Surface finishing techniques
Ariel
I have printed a pilot's head and I was wondering what techniques everyone uses to prepare the surface for painting. It's not bad at the moment though the printer will stand a bit more tuning, but I can see the lines showing up once the primer hits it. I would like to get the surface as smooth as possible.
It's printed in grey Creality Hyper PLA. First serious attempt other than a few rabbits for the grandchildren. They seem happy!
There is a video on the Easy composites website where they use coating resin but I'm not sure how well acrylic paint would stick.I guess it's going to require some testing. I'll run a few more rabbits off and see how they come out with various finishes.
  • 3 weeks later...
Hi
I just kept hitting these PLA Mk117ish bombs I drew up with Halfords high build yellow primer and gently sanding back.  About 4 coats each.  Easy enough on simple shapes but would be a pain I imagine on a figure/head.
Tamiya acrylic primer and Tamiya Acrylics after that.  When finished dust with a satin 2K clear coat (or matt or gloss as required).
Mike
PS the bomb racks were only given a single coat of primer.  Don’t sand too hard.  Maybe 280 grit wet and dry used wet
Edited by MikeQ
Those look good! Festivities and travels over I should be back at the bench next week so I'll see what I can come up with. I think I can still get a better quality print once I get Klipper dialled in. There's a lot to learn before you start! All in all very pleased with the printer though.
