John Smith 50 Posted September 9, 2016 Share Posted September 9, 2016 I am looking for a prop for one of these http://extremeflightrc.com/91-Extra-300-RedWhiteBlack_p_495.html the recommended is a Xoar 24 x 12 wooded, but can't seem to find one in the UK. What other makes are their which are good quality? Are MenZ any good. Quote Link to comment Share on other sites More sharing options...
iqon Posted September 9, 2016 Share Posted September 9, 2016 menz are good also look for agm on ebay Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 9, 2016 Share Posted September 9, 2016 I like the menz props and use them a lot Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 9, 2016 Share Posted September 9, 2016 Puffin models do the make and size you are looking for. Xoar Beech Gsa propeler £24.95 Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 9, 2016 Share Posted September 9, 2016 I usually buy Xoar as they come balanced what motor are you using? Edited By Rich2 on 09/09/2016 15:03:42 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 9, 2016 Share Posted September 9, 2016 Another vote for Xoar - good props. BEB Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 9, 2016 Share Posted September 9, 2016 Why not ask your local mdoel shop (LMS). I bet they could do with your suport. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted September 9, 2016 Share Posted September 9, 2016 Falcon props supplied by Steve the PropGuy. Very good prices and always in balance, more can be said for most of the Menz props i've had over the years. CB Quote Link to comment Share on other sites More sharing options...
John Smith 50 Posted September 9, 2016 Author Share Posted September 9, 2016 Posted by Rich2 on 09/09/2016 15:02:15: I usually buy Xoar as they come balanced what motor are you using? Edited By Rich2 on 09/09/2016 15:03:42 either Xpwr 60cc Electric Motor or Eflite Power 360 Brushless Outrunner Motor, 180Kv, not sure yet. Quote Link to comment Share on other sites More sharing options...
John Smith 50 Posted September 9, 2016 Author Share Posted September 9, 2016 Posted by bert baker on 09/09/2016 15:10:55: Why not ask your local mdoel shop (LMS). I bet they could do with your suport. I have tried my local model shop many times, I have even gone out of my way to get stuff from them but they never have what I want / need. Quote Link to comment Share on other sites More sharing options...
John Smith 50 Posted September 9, 2016 Author Share Posted September 9, 2016 Posted by bert baker on 09/09/2016 15:00:22: Puffin models do the make and size you are looking for. Xoar Beech Gsa propeler £24.95 I need electric and they only go up to 22" Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 9, 2016 Share Posted September 9, 2016 here or does it have to be wood try the g sonic pro as well (efficient) or apc electric here Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 9, 2016 Share Posted September 9, 2016 You don't need an electric! True it would be a bit lighter - but frankly at this size you are fine with the gas one! I often us so-called "gas" or "IC" props on electric powered models. BEB Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 9, 2016 Share Posted September 9, 2016 I've always thought it was OK to use props intended for IC on electric models but not vice versa because electric specific props are less robust and usually lighter. Geoff Quote Link to comment Share on other sites More sharing options...
iqon Posted September 9, 2016 Share Posted September 9, 2016 Posted by Biggles' Elder Brother - Moderator on 09/09/2016 16:56:44: You don't need an electric! True it would be a bit lighter - but frankly at this size you are fine with the gas one! I often us so-called "gas" or "IC" props on electric powered models. BEB +1 for the size you are after i would be tempted to use IC anyway. Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted September 9, 2016 Share Posted September 9, 2016 You must be looking at a 5000 watt setup for this model In leccy I have the same model . I use biela or mejzlik Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 9, 2016 Share Posted September 9, 2016 Posted by iqon on 09/09/2016 17:28:09: Posted by Biggles' Elder Brother - Moderator on 09/09/2016 16:56:44: You don't need an electric! True it would be a bit lighter - but frankly at this size you are fine with the gas one! I often us so-called "gas" or "IC" props on electric powered models. BEB +1 for the size you are after i would be tempted to use IC anyway. I agree. It would be stiffer and have more "flyweel effect" both of which would be beneficial. BEB Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted September 9, 2016 Share Posted September 9, 2016 If you intend to to 3D . The flying style this model is designed for. you want the lightest prop you can get so you don't get flywheel wffect . It wants to be both de and accelerating as fast as possible . Quote Link to comment Share on other sites More sharing options...
The real Ron Truth Posted September 10, 2016 Share Posted September 10, 2016 For large electric props, try fiela sold by electric wingman. Superb and much stronger than those already mentioned esp around the tips. When compared to even the lightest IC wooden prop they are superior. Lightness is essential to keep the amp draw down. https://www.electricwingman.com/fiala-wood-propellers.aspx Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 10, 2016 Share Posted September 10, 2016 good find those Fiela props and you gan get then painted too direct nice . now loged for future use Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 10, 2016 Share Posted September 10, 2016 What makes you say that an EF extra is "designed for 3d" Ben? Sure they are popular for that, but they are also popular for flying IMAC and F3A style aerobatics. Hell, some people even sports fly them as they fly so well. I have one and don't generally engage in "hanging around"!It's dangerous to make assumptions!BEBEdited By Biggles' Elder Brother - Moderator on 10/09/2016 09:43:00 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 10, 2016 Share Posted September 10, 2016 We don't do personal insults Ben. BEB Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 10, 2016 Share Posted September 10, 2016 Xoar props are goodie expensive. I have had some from HK and they have been of good quality. Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 10, 2016 Share Posted September 10, 2016 Posted by Biggles' Elder Brother - Moderator on 10/09/2016 09:42:02: What makes you say that an EF extra is "designed for 3d" Ben? Sure they are popular for that, but they are also popular for flying IMAC and F3A style aerobatics. Hell, some people even sports fly them as they fly so well. I have one and don't generally engage in "hanging around"! It's dangerous to make assumptions! BEB Edited By Biggles' Elder Brother - Moderator on 10/09/2016 09:43:00 It says as much in the product description. Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 10, 2016 Share Posted September 10, 2016 Posted by cymaz on 10/09/2016 19:44:24: Xoar props are goodie expensive. I have had some from HK and they have been of good quality. I thought Xoar were quite reasonable? And balanced! How much are HK's? Quote Link to comment Share on other sites More sharing options...
