SIMON CRAGG Posted April 12 Share Posted April 12 I am in the process of fitting two 70mm 12 blade 4s EDF motors to a 65" high wing model. The EDF's will be in nacelles under the wing with a neutral thrust line. My question is, how far out from the fuz do the EDF's need to be fitted? My thinking so far, is as close to the fuz as possible, so any minor mis match in thrust will not be as noticeable etc. Anybody any ideas please?. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 12 Share Posted April 12 As close to the fuselage as possible sounds right to me too, for the reason you've stated, and to minimise the structural load on the wing. I would also question whether a little bit of down thrust would be good, as is usually the case with normal front-mounted props, to counteract the lift when the throttle is increased. Quote Link to comment Share on other sites More sharing options...
EvilC57 Posted April 12 Share Posted April 12 Yep, I’d say as close to the fus as possible. I certainly wouldn’t do this…! Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted April 12 Share Posted April 12 Those things look like great fun! Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 12 Share Posted April 12 I will disagree with the statements above. Pods for the fans need to be mounted away from the fuselage some so inlet is away from air disturbed by said fuzz. Note. Full size practice with types like A 10 thunderbolt, VC 10, Learjet and many more. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted April 12 Share Posted April 12 A not so obvious reason why (jet) engines on wings are set away from the fuselage is that the mass of the engines opposes bending moments due to lift and consequent G effects (e.g. the engines get "heavier" while the wings are generating more lift in a turn) so the centre section doesn't experience as much stress. 2 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 12 Share Posted April 12 I was going to say what Martin said, but if you want to do cartwheel manoeuvres then having them spaced apart will help 😉 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 12 Share Posted April 12 7 hours ago, J D 8 said: I will disagree with the statements above. Pods for the fans need to be mounted away from the fuselage some so inlet is away from air disturbed by said fuzz. Note. Full size practice with types like A 10 thunderbolt, VC 10, Learjet and many more. I agree. In my earlier post I was thinking of A10 Thunderbolt and Learjet, both of which I have, so I should have said as close as reasonably possible, or something like that. Quote Link to comment Share on other sites More sharing options...
