Robin Colbourne Posted August 5, 2021 Share Posted August 5, 2021 (edited) It is not unusual to see model wheels described as 'low bounce'. Presumably this means they deform on impact but dodn't just act as a spring, launching the model back in the air. This raises three questions for me: Do 'low bounce' wheels leak some air out to provide damping, or is it just a property of the synthetic rubber or plastic from which they were made? Which currently available wheels offer the best 'low bounce' properties, foam or hollow rubber? Of the various makes described as low bounce, are any notably better than the rest? Edited August 5, 2021 by Robin Colbourne Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 5, 2021 Share Posted August 5, 2021 Whilst I do like 'proper' inflatable air wheels on my larger / heavier models, these ones from SLEC are the ones I use on most of my other models. They provide a nice bit of damping on landing! Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted August 5, 2021 Share Posted August 5, 2021 Looks very similar to a Dubro wheel. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 5, 2021 Share Posted August 5, 2021 (edited) Foam wheels, apart from light weight aeroplanes, do you no favours on landing Robin, they are just too hard. Dubro low bounce are heavy for 3' - 4' span, but work well at 5' span and above, and are low bounce, and more commonly fit in around 3" Inflatable air wheels are best 4" 5" 6" dia wheels inflatable air wheels come in a few guises, but most I tried, do deform brilliantly on landing. As you suggest Robin, there are big differences in wheels And they do offer genuine low bounce Edited August 5, 2021 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted August 5, 2021 Share Posted August 5, 2021 Fitted du-bro on my Katana which has a rather rigid carbon UC, work well. Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 5, 2021 Share Posted August 5, 2021 1 hour ago, Ron Gray said: Whilst I do like 'proper' inflatable air wheels on my larger / heavier models, these ones from SLEC are the ones I use on most of my other models. They provide a nice bit of damping on landing! I think those a manufactured by radio active and they are good. I have used them a bunch. In my experience low bounce wheels have tyres made from fairly stiff rubber that deforms fairly easily but is quite slow returning to its original shape. Sort of like a football that is low on pressure. In truth though, the rate at which a model may bounce is usually as much down to the smoothness of the touchdown as it is anything else. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted August 5, 2021 Share Posted August 5, 2021 Dubro and Oleos on all my larger models. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 5, 2021 Share Posted August 5, 2021 1 hour ago, Peter Jenkins said: Looks very similar to a Dubro wheel. Very similar but not the same, lighter and cheaper. As Jon mentioned above, I too think they maybe Radio Active ones but SLEC sell them at a lot lower prices than most! Quote Link to comment Share on other sites More sharing options...
ASH. Posted August 5, 2021 Share Posted August 5, 2021 (edited) Hangar 9 pro-lite wheels are low bounce and much lighter than Dubro. I think these wheels have an inner foam core. The Slec / Radio Active wheels are good too. Edited August 5, 2021 by ASH. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted August 6, 2021 Author Share Posted August 6, 2021 Thank you for all your replies. It sounds as though a back to back dynamic load/deflection test of a few different makes and types would make an interesting article. Temperature may play a part too. A tyre sidewall at near 0°C is likely to be a lot stiffer than one at 25°C, although the air in the latter will be at slightly higher pressure if it unvented. As JD8 says, the type of undercarriage leg affects whether you want the tyre to be springy or just shock absorbing. I get the impression that it is a lot easier to do a decent landing on wing mounted vertical legs (a la Mick Reeves Gangster) than fuselage mounted legs (a la Precedent HiBoy). The Gangster certainly made my landings look better than I thought they were. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted August 6, 2021 Share Posted August 6, 2021 Robin, remember that a good stable approach is needed before a good landing. Second, most bounces are caused by a late round out or trying to land too fast. Third, it doesn't matter if the U/C is fuselage or wing mounted. Provided you have the room, a shallow powered approach is the easiest way to land. Holding off in a 3 point attitude until the speed decays to the stalling speed will guarantee a landing with no bounce regardless of what sort of tyre you are using. On my 2 mtr aerobatic mount I have 57 mm diameter wheels of hardish composition. If I get the landing attitude and speed right there is no bounce. If I'm fast it will bounce or rather land more than once. If you work on the approach, correct approsch speed and correctly timed round out there will be no bounce. Low bounce wheels are not going to make up for a poor approach, poorly executed flare or trying to land too fast. All will lead to a bounce regardless of the low bounce wheels. Quote Link to comment Share on other sites More sharing options...
