Doug Ireland Posted December 7, 2010 Share Posted December 7, 2010 Gents, a question any car mechanics out there. I have a gallon of old two-stroke mix (20:1) that I need to dispose of. My question is will it damage the engine of my car (X-Type Jag) if pour it into the tank? Quote Link to comment Share on other sites More sharing options...
Klippy Posted December 7, 2010 Share Posted December 7, 2010 If it was made with leaded petrol, then don't do it! If not, then if you put it into a nearly full tank, then it shouldn't make too much difference. Don't take just my word for it though. I think Ultimate is pretty good with these things. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted December 7, 2010 Author Share Posted December 7, 2010 Thanks Tony, hopefully Eric or Ulti will see this. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 7, 2010 Share Posted December 7, 2010 Doug No problem. Many moons ago ,I ran out of petrol at sea ,but had a mix in a tin for my seagull outboard motor So i put it in the tank for the Volvo inboard/outboard main motor . Well you would wouldn't you with the Cornish rocks ahead ! Absolutely no problems.5 star petrol if i remember 'cos I was running an E-type at the time (wish I still had but that's another story ) Myron Ah! Pure nostalgia ! Quote Link to comment Share on other sites More sharing options...
Ultymate Posted December 7, 2010 Share Posted December 7, 2010 Won't hurt Doug, obviously the more petrol you dilute it with the better Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted December 7, 2010 Share Posted December 7, 2010 makes good weedkiller doug Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted December 7, 2010 Author Share Posted December 7, 2010 Thanks for the reassurance guys, I've got maybe 3/4 of a tank in the car already so I'll just top it off with the two-stroke stuff. cheers, Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 7, 2010 Share Posted December 7, 2010 Better still use it as an excuse to buy a petrol engine and model to go with it............. Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted December 7, 2010 Share Posted December 7, 2010 Posted by Phil Claridge on 07/12/2010 17:13:43: makes good weedkiller doug Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted December 7, 2010 Author Share Posted December 7, 2010 Posted by Frank Skilbeck on 07/12/2010 22:06:48:Better still use it as an excuse to buy a petrol engine and model to go with it............. Frank, I already have a couple of petrol engined models. The fuel in question is over a year old and in need of replacing. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted December 7, 2010 Share Posted December 7, 2010 DougDoes petrol actually go off?After all the stuff it is distilled from is millions of years old. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 8, 2010 Share Posted December 8, 2010 Petrol definitely goes off (usually within a couple of years) but I'd also be concerned about poisoning the cat - the tin box full of expensive platinum, not the furry thing on the sofa - assuming it has one... Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted December 8, 2010 Author Share Posted December 8, 2010 Posted by Martin Harris on 08/12/2010 00:00:26: Petrol definitely goes off (usually within a couple of years) but I'd also be concerned about poisoning the cat - the tin box full of expensive platinum, not the furry thing on the sofa - assuming it has one... I think my car has two, one for each pipe. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 8, 2010 Share Posted December 8, 2010 I thought as much but with all the talk of E-types, I did wonder if you meant it was a Mark X - which wouldn't suffer in the least. For info - from a cat manufacturer's website: Plugged Or Contaminated. Plugged or contaminated catalytic converters are caused by using the wrong sort of fuel in your car. Using leaded or lead replacement fuel will plug up the monolith and cause it to stop working. A similar thing will happen if fuel additives are used that are not suitable for use with a catalytic converter. Oil FouledThis is caused by oil getting into the exhaust system and contaminating the catalytic converter. The most likely cause is a leaking gasket. Using old 2 stroke fuel might cause either of these unhealthy conditions although I accept it would be well diluted. Personally, I wouldn't risk it for the sake of a fiver! Edited By Martin Harris on 08/12/2010 11:10:04 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 8, 2010 Share Posted December 8, 2010 Simon Your comment about " Does petrol go off ?" reminded me of something that an old mining /china clay worker friend of mine down Cornwall once said when selling his house which had a coal shed .Full of coal ! he said, but havn't used any for a couple of years --It's probably gone off by now . True story Myron Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 8, 2010 Share Posted December 8, 2010 Posted by Simon Chaddock on 07/12/2010 23:35:46:DougDoes petrol actually go off?After all the stuff it is distilled from is millions of years old. Reminds me (sorry, bit off topic) of when I checked some bottled water that claimed it contained water that had been filtered through rocks for several million years - mine was within a few months of its use by date - lucky or what?!?!?Edited By Martin Harris on 08/12/2010 11:16:47 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 8, 2010 Share Posted December 8, 2010 PS Why is it that when I try to insert smileys ,all I get is a little circle with a red cross in it & I have to start all over again . I do have a new hard drive in my lap top but can't get to grips with it .Can't even get any mail .Sorry ---Wrong thread ! Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 8, 2010 Share Posted December 8, 2010 Martin After millions of years the proper water has finally been contaminated by man made plastic bottles giving it a miniscule life span (comparatiively speaking that is) Quote Link to comment Share on other sites More sharing options...
kc Posted December 8, 2010 Share Posted December 8, 2010 Put it in your lawnmower or give it to someone who has a petrol lawnmower! Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted December 8, 2010 Share Posted December 8, 2010 Martin Just read your reference to "E" type / Mark 10 jag . I can assure you that it was an "E" type & the reg was 216 HYO .Never forget it ! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 8, 2010 Share Posted December 8, 2010 Keep on topic please guys. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 8, 2010 Share Posted December 8, 2010 Myron, I don't doubt it - I wouldn't have forgotten either! I was referring to Doug's X-type... Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 8, 2010 Share Posted December 8, 2010 Whoops - sorry Timbo but your admonishment was on the next page!!! Quote Link to comment Share on other sites More sharing options...
