Richard Harris Posted January 6, 2012 Share Posted January 6, 2012 Posted by David Gilder on 05/01/2012 13:11:41: Ben Buckle New Matador, with Enya 15-5 engine! Good choice David Did you pick up your calender? Rich Quote Link to comment Share on other sites More sharing options...
David Gilder Posted January 6, 2012 Share Posted January 6, 2012 It arrived in the post a few days before Xmas!! Very kind of Steve!! Quote Link to comment Share on other sites More sharing options...
John Green Posted January 7, 2012 Share Posted January 7, 2012 Astro Hog, from the Sig kit. Quote Link to comment Share on other sites More sharing options...
Andrew Bourne Posted February 4, 2012 Share Posted February 4, 2012 Drake 2 from 1952 Ken Willard plan Almost completed - see here Quote Link to comment Share on other sites More sharing options...
Glasshopper Posted February 4, 2012 Share Posted February 4, 2012 playboy senior Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 4, 2012 Share Posted February 4, 2012 my project X........Top Secret..... ready for it's maiden somewhere in the north east .. .. ken anderson ne..1.. secret testing facility dept. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted February 4, 2012 Share Posted February 4, 2012 Tell me when the test flight is and I'll bring Gamine along to test fly,I'm hoping that the good King Keneth or lord Weasel of Alnwick will fly this for me at Greenacres. 60" span with OS48 surpass up front JC ne23 snivel dept. Quote Link to comment Share on other sites More sharing options...
batcho99 Posted April 10, 2012 Share Posted April 10, 2012 The Champ. PAW 06 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted May 8, 2012 Share Posted May 8, 2012 Doug McHard's "Wee Snifter" for my old Mills 0.75. I built one in 1961, also with a Mills 0.75. This one will be radio controlled, which was impossible then, even if I'd had any money! Quote Link to comment Share on other sites More sharing options...
Junior 60 Posted June 29, 2012 Share Posted June 29, 2012 Junior 60, electric powered and Ben Buckle Elf also electrified Quote Link to comment Share on other sites More sharing options...
Alexandre Rillos Posted June 29, 2012 Share Posted June 29, 2012 80" Pietenpol Air Camper from plans, electric power, Turnigy Power 60, 5S 5000mah, 80A esc. Quote Link to comment Share on other sites More sharing options...
ebeneezer Posted October 3, 2012 Share Posted October 3, 2012 15inch span scaled down indoor Vic Smeed Tom Thumb Quote Link to comment Share on other sites More sharing options...
mick pemberton Posted October 6, 2012 Share Posted October 6, 2012 Hi guys im building an ABC Robin from an old Aero modler plan it used to be rubber powered but im putting a OS10 in it and building it with ailarons, dont now why but i just like the shape and its only small ,so i can keep it in the car and fly it when i get a chance Edited By mick pemberton on 06/10/2012 07:59:06 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 6, 2012 Share Posted October 6, 2012 Hi Guys are you going to bring them along to Greenacres 2013? There will be an opportunity to fly with the models that missed out this year due to poor weather. Would be great to see them? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted October 6, 2012 Share Posted October 6, 2012 I've built a Doug McHard Wee Snifter with a Mills 0.75. (Made the last one in 1960). Greenacres could be a good idea. Quote Link to comment Share on other sites More sharing options...
david bufton Posted October 17, 2012 Share Posted October 17, 2012 Matador or Junior 60 both four storke powered. Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted December 4, 2012 Share Posted December 4, 2012 Gamine, Vic Smeed Electric 36" version also got a KK/Flair Junior 60 (72" FS 40 power, a David Boddington kit ?and another DB Plan all halfed baked appart from gamine templates all made most parts cut and ready to start building soon 5/12 I think looks good. Why Gamine well was going to be KK Ajax but the plan I have is crude to say the least (needs a redraw)... So a Big thanks To Jim ta mate Quote Link to comment Share on other sites More sharing options...
bhubesi Posted December 10, 2012 Share Posted December 10, 2012 Schiffermuller from plan Quote Link to comment Share on other sites More sharing options...
Bernard Koussoulos Posted January 8, 2016 Share Posted January 8, 2016 Ben Bukle Fire Brand. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted January 8, 2016 Share Posted January 8, 2016 Seriously thinking about this but converted to electric The Mercury Marauder. Still like its 'diamond' fuselage! My brother built one 62 years ago and I still have the plan and most of the wings. It needed quite a bit of nose weight - about the same as a modest brushless. Also intended to carry ballast in the fuselage under the wing - about the same as a reasonable size LIPo. But would it manage acceptable control with such a tiny fin/rudder or be better with small ailerons instead? Quote Link to comment Share on other sites More sharing options...
Mark Lubbock Posted January 8, 2016 Share Posted January 8, 2016 Hi, the tiny rudder will be fine with that amount of dihedral, use no more than about 20deg movement either way. Also , if you are using an elevator, consider extending a tapered ply dihedral brace out at least 2 rib bays, maybe adding an extra spar and webs to the inner panels, you will be stressing the wing much more than intended even at the same flying weight. A small motor, battery, RX and servos shouldn't weigh much more than the original rubber/prop combination anyway, so should make a great flying model. You should only need 20-30W of power and aim for a CG much further forward than the FF position. Best of luck, hope this helps Quote Link to comment Share on other sites More sharing options...
Bernard Koussoulos Posted July 17, 2016 Share Posted July 17, 2016 Lanzo Record Breaker from an old Ben Bukle plan . Edited By Bernard Koussoulos on 17/07/2016 11:01:29 Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted July 17, 2016 Share Posted July 17, 2016 First complete a Veron Mini-Concord from E-bay and include the wings from my kit purchased from Heset Model Supplies bought when the shop closed in 1976. The wings were left by someone who broke into my garage and took the fuselage plus a number of other modelling items including the box from my DC Merlin powered Southern Junior Models 'Southern Dragon' another plane I have been thinking about building since I lost the original plane in 1962. Quote Link to comment Share on other sites More sharing options...
DCW Posted July 17, 2016 Share Posted July 17, 2016 CAP Devils Duster. I had the above delta in the mid eighties, now long gone. I decided to build another but have been unable to track down a plan. I am therefore resigned to draw up a plan and build one from memory... Hope I get it right! See 'Devils Duster' in the forum. David Quote Link to comment Share on other sites More sharing options...
Graham R Posted July 17, 2016 Share Posted July 17, 2016 on a meagre got back around Posted by Mike Etheridge 1 on 17/07/2016 11:49:04: First complete a Veron Mini-Concord from E-bay and include the wings from my kit purchased from Heset Model Supplies bought when the shop closed in 1976. The wings were left by someone who broke into my garage and took the fuselage plus a number of other modelling items including the box from my DC Merlin powered Southern Junior Models 'Southern Dragon' another plane I have been thinking about building since I lost the original plane in 1962. Heset model Supplies - there's a name from the past. Bought my 1st R/c model kit from there around 1973 - a Mercuy Matador. Tried to fly in using a wee Magreggor single channel with a 3 function escapment . Push once for left, twice for right and if you were very quick 3 times for kick up elevator. 1st and only flight (if you could call it that) was over on Mitcham Common nr Croydon. Everybody had to stop flying as the set was I think Superhet? (Only one radio at a time). They didn't have to wait very long, about 20secs if I remember correctly. Those were the days. Quote Link to comment Share on other sites More sharing options...
