Allan Bennett Posted April 27, 2021 Share Posted April 27, 2021 I've already updated most of my receivers to v2 firmware without any problem, having bought an X9D Plus 2019 earlier this year with v2 firmware already loaded. But I'm bamboozled when it comes to updating my X9D Plus to v2 -- everything I read on the internet seems to relate to updating the OTX, the instructions on the FrSky site start by telling me to download the update and then copy the .bin file (which I don't see) to the trannie's SD card, and following a thread I found in this forum doesn't work for me either. Here's where I'm at: I've downloaded XJT_ACCST_2.1.0_LBT.frk from the X9D Pluse page on the FrSky downloads site, and copied it into the FIRMWARES and FIRMWARE folders on my trannie's SD card. My trannie reports that it's got OTX Bootloader 2.2.3, and Curr FW: opentx-x9d+-2.2.3. So, having switched on the trannie with both trims towards the middle, I have the options to Write Firmware, Restore EEPROM, or Exit. So, where do I go from there, please? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted April 27, 2021 Share Posted April 27, 2021 17 minutes ago, Allan Bennett said: XJT_ACCST_2.1.0_LBT.frk I have just done this on my Taranis X9D 2019 SE which uses access. To upgrade the RF module I switched on the TX Long pressed Menu pressed page which took me to SD-HC card Select [FIRMWARE} find the frk file XJT_ACCST_2.1.0_LBT.frk in your case. Long press enter Flash internal module press enter. Fingers crossed that it is the same for you. Quote Link to comment Share on other sites More sharing options...
John Muir Posted April 27, 2021 Share Posted April 27, 2021 Hi Allan, I think you need to start the tx normally then follow Earlybird's instructions. Don't hold the trims in. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted April 27, 2021 Share Posted April 27, 2021 1 minute ago, John Muir said: Hi Allan, I think you need to start the tx normally then follow Earlybird's instructions. Don't hold the trims in. Oops I missed out the obvious. Yes start the tx normally. ? Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 27, 2021 Share Posted April 27, 2021 You don't need to be in bootloader mode to flash internal firmware - just navigate to the relevant folder on the SD card, press Enter on the frk file and select "Write to internal module". Job done! Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 27, 2021 Share Posted April 27, 2021 Great minds and all that... ?? 1 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 27, 2021 Author Share Posted April 27, 2021 Is that it? ? It seems to have gone okay, and I've bound a v2 receiver to it as a check. Thanks guys, it's easy when you know how! 1 Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 27, 2021 Share Posted April 27, 2021 46 minutes ago, Allan Bennett said: Is that it? ? It seems to have gone okay, and I've bound a v2 receiver to it as a check. Thanks guys, it's easy when you know how! Yep, updating module firmware is pretty straightforward, but we all do it so infrequently it’s always a bit of a memory test when it is required! Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted April 27, 2021 Share Posted April 27, 2021 1 hour ago, MattyB said: Yep, updating module firmware is pretty straightforward, but we all do it so infrequently it’s always a bit of a memory test when it is required! That's the problem I have with this sort of stuff. I have to read up and re-learn it every time I update - and I'm getting worse with age. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 27, 2021 Author Share Posted April 27, 2021 1 hour ago, MattyB said: Yep, updating module firmware is pretty straightforward, but we all do it so infrequently it’s always a bit of a memory test when it is required! Yup, that's my problem. I can remember receiver updating because there's so many of them, but a trannie is once in a blue moon! And FrSky (and others on the internet) doesn't help by refering to both their firmware and the OS (OTX in my case) as "Firmware". Quote Link to comment Share on other sites More sharing options...
Andy48 Posted April 28, 2021 Share Posted April 28, 2021 The main pain for me, once I'd remembered how to do it, was that the update screwed up all my telemetry. As I use it a lot, resetting that has been a real chore. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted April 28, 2021 Share Posted April 28, 2021 (edited) I'm facing the same issue - a 2019 X9D Plus still on the original OpenTX 2.2.4 and firmware and a dozen RXs still on ACCST 1 etc - which all works perfectly, and I'm loathe to have to do anything more than just use it to fly models! So, what is the merit of NOT changing anything? The only downside I can see is that, if all new RXs are only now available with ACCST 2, this'll mean flashing them back to ACCST 1...? Edited April 28, 2021 by Jonathan M Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 28, 2021 Share Posted April 28, 2021 7 minutes ago, Jonathan M said: I'm facing the same issue - a 2019 X9D Plus still on the original OpenTX 2.2.4 and firmware and a dozen RXs still on ACCST 1 etc - which all works perfectly, and I'm loathe to have to do anything more than just use it to fly models! So, what is the merit of NOT changing anything? The only downside I can see is that, if all new RXs are only now available with ACCST 2, this'll mean flashing them back to ACCST 1...? I am still on ACCST v1 (FCC, not LBT). I have chosen to stay there for now because: I have never experienced an uncommanded servo movement (USM) due to the bug, and I have been a Frsky user for nearly 10 years; From what I have read USMs were more likely on the LBT firmware (which I don't currently use) than FCC version; Updating all my D16 RXs to ACCST v2 is a much bigger job than just flashing any new ones I to v1 (though obviously I won't be able to do that forever as new model RXs will only run v2), and; I am uncertain on my next major TX purchase, so have just bought the lowest cost RM TX16SE as an experiment/insurance whilst Frsky play out their strategy - this allows me to guarantee the future of my existing D16 and D8 RXs on whatever version of ACCST I choose in future. YMMV, but I hope that helps. I certainly wouldn't worry about it if you have never seen a USM to date! 1 Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted April 28, 2021 Share Posted April 28, 2021 One reason some people don't want to upgrade from V1 to V2 is they use D8 receivers, that are no longer supported on the V2 Tx firmware (because they don't meet EU regulations). For this situation, I've written D16 firmware that runs on D8 receivers, see here for details: https://www.rcgroups.com/forums/showthread.php?3391195-FrSky-D16-firmware-for-D8-receivers&perpage=20. This doesn't just do D16, it does: Auto detection of protocol V1/V2, FCC/EU at bind time. Dual bind, easily rebind between two transmitters. Use Hub or SPort telemetry sensors. Optionally use a servo output for SBUS, either polarity. Select servo outputs to be 18mS or 9mS period (individually selectable). Map servo outputs to channels. Configure options using a script on the Tx. Link quality reporting over telemetry, with other statistics available using a script to read them. Mike 3 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 28, 2021 Author Share Posted April 28, 2021 (edited) Edit: Post deleted. Edited April 28, 2021 by Allan Bennett Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted June 24, 2021 Share Posted June 24, 2021 On 28/04/2021 at 10:22, Andy48 said: The main pain for me, once I'd remembered how to do it, was that the update screwed up all my telemetry. As I use it a lot, resetting that has been a real chore. Is that definitely the norm for performing the V1 to V2 upgrade? I keep thinking that should upgrade my Taranis X9D+ and receivers, but I make a fair bit of use of telemetry (altimeter/vario, Neuron ESCs for mAh consumed etc). In what way was telemetry "screwed up"? Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted June 24, 2021 Share Posted June 24, 2021 On 28/04/2021 at 14:28, Mike Blandford said: One reason some people don't want to upgrade from V1 to V2 is they use D8 receivers, that are no longer supported on the V2 Tx firmware (because they don't meet EU regulations). For this situation, I've written D16 firmware that runs on D8 receivers, see here for details: https://www.rcgroups.com/forums/showthread.php?3391195-FrSky-D16-firmware-for-D8-receivers&perpage=20. This doesn't just do D16, it does: Auto detection of protocol V1/V2, FCC/EU at bind time. Dual bind, easily rebind between two transmitters. Use Hub or SPort telemetry sensors. Optionally use a servo output for SBUS, either polarity. Select servo outputs to be 18mS or 9mS period (individually selectable). Map servo outputs to channels. Configure options using a script on the Tx. Link quality reporting over telemetry, with other statistics available using a script to read them. Mike Mike, I think you are getting ACCST V2 and ACCESS mixed up, D8 works fine with ACCST V2 it's ACCESS it won't work with. Phil Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted June 25, 2021 Share Posted June 25, 2021 Indeed, but if, with openTx, you also update the radio firmware, you have to make sure you also enable D8 to be available. However, you may consider my firmware for all the extra features you get, as well as not needing to make sure you have matching firmware on the Tx and Rx. Mike Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 25, 2021 Share Posted June 25, 2021 (edited) 12 hours ago, Philip Lewis 3 said: Mike, I think you are getting ACCST V2 and ACCESS mixed up, D8 works fine with ACCST V2 it's ACCESS it won't work with. Phil It's not V1/V2/Access, it's the change from the iXJT tx module to the ISRM one. ISRM still works for ACCST V1 and V2 but only in D16 mode, Access is just a bonus. Edited June 25, 2021 by Bob Cotsford Quote Link to comment Share on other sites More sharing options...
Andy48 Posted June 25, 2021 Share Posted June 25, 2021 17 hours ago, Tim Kearsley said: Is that definitely the norm for performing the V1 to V2 upgrade? I keep thinking that should upgrade my Taranis X9D+ and receivers, but I make a fair bit of use of telemetry (altimeter/vario, Neuron ESCs for mAh consumed etc). In what way was telemetry "screwed up"? Once upgraded, the new firmware no longer recognises the existing telemetry. The only option I found was to search for telemetry again, and delete the old ones. You then need to check carefully through all your programming to see what has happened to the telemetry. Sometimes that needs resetting too. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted June 25, 2021 Share Posted June 25, 2021 18 minutes ago, Andy48 said: Once upgraded, the new firmware no longer recognises the existing telemetry. The only option I found was to search for telemetry again, and delete the old ones. You then need to check carefully through all your programming to see what has happened to the telemetry. Sometimes that needs resetting too. OK, thanks Andy. That's rather annoying isn't it? I keep thinking that I must upgrade to ACCST V2, but then think why fix it if it isn't broken? I know there exists the "uncommanded servo movement" bug but in the several years that I've used FrSky I've yet to see a single instance of it. I guess the time will come when receivers will only be sold with V2 firmware. At the time of writing, T9 Hobbysport will flash an rx with V1 at no extra charge. Perhaps I'll hang on until I move to ACCESS! Quote Link to comment Share on other sites More sharing options...
Andy48 Posted June 25, 2021 Share Posted June 25, 2021 (edited) 2 hours ago, Tim Kearsley said: OK, thanks Andy. That's rather annoying isn't it? I keep thinking that I must upgrade to ACCST V2, but then think why fix it if it isn't broken? I know there exists the "uncommanded servo movement" bug but in the several years that I've used FrSky I've yet to see a single instance of it. I guess the time will come when receivers will only be sold with V2 firmware. At the time of writing, T9 Hobbysport will flash an rx with V1 at no extra charge. Perhaps I'll hang on until I move to ACCESS! It is very annoying, but then its been a good chance to get each model out, update it, check all the programming, and update that so that each model is consistent (I must be OCD ?), and then check over the model itself and tidy it up. After that its a few test flights and all good to go. All in all quite worthwhile in the long run, and at some point the move to V2 will have to take place. Its been quite an interesting exercise overall. One or two models that will get put into a swap meet, but a number of other problematic ones that now fly far better than I realised. Edited June 25, 2021 by Andy48 Quote Link to comment Share on other sites More sharing options...
