My next assembly ( The sequel ) ..... The Phoenix Domino EP
toto
30 minutes ago, toto said:
***************** HEADLINE NEWS ************* SOMETHING GOES ACCORDING TO PLAN **************
The time and the realisation was dawning that i would have to be able to press my Watt meter into service. Now given the issues with soldering on connections to my ESC's and the " were they dry joints or were they not ............. i was not looking forward to this one little bit.
However, I had to bite the bullet and give it a go ........
It took two attempts with one of the wires as I managed to get solder on the outside of the brass connector which wouldn't allow the connector to " click " in. I thought ... you have to get it right this time ....... and now and behold ..... clicked in it did .... the proof would be in the connection though .... so ....
and ....
it would appear to have life. My soldering is not that bad after all.
I also slid a " tommy " bar through the nose cone ( thanks Ron ) and tightened the prop.
I'm now going to catch up with my mate John Smith for a minute and chill before working out the best way of using this.
hopefully back on a positive footing .... about time as well.
toto
Don't consult your pal John Smith and then run your motor with a prop on.
Not being a killjoy Toto, but ale and props on the bench really do not make good bedfellows - unless that bed is in the local A & E department.
Figures for 12x8
Battery
Load: 10.27 C
Voltage: 21.39 V
Rated Voltage: 22.20 V
Energy: 88.8 Wh
Total Capacity: 4000 mAh
Used Capacity: 3400 mAh
min. Flight Time: 5.0 min
Mixed Flight Time: 9.8 min
Weight: 684 g
  24.1 oz
  Motor @ Optimum Efficiency
Current: 70.06 A
Voltage: 20.50 V
Revolutions*: 9042 rpm
electric Power: 1436.0 W
mech. Power: 1192.1 W
Efficiency: 83.0 %
  Motor @ Maximum
Current: 41.09 A
Voltage: 21.20 V
Revolutions*: 9755 rpm
electric Power: 871.1 W
mech. Power: 694.6 W
Efficiency: 79.7 %
est. Temperature: 79 °C
  174 °F
Wattmeter readings
Current: 41.09 A
Voltage: 21.39 V
Power: 878.9 W
  Propeller
Static Thrust: 3735 g
  131.7 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 3735 g
avail.Thrust @ 0 mph: 131.7 oz
Pitch Speed: 119 km/h
  74 mph
Tip Speed: 560 km/h
  348 mph
specific Thrust: 3.74 g/W
  0.13 oz/W
  Total Drive
Drive Weight: 1132 g
  39.9 oz
Power-Weight: 338 W/kg
  153 W/lb
Thrust-Weight: 1.38 : 1
Current @ max: 41.09 A
P(in) @ max: 912.2 W
P(out) @ max: 694.6 W
Efficiency @ max: 76.1 %
Torque: 0.68 Nm
  0.5 lbf.ft
Climb Capacity: 3174 m
  10413 ft
  Airplane
All-up Weight: 2700 g
  95.2 oz
Wing Load: 54.0 g/dm²
  17.7 oz/ft²
Cubic Wing Load: 7.6
est. Stall Speed: 34 km/h
  21 mph
est. Speed (level): 99 km/h
  61 mph
est. Speed (vertical): 36 km/h
  22 mph
est. rate of climb: 10.7 m/s
( ~85...90° ) 2097 ft/min
Figures for 12x6
Battery
Load: 8.34 C
Voltage: 21.54 V
Energy: 88.8 Wh
min. Flight Time: 6.1 min
Mixed Flight Time: 10.3 min
Weight: 684 g
  24.1 oz
Current: 70.06 A
Voltage: 20.50 V
Efficiency: 83.0 %
  Motor @ Maximum
Current: 33.38 A
Voltage: 21.39 V
Revolutions*: 9945 rpm
electric Power: 713.9 W
mech. Power: 547.4 W
Efficiency: 76.7 %
est. Temperature: 76 °C
  169 °F
Wattmeter readings
Current: 33.38 A
Voltage: 21.54 V
Power: 719 W
  Propeller
Static Thrust: 2911 g
  102.7 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 2911 g
avail.Thrust @ 0 mph: 102.7 oz
Pitch Speed: 91 km/h
  57 mph
Tip Speed: 571 km/h
  355 mph
specific Thrust: 4.08 g/W
  0.14 oz/W
  Total Drive
  39.9 oz
Power-Weight: 274 W/kg
  124 W/lb
Thrust-Weight: 1.08 : 1
Current @ max: 33.38 A
P(in) @ max: 740.9 W
P(out) @ max: 547.4 W
Efficiency @ max: 73.9 %
Torque: 0.53 Nm
  0.39 lbf.ft
Climb Capacity: 3051 m
  10010 ft
  Airplane
  95.2 oz
  17.7 oz/ft²
  21 mph
est. Speed (level): 84 km/h
  52 mph
est. Speed (vertical): 9 km/h
  6 mph
est. rate of climb: 8.3 m/s
( ~50...55° ) 1638 ft/min
Figures for 11x6
Battery
Load: 6.52 C
Voltage: 21.68 V
Energy: 88.8 Wh
min. Flight Time: 7.8 min
Mixed Flight Time: 11.4 min
Weight: 684 g
  24.1 oz
Current: 70.06 A
Voltage: 20.50 V
Efficiency: 83.0 %
  Motor @ Maximum
Current: 26.07 A
Voltage: 21.57 V
Revolutions*: 10125 rpm
electric Power: 562.1 W
mech. Power: 402.2 W
Efficiency: 71.5 %
est. Temperature: 74 °C
  165 °F
Wattmeter readings
Current: 26.07 A
Voltage: 21.68 V
Power: 565.2 W
  Propeller
Static Thrust: 2324 g
  82 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 2324 g
avail.Thrust @ 0 mph: 82 oz
Pitch Speed: 93 km/h
  58 mph
Tip Speed: 533 km/h
  331 mph
specific Thrust: 4.14 g/W
  0.15 oz/W
  Total Drive
  39.9 oz
Power-Weight: 214 W/kg
  97 W/lb
Thrust-Weight: 0.86 : 1
Current @ max: 26.07 A
P(in) @ max: 578.6 W
P(out) @ max: 402.2 W
Efficiency @ max: 69.5 %
Torque: 0.38 Nm
  0.28 lbf.ft
Climb Capacity: 3222 m
  10571 ft
  Airplane
  95.2 oz
  17.7 oz/ft²
  21 mph
est. Speed (level): 79 km/h
  49 mph
est. Speed (vertical): - km/h
  - mph
est. rate of climb: 6.9 m/s
( ~40...45° ) 1351
ft/min
Figures for 11x7
Battery
Load: 6.52 C
Voltage: 21.68 V
Energy: 88.8 Wh
Weight: 684 g
  24.1 oz
Current: 70.06 A
Voltage: 20.50 V
Efficiency: 83.0 %
  Motor @ Maximum
Current: 26.07 A
Voltage: 21.57 V
Efficiency: 71.5 %
  165 °F
Wattmeter readings
Current: 26.07 A
Voltage: 21.68 V
Power: 565.2 W
  Propeller
  82 oz
Stall Thrust: - g
  - oz
  58 mph
Tip Speed: 533 km/h
  331 mph
  0.15 oz/W
  Total Drive
  39.9 oz
  97 W/lb
Torque: 0.38 Nm
  0.28 lbf.ft
  10571 ft
  Airplane
  95.2 oz
  17.7 oz/ft²
  21 mph
  49 mph
  - mph
( ~40...45° ) 1351 ft/min
Figures for 11x7 3 blade
Battery
Load: 9.17 C
Voltage: 21.47 V
Energy: 88.8 Wh
min. Flight Time: 5.6 min
Mixed Flight Time: 10.1 min
Weight: 684 g
  24.1 oz
Current: 70.06 A
Voltage: 20.50 V
Efficiency: 83.0 %
  Motor @ Maximum
Current: 36.67 A
Voltage: 21.31 V
Revolutions*: 9864 rpm
electric Power: 781.4 W
mech. Power: 611.0 W
Efficiency: 78.2 %
est. Temperature: 78 °C
  172 °F
Wattmeter readings
Current: 36.67 A
Voltage: 21.47 V
Power: 787.3 W
  Propeller
Static Thrust: 3283 g
  115.8 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 3283 g
avail.Thrust @ 0 mph: 115.8 oz
Pitch Speed: 105 km/h
  65 mph
Tip Speed: 520 km/h
  323 mph
specific Thrust: 4.20 g/W
  0.15 oz/W
  Total Drive
  39.9 oz
Power-Weight: 302 W/kg
  137 W/lb
Thrust-Weight: 1.22 : 1
Current @ max: 36.67 A
P(in) @ max: 814.1 W
P(out) @ max: 611.0 W
Efficiency @ max: 75.1 %
Torque: 0.59 Nm
  0.44 lbf.ft
Climb Capacity: 3170 m
  10400 ft
  Airplane
  95.2 oz
  17.7 oz/ft²
  21 mph
est. Speed (level): 91 km/h
  57 mph
est. Speed (vertical): 22 km/h
  14 mph
est. rate of climb: 9.5 m/s
( ~60...65° ) 1870 ft/min
No worries Leccyflyer,
I only had one and then came in doors to have a look through Watt Meter info on the internet. Like Lipo's I tend to give props the greatest of respect.
I wont be back in the shed tonight. I need to try and get my head around the figures that the Watt Meter is chucking out. This side of things was always going to take a bit of time so I'll just Idle through this bit at my own ( normally slow ) pace. No rushing this.
I'll be back in the shed tomorrow to do a rerun with the connection of the watt meter and hopefully be better able to understand what its telling me. To be honest .... I'm just delighted to have achieved the connections to get it working so far .... it's a very small step forward.
Cheers
Toto
Correction
Figures for 11x7  2 blade should be
Battery
Load: 7.26 C
Voltage: 21.62 V
Energy: 88.8 Wh
min. Flight Time: 7.0 min
Mixed Flight Time: 11.2 min
Weight: 684 g
  24.1 oz
Current: 70.06 A
Voltage: 20.50 V
Efficiency: 83.0 %
  Motor @ Maximum
Current: 29.05 A
Voltage: 21.49 V
Revolutions*: 10052 rpm
electric Power: 624.5 W
mech. Power: 462.2 W
Efficiency: 74.0 %
est. Temperature: 75 °C
  167 °F
Wattmeter readings
Current: 29.05 A
Voltage: 21.62 V
Power: 628.1 W
  Propeller
Static Thrust: 2673 g
  94.3 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 2673 g
avail.Thrust @ 0 mph: 94.3 oz
Pitch Speed: 107 km/h
  66 mph
Tip Speed: 529 km/h
  329 mph
specific Thrust: 4.28 g/W
  0.15 oz/W
  Total Drive
  39.9 oz
Power-Weight: 239 W/kg
  109 W/lb
Thrust-Weight: 0.99 : 1
Current @ max: 29.05 A
P(in) @ max: 645.0 W
P(out) @ max: 462.2 W
Efficiency @ max: 71.7 %
Torque: 0.44 Nm
  0.32 lbf.ft
Climb Capacity: 3375 m
  11073 ft
  Airplane
  95.2 oz
  17.7 oz/ft²
  21 mph
est. Speed (level): 86 km/h
  53 mph
  - mph
est. rate of climb: 8 m/s
( ~45...50° ) 1577 ft/min
2 minutes ago, toto said:
Shaun,
Thanks for the above, I take it I will be comparing the output readings from the Watt Meter with those above when I hit this again tomorrow night.
I can't wait :classic_wacko:
I usually find that the eCalc figures are pretty close to those measured with my wattmeter.
Remember that static current figures will be higher than those measured when the model is flying.
5 minutes ago, toto said:
Shaun,
I also measure thrust using a set of luggage scales attached to the tail of the model.
something like this
Beurer LS Dynamo Power Luggage Scale - White 0
What prop manufacturer does e calc relate too as the efficiency differs between makes?
Well ..... the wheels were changed over ....
for ....
and .......
for .....
What a job I had getting the originals off.  I had used thread lock on the screws .... and they would not slacken under any condition. luckily the rear wheels had a rear locking nut ( Nylock ) that I was able to remove to get the axle out and replace the wheels ...... but no such luxury with the front nose wheel.
It was stuck fast to the point where I knackered the screw head trying to slacken it off ........ this called for the heavy mob .......
so .... some heat applied to the collett and ..... off it came.
Wheels now replaced.
that's me for the moment.
toto
  • Like 2
for ....
and .......
for .....
toto
Good job Toto.  Those new wheels will make a difference.
Hi Toto. I am the bearer of bad new. No but. There are two sorts of flyers. Those who have had a wheel fall off, due to a collet. And those who will.
Now, use locktite. Secondly your slow forgiving airframe will give you an interesting landing if a wheel falls off, but will survive. Suggest, relax, get it down lightly, don’t tense up for perfection, or even where you wanted it, or you will fail. But it’s still not the end of the earth, it’s a tough trainer.
Next time you attach a wheel, a brass tube, soldered over the steel axle, can be drilled out, and a split pin inserted and it’s there forever.
Steep learning curve.
  • Like 2
OK ..... for now ..... two tasks that I still need to do prior to any pre maiden flight check by my mentor / club buddies.
1.    determine the draw with the Watt meter with the model set up as it is.
I had already been familiarising myself with this but still have the final task to undertake properly. I've sort of been easing myself back into this as the past couple of days my brain has been pickled. So this will be coming up.
2.    set up the electrics again with Battery, receiver, all servo's etc etc and check all the servo settings / throws etc.
Again, I'd like to ease my frazzled brain back into this as when I present this for a pre - maiden check over, I'd like my buddies to see that my initial set up has been at least attempted and not just handed over for someone else to do it. Also ..... I need to get used to doing this on every model I bring into service.
I think the above ( notwithstanding generally assembling the airframe ) is the bread and butter of preparing the model for flight.
However, for tonight .... thats it ..... one small step at a time for now ..... the rush is off.
toto
  • Like 2
Clean the inside of the tube. Clean the axle. Drill the tube, but long from final position. Easier to file down to right length, than just get it right. 60 / 40 is good, and flux. Don’t forget, a washer or so each side to act as thrust races.
But not the current build, locktite, and hope. That’s what I would do, and it won’t break that airframe. Different story, long hours scale build.
Thanks Don,
As you say, leave the current build as is. The locktite is far better / stronger than I imagined. It has welded the collar to the axle. As I mentioned, it needed heat to get it off. .... well impressed but makes you think a little before using. Especially if you can ever foresee a reason to get the part back off.
Build with it by all means but make sure all the test fits etc are done before applying .... :classic_biggrin:
Cheers
Toto
I don't use loctite for the reason you encountered.
One thing I found, when I was learning landings and touch-and-goes on a hard strip, was that the rear wheels would get splayed out by heavy landings and then the plane would sit on the ground with the nose slightly up - which makes for bouncy landings. Better to bend the rear legs back into their correct positions or shorten the nose leg so that the plane always sits horizontal or slightly nose down. The other thing I found, with a steerable nose wheel coupled to the rudder, was to have only a very small movement on the nosewheel compared with the rudder.
Edited by John Stainforth
omission
@toto Your head must he spinning by now, with all the conflicting advice!  You'll soon learn what to discard (I may already fall into this category!), what to try, and what suits you best.
Personally, I've never had an issue with loctite (the blue stuff) if using the correct allen key/tool to undo it.
You'll find what you like regarding amount of movement on rudder and nosewheel.  For starters, use what's recommended in the manual, then adjust if necessary. Inability to control the model due to too much or too little steering is a pain....
@John StainforthI've only ever had one plane with a tricycle undercarriage, and am curious as to why splayed rear legs would cause/exacerbate bouncy landings......
  • Like 2
