Mounty Posted May 27, 2007 Share Posted May 27, 2007 Has there been any articles or information put into print in the magazine with regards to installing and setting up / starting of petrol engines, this is an area I would like to explore after seeing a friends plane with a 20cc petrol engine installed, any of the above info/photos/advice would be most welcome, Cheers, Joe Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 28, 2007 Share Posted May 28, 2007 JoeWe had an article in our 'special' issue last autumn, this was an intro to petrol engines. The special was the one with a Spit on the front (Spitfire free plan) Quote Link to comment Share on other sites More sharing options...
Mounty Posted June 7, 2007 Author Share Posted June 7, 2007 Thanks for this David, I think I must have missed this issue/article as I never saw this info, what was the date of the Autum issue as I may still have it, modellers never part with anything. Cheers, Joe Quote Link to comment Share on other sites More sharing options...
nasa_steve Posted June 9, 2007 Share Posted June 9, 2007 joe it was the RCM&E SPECIAL and not a regular monthly mag it has a black cover with the tony nihuis spit on the frontregardsnasa Quote Link to comment Share on other sites More sharing options...
steve-richards Posted October 1, 2014 Share Posted October 1, 2014 I have an Everlution 20cc engine fitted in an wot 4 xl I have fitted it at a 90 degree angle my problem is that the stock exhast hits the fire wall is there a conversion that will place the exhast under the model Steve Quote Link to comment Share on other sites More sharing options...
steve-richards Posted October 1, 2014 Share Posted October 1, 2014 any ideas Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 1, 2014 Share Posted October 1, 2014 Just engines do custom exhaust pipes and headers.....worth a ring? Quote Link to comment Share on other sites More sharing options...
steve-richards Posted October 1, 2014 Share Posted October 1, 2014 thanks i will give them a ring anymore ideas would be helpfull Steve Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 1, 2014 Share Posted October 1, 2014 Here?? But not cheap.....ouch! Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 1, 2014 Share Posted October 1, 2014 Just Engines sell BCM Pitts style exhausts for Evolution petrols, or Puffin Models sell the MVVS range which will fit the Evo Quote Link to comment Share on other sites More sharing options...
Masher Posted October 1, 2014 Share Posted October 1, 2014 Watch out if buying the Pitts style exhausts mentioned above. I just fitted a model out for a club member which included a new Evolution 10cc petrol engine with Just Engines Pitts style exhaust - it is stupidly loud and would fail any noise test or lose a flying field. It's just an empty tin box which fits the engine and cowl but does nothing to muffle the noise. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 1, 2014 Share Posted October 1, 2014 What would it be like inverted Steve, or can you cut the bulkhead ? John Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 1, 2014 Share Posted October 1, 2014 Odd, I have a JE BCM Pitts on a 60FX and it's not too bad at all, though the Evo 10GX does have a nasty edge to the exhaust - I need to run 13*8 props to get through the club test with the standard silencer. Is it a BCM or JE's own branded unit? Quote Link to comment Share on other sites More sharing options...
steve-richards Posted October 2, 2014 Share Posted October 2, 2014 Posted by john stones 1 on 01/10/2014 21:41:46: What would it be like inverted Steve, or can you cut the bulkhead ? John No i cant cut the bulkhead and inverted would look stupid iv been looking at the in cowl ones would they be noisey Steve Quote Link to comment Share on other sites More sharing options...
Masher Posted October 2, 2014 Share Posted October 2, 2014 It was one like this Bob link I assume things would quieten down a bit when the engines is fully run in and when a bigger prop is fitted but I can't imagine it would get down to the required noise level. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted October 2, 2014 Share Posted October 2, 2014 Posted by Bob Cotsford on 01/10/2014 21:50:47: Odd, I have a JE BCM Pitts on a 60FX and it's not too bad at all, though the Evo 10GX does have a nasty edge to the exhaust - I need to run 13*8 props to get through the club test with the standard silencer. Bob...you need to fit your 10GX with an ASP52 muffler fits perfectly & really takes the crackle off the Evos exhaust note with no loss of power that I can detect.....works very well... Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 2, 2014 Share Posted October 2, 2014 Thanks Steve, I think I have at least one spare, I'll give it a try. Masher, that looks to be more compact than the BCM ones. I stuck a pair of 'Exhaust deflector - expansion' (halfway down the page)on the outlets on mine to make the 61 really purr. Quote Link to comment Share on other sites More sharing options...
Paul Adams Posted October 2, 2014 Share Posted October 2, 2014 The only way I could get mine below the noise limit was to fit a canister exhaust. Makes a neat installation:- Quote Link to comment Share on other sites More sharing options...
Rich too Posted October 2, 2014 Share Posted October 2, 2014 Posted by Mounty on 27/05/2007 20:45:00: Has there been any articles or information put into print in the magazine with regards to installing and setting up / starting of petrol engines, this is an area I would like to explore after seeing a friends plane with a 20cc petrol engine installed, any of the above info/photos/advice would be most welcome, Cheers, Joe not sure about that, but having moved from glow to petrol myself, I found the most important bit of information to be in regards to the alignment of the prop in relation to TDC. After many, many attempts at hand starting my 1st petrol, I discovered that the props are not aligned the same as a glow engine. If you get that right, I find mine easy to hand start - I've never used a starter on my petrol engines. Rich Quote Link to comment Share on other sites More sharing options...
Charles Lee Posted October 2, 2014 Share Posted October 2, 2014 My manifold pipe was custom made by Weston Uk for a very reasonable price & quickly too. Quote Link to comment Share on other sites More sharing options...
steve-richards Posted October 2, 2014 Share Posted October 2, 2014 I may have to goto weston uk for mine when iv done the mesurments very costly Steve Quote Link to comment Share on other sites More sharing options...
Charles Lee Posted October 2, 2014 Share Posted October 2, 2014 They only charged about £35 for the manifold. Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted October 2, 2014 Share Posted October 2, 2014 My son has bitten the bullet and bought a petrol engine, a Saito 4 stroke. We've dabbled with 2 strokes but have been unable to get the noise down. Finally, four strokes seem to have solved the problem. Whilst it was an expensive engine, Saito 30cc, it's excellent. I can foresee that four stroke petrol will be the way to go. Quote Link to comment Share on other sites More sharing options...
Charles Lee Posted October 2, 2014 Share Posted October 2, 2014 Your giving him too much pocket money Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted October 4, 2014 Share Posted October 4, 2014 Fear not, he's working and earning now. He revelling in having his own money, saving up for flying lessons and buy anything whatever he wants. Hence the Saito. Ah, the lack of responsibility...... Quote Link to comment Share on other sites More sharing options...
