PWLT Posted October 24, 2020 Share Posted October 24, 2020 Hi, a bit of a left-field and newbie question combined if I may please. I'd like to create a dummy radial engine for a restoration project I'm working on. However, the radial kits made from ply/wood I've seen advertised don't look anything like the actual single cylinder 4 stroke I intend to use for the aircraft powerplant. Recently, I came across a website that sells 3D CAD models of RC engines and I wondered if this would be a good foundation on which to try and reconstruct the dummy radial by 3D printing the extra cylinders? This design, in particular, look like my OS FS. **LINK** So before I dive in and try something new, I thought I should ask if anyone has tried this before and if yes, then what was the result, pros and cons etc. Obviously, the weight and toughness of the 3D materials would be a major consideration and especially its resistance to heat. Thoughts? Many thanks in advance Regards to all Peter Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 24, 2020 Share Posted October 24, 2020 I haven't done a 3D printed engine but I did one of my Locamp homebuilt. A long and fairly tedious job but worth it. This involved stamping out an awfull lot of 1/32 ply discs in two sizes plus extra for the finned valve chests The other tricky task was making the rocker covers with the engine name embossed on each one. You can just see the four stroke engine sticking out on the right side of the engine Quote Link to comment Share on other sites More sharing options...
kevin b Posted October 24, 2020 Share Posted October 24, 2020 Try here. **LINK** Quote Link to comment Share on other sites More sharing options...
PeterF Posted October 24, 2020 Share Posted October 24, 2020 Here is the engine on my Stearman from 3D LabPrint (see here , the engine files are part of the overall model files. Printed on a typical budget home printer, AnyCubic MegaS. Quote Link to comment Share on other sites More sharing options...
Gary Clark 1 Posted October 24, 2020 Share Posted October 24, 2020 Hi Peter, There are lots of smart people who have designed 3d radials out there and they are pretty easy to print. I have printed loads of R2800 engines from one i downloaded a few years back and they can be made very realistic with little effort. What engine is it you are looking for? Gary Quote Link to comment Share on other sites More sharing options...
Martian Posted October 24, 2020 Share Posted October 24, 2020 We need a clear idea of the radial engine you want to replicate but yes it's easily possible and do you own a printer ? Edited By Martian on 24/10/2020 21:14:41 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted October 24, 2020 Share Posted October 24, 2020 It does rather depend on how detailed you want the dummy to be. The more detail the more likely it will be a 3D printed kit of parts. The ASh 62 for my AN2 There are over 60 parts glued together. Edited By Simon Chaddock on 24/10/2020 21:43:09 Quote Link to comment Share on other sites More sharing options...
Martian Posted October 24, 2020 Share Posted October 24, 2020 Here's my f2800 Quote Link to comment Share on other sites More sharing options...
PWLT Posted October 24, 2020 Author Share Posted October 24, 2020 Thanks everyone, there is clearly a lot of expertise here!! The single-cylinder engine I hope to mount is an OS FS-70S. In my simple view of the world, I would "print" an additional 4 cylinders and use them to fabricate a reasonable impression of a 5 cylinder OS radial. The end result would be close to something like an O.S. FR5-300 SIRIUS 5-Cylinder Radial This isn't for a scale model, so it doesn't have to be a scale representation of a full-size engine. It's purely to add some interest to a rather chunky sports/trainer. The existing cowl has never looked quite right to me, so I thought I'd do away with it and fit a "fake" radial instead of mounting just a single-cylinder engine. I don't own a printer myself, but I have used online services in the past and the results have been impressive. Thanks again Peter Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted October 25, 2020 Share Posted October 25, 2020 Peter, I made this dummy engine, constructed from water waste pipe, bleach bottle, balsa and drinking straws. The model is 12 years old so it has held up well, it's not scale but finishes the model off. I also made a depron version for electric, the plans for this were published a few years ago in RCM&E, same principle. Quote Link to comment Share on other sites More sharing options...
PWLT Posted October 25, 2020 Author Share Posted October 25, 2020 Posted by Richard Harris on 25/10/2020 That looks excellent and exactly what I’m hoping to achieve! It sounds like traditional model crafts are still the way to go. I’ll report back progress in due course. Thanks again to all. Peter Quote Link to comment Share on other sites More sharing options...
