52 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 16, 2020 Share Posted August 16, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
J D 8 Posted August 16, 2020 Share Posted August 16, 2020 Funny thing but this morning I fully assembled for the first time a bitsa motor glider I have been putting together and found the airbrake servo was messing things up not going the correct travel [ the only non Futaba ] and with chatter on ailerons and even setting the motor off into little bursts. On its own it worked fine. Everything normal with it disconnected . Now to dig it out of the awkward position in the wing. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 16, 2020 Author Share Posted August 16, 2020 "Then I remembered that I have some unused TowerPro SG90 (plastic geared) servos. They work fine on the extensions, with no juddering. However, I don't particularly want to use them on this 2 metre wingspan motor glider." After positive prompts from my clubmates about them, I'm going with the SG90s. Keeping my fingers crossed! Many thanks for all the comments and suggestions. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 16, 2020 Share Posted August 16, 2020 Tosh, I hope that they are genuine Tower Pros and not ebay ones which will give you huge unforseen problems. On another thread I posted what was happening with my TN electric Hurricane. It had Hitec 82MGs on ailerons and flaps and a JR 591 on rudder. Although it had been flown many times a Hitec started to oscillate to full travel. Replaced twice to no avail then a forumite suggested that another servo was affecting it. Turned out that the JR did not like the 5.5V BEC output. Replaced and problem solved. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 16, 2020 Author Share Posted August 16, 2020 Right- before we finish the thread- can any of you give me a heads up on a good reliable (reasonably priced) servo (or different brands of servos) that would be able to fit into my TowerPro MG/SG 90 slots? I'm quite happy to pay for peace of mind! Thanks in advance! Edited By Tosh McCaber on 16/08/2020 18:28:46 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 16, 2020 Share Posted August 16, 2020 Hitec good reliable servos available with metal gears sizes shown in details **LINK** Quote Link to comment Share on other sites More sharing options...
Ben B Posted August 16, 2020 Share Posted August 16, 2020 Hmmm. Interesting thought. My first thought was "ferrite bead" but agree a counterfeit servo could explain a lot. Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted August 17, 2020 Share Posted August 17, 2020 I noticed a query earlier asking if the ext leads were twisted or flat, if flat then there are two possible issues. 1/ The leads are picking up interference from each other due to the signal wires laying parallel to each other over a long(ish) distance. This is why telephone cables are not only twisted but when cable joints are made pairs get cross connected to minimise pickup of signals from adjacent wires. 2/ the cables are picking up other signals ie R/C transmissions or if you are on a workbench rather than out at the field it could even be mains interference from Fluorescent lights. Dependent on the electronics in the servos some servos will be affected more than others by either form of pickup. Have you tried twisting the extension leads? Also very valid points mentioned about knock off servos, Fake Tower Pro and Futaba servos are rife on ebay. Get MG90s from Steve Webb (Servo Shop) they are genuine. I use quite a few. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted August 18, 2020 Share Posted August 18, 2020 Hi Tosh. PM sent Quote Link to comment Share on other sites More sharing options...
Keith Miles 2 Posted August 18, 2020 Share Posted August 18, 2020 Posted by Tosh McCaber on 15/08/2020 06:45:39: I naively thought that extension leads were extension leads- all being equal. Not a question of money! Can anyone give me a lead (pardon the pun!) to somwhere who sells "heavy duty" leads? Thx! Belated input! Despite a comment to the contrary, leads are available in at least two different guages (e.g. Futaba STD and HD). They are also available flat or twisted and I think (though I could be wrong) that the latter are usually HD. A web search will provide you with a number of stockists. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 18, 2020 Author Share Posted August 18, 2020 Can you tell me what guage I should be lookin for with long extension leads? I've seen 22 AWG twisted leads advertised- is that standard- or thicker? Quote Link to comment Share on other sites More sharing options...
Keith Miles 2 Posted August 18, 2020 Share Posted August 18, 2020 Posted by Tosh McCaber on 18/08/2020 16:27:18: Can you tell me what guage I should be lookin for with long extension leads? I've seen 22 AWG twisted leads advertised- is that standard- or thicker? RC World is showing the Twisted leads as HD 22. Not looked at Ripmax site but you will probably be able to cross reference that on there. Of course, you don’t have to buy Futaba but at least you can probably trust the specs! Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 18, 2020 Author Share Posted August 18, 2020 Thx, but- 22 AWG- HD 22 ?? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 18, 2020 Share Posted August 18, 2020 Tosh, you already have 2 x 2ft extension leads, so use those Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 18, 2020 Author Share Posted August 18, 2020 Dennis- for future reference! Quote Link to comment Share on other sites More sharing options...
Keith Miles 2 Posted August 18, 2020 Share Posted August 18, 2020 Posted by Tosh McCaber on 18/08/2020 18:50:31: Thx, but- 22 AWG- HD 22 ?? Correct! 22 gauge wire. Heavy duty. You’ll find them online. 20 gauge are also available. 28 seems to be the standard (lighter) gauge. RC World seem to carry a wide range. Edited By Keith Miles 2 on 18/08/2020 22:03:24 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 18, 2020 Author Share Posted August 18, 2020 So- smaller the guage- thicker the wire? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 18, 2020 Share Posted August 18, 2020 Google AWG for info and conversion charts. Edited By Martin Harris on 18/08/2020 23:09:13 Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 19, 2020 Author Share Posted August 19, 2020 Thx again for all the replies- the fog has cleared! Edited By Tosh McCaber on 19/08/2020 14:08:46 Quote Link to comment Share on other sites More sharing options...
Keith Miles 2 Posted August 19, 2020 Share Posted August 19, 2020 Posted by Tosh McCaber on 19/08/2020 14:07:15: Thx again for all the replies- the fog has cleared! Edited By Tosh McCaber on 19/08/2020 14:08:46 You're not the first to query "big is small, small is big" scenario, nor will you be the last! I hope the fog also clears on the "jittering servos" scenario and it would be interesting to know, in due course, what cures it! Never experienced it myself apart from years ago when using using Futaba 33M (I think) servos which, as someone said, suffered from wiper/track issues. Other than that, I have heard anecdotes, in years past, of servos not liking NiCd/NiMh 6 volt packs, especially when at full charge. One would hope that things have moved on since then and that modern servos are more tolerant. Servo ratings do still seem to relate to "nominal" battery voltages i.e. 4.8, 6 and 7.4(HV). Until now, I had not considered that servos might interfere with one another. An interesting thread. Quote Link to comment Share on other sites More sharing options...
