Edgeflyer Posted April 8 Share Posted April 8 This is getting expensive. Does anyone use alternatives successfully? Quote Link to comment Share on other sites More sharing options...
Outrunner Posted April 8 Share Posted April 8 I bought some Blenderm recently off eBay and it was expensive at £5 or £6 for a 4.5m roll, then the other day i noticed SMC are flogging it off cheap https://sussex-model-centre.co.uk/products/db916-electric-flyer-hinge-tape-5-yds-7 I've used Scotch tape and it's almost as good as Blenderm but I didn't regret buying the proper stuff as it will last for quite a few models. Quote Link to comment Share on other sites More sharing options...
Duncan Disorderly Posted April 8 Share Posted April 8 Cheapest bought from medical suppliers, as it's manufactured for sticking stuff to skin. Way cheaper than any model supplier but you might have to buy a box, which is what I did last time - most eagerly consumed by my clubmates. e.g. 4.5m x 2.5cm - box of 12 rolls for £16 Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted April 8 Share Posted April 8 (edited) Available in Boots the Chemists in different sizes, (other stores are available, try your local pharmacy). Edited April 8 by Philip Lewis 3 Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted April 8 Share Posted April 8 (edited) Reinforced sticky tape. cut into 30mm lengths two lengths stuck together to make 50 mm long ( with one reversed( ,made into figure of 8 hinges ( four hinges per surface). Easy version of sewn hinge ! Edited April 8 by john davidson 1 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 8 Share Posted April 8 Look for Sellotape Diamond tape if you can find any otherwise their Superclear tape 8s the currdnt nearest. Very strong adhesive, UV resistant and once on its unoticable as its so clear. The Scotch tape super clear is not very good. 1 Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted April 8 Author Share Posted April 8 Thanks All for great tips. I ordered 12 rolls from Duncan's medi supplier. Works out at £1.60 each. Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted Tuesday at 08:41 Share Posted Tuesday at 08:41 When using Diamond tape as a hinge .is it used as one continuous strip along the hinge just on one surface or is it better to use both top and bottom surfaces like using the covering film technique . Could the top and bottom technique be used but only using say one inch strips at suitable positions thanks Keith Quote Link to comment Share on other sites More sharing options...
