David Davis Posted January 9, 2023 Share Posted January 9, 2023 If I were to fit a 3S 4500 LiPo into a Radio Queen what size propeller and ESC would I require. The Radio Queen weighs 6.5 lbs or 3kgs. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted January 9, 2023 Share Posted January 9, 2023 (edited) Not sure of my reply, removed. Edited January 9, 2023 by Don Fry Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 9, 2023 Share Posted January 9, 2023 4-Max advised setup. What motor are you using? Steve Quote Link to comment Share on other sites More sharing options...
Geoff S Posted January 9, 2023 Share Posted January 9, 2023 If you allow for (say) 80 watts/lb then you need a power train capable of delivering about 500 watts. A 3S LiPo is about 10v on load so you'd need an esc capable of passing 50 amps (so 60 amps for some overhead). The prop size will be dependent on the kv of the motor, which will need to weigh around 150 grams (based on the 3 watts/gram rule of thumb) and happy with a 50 amp current flow. As the fabled George (I'm sure he really does exist 🙂 ) suggests from Steve's post above 4S would be a better choice. Quote Link to comment Share on other sites More sharing options...
David Davis Posted January 9, 2023 Author Share Posted January 9, 2023 I enquired for a friend. If a 3s 4500 battery will fly it, we can use the one we fit in his Junior 60. Quote Link to comment Share on other sites More sharing options...
David Davis Posted January 10, 2023 Author Share Posted January 10, 2023 We haven't yet chosen a motor but according to this, a Protronik 3625-650 which is a similar spec to 4-max's recommendation and much more easily available here in France, produces 491.7 Watts on 11 Volts and a 15x8 propeller. That should be enough to fly a Radio Queen shouldn't it? https://www.weymuller.fr/data/cata-6/23690_02173625_t.jpg Quote Link to comment Share on other sites More sharing options...
Don Fry Posted January 10, 2023 Share Posted January 10, 2023 I think you would be better with a 6” pitch prop. Grunt rather than speed for that airframe. 16x6? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 10, 2023 Share Posted January 10, 2023 The link shows the prop as a 15x12. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted January 10, 2023 Share Posted January 10, 2023 For what its worth I think you'd be fine with less, 80watts/pound isnt necessary for a vintage model, 50 is usually ample and a 300W setup might be easier to find. Its just another opinion 😉 Cheers Phil 2 Quote Link to comment Share on other sites More sharing options...
PatMc Posted January 10, 2023 Share Posted January 10, 2023 (edited) Would be better with a motor of around 900kv or a 4s battery. The original RQ flew across the Channel using a 1/4 hp (195 Watts) 3.5cc ED diesel with something like a 10" or 12" prop & model must have weighed a lot more than 6.5 lbs. Agree with what Phil posted as I typed. Edited January 10, 2023 by PatMc 1 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted January 10, 2023 Share Posted January 10, 2023 David D Just be aware that the Junior 60 is quite a bit lighter than the Radio Queen so you will likely be working the same battery a bit harder. Indeed if you do draw 50A constant you will have to watch the flight duration (4 minutes to be safe). Hopefully it will fly nicely well throttled back. Quote Link to comment Share on other sites More sharing options...
Jason Channing Posted January 10, 2023 Share Posted January 10, 2023 6 hours ago, Phil Green said: For what its worth I think you'd be fine with less, 80watts/pound isnt necessary for a vintage model, 50 is usually ample and a 300W setup might be easier to find. Its just another opinion 😉 Cheers Phil More power the better. OS 52 four stroke in my Junior 60 and it could do with more power flying inverted. Quote Link to comment Share on other sites More sharing options...
